Nasty spare tire/rim
Discussion in '1st Gen Tundras (2000-2006)' started by savagefen, Apr 28, 2023.
  1. Apr 28, 2023 at 9:20 AM
    savagefen
    savagefen [OP] New Member
    Jon
    2002 Toyota Tundra
    LED lighting, back up camera, 2021 Tacoma TRD wheels
    Just thought I'd share my experience removing the spare from my truck after never being removed for 21 years. The hoist mechanism worked great although it looks very rusty, however, separating the wheel from the hoist was difficult due to the amount of rust on both. The hoist was cemented onto the rim so I sprayed PB Blaster and used the pry bar to finally break it free. The rim looks unusable (I wouldn't trust those lug nut holes). With the spare off I now can see the rust on the rear crossmember, I will clean it up and repaint it like I have done with the rest of the surface rust on the frame. I am now looking for a spare rim and tire (maybe CL or Ebay) don't want to spend too much.
    Jack McCarthy likes this.
  2. Apr 28, 2023 at 9:22 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Ha! Mine's worse. :D
    The integrated dry rot edition.
    lionscourt and savagefen[OP] like this.
  3. Apr 28, 2023 at 9:58 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    Yeah mine hadn't been dropped in probably 20+ years; wasn't necessarily rusted, just really stuck on there. Spare was flat so wanted to get that sorted. Had to lower the line and then beat on that hoist a little bit to get it loose. Sprayed the heck out of the mechanism and line with silicone lubricant and spooled it back up. Spare is in the truck bed for now, holding air but with a valve that leaks it down to around 30 psi. Will remount the spare after I have a chance to replace that valve, then clean, sand and repaint the wheel a nice black.
    FYI on car-part.com you can search for wheel types for our trucks (include the 2000-2007 Sequoias), and one of those is the spare, so maybe a junk yard around you has one you can get cheaper than ebay.
  4. Apr 28, 2023 at 10:02 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    I’ve been looking for a 5th wheel to match my trd off-road t4r wheels but nobody wants to sell just one.
    savagefen[OP] likes this.
  5. Apr 28, 2023 at 10:02 AM
    savagefen
    Jon
    2002 Toyota Tundra
    Yeah, good luck there
  6. Apr 28, 2023 at 10:06 AM
    Elevatorguy
    James
    When I had my 16 t4r trail I bought a single wheel to match with no tire from someone that went to pro wheels. They sold all 4 individually.
  7. Apr 28, 2023 at 10:15 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    Search that wheel on car-part and if you find one that's crashed all to hell and missing a wheel, those are your best bet since they already only have 3.
    2mchfun and Elevatorguy[QUOTED] like this.
  8. Apr 28, 2023 at 10:16 AM
    savagefen
    Jon
    2002 Toyota Tundra
    I am looking right now and finding some crashed trucks that I am inquiring about right now
  9. Apr 28, 2023 at 11:10 AM
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    I found a matching 18" gx460 wheel that I have on my tundra on ebay. Had minor car wash scratches. May try looking on there.
    Elevatorguy and savagefen[OP] like this.
  10. Apr 28, 2023 at 11:29 AM
    Oof, you can see the steel is delaminating around the hole there. Not sure how much you'll be able to rescue there, without grinding away the oxidized metal.
    The lip is punched in there for a reason, to add rigidity, so you don't want to kill that totally, necessarily.
    savagefen[QUOTED][OP] likes this.
  11. Apr 28, 2023 at 11:31 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Took me 2 months to find a method 17' wheel with 0 offset, found on offer up for $100, it's not the same model# but close enough for a spare, than found a never used Spare k02 285/70/17 tire same size 2 weeks later at a Toyota meet for $100
    My spare is a method 309 and im running 305nv
    JasonC., lionscourt, shifty` and 3 others like this.
  12. Apr 28, 2023 at 3:03 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    How much rust is in the area where that crossmember attaches to the rest of the frame? Not sure if it's been brought up by you before or not but is there any chance your truck is covered under frame recall?
  13. Apr 28, 2023 at 4:51 PM
    lionscourt
    lionscourt 2006 DC SR5 4X4
    Ray
    CA
    2006 SR5 Tundra 4x4
    NO RUST, step bars, weathertech window and hood protectors, weathertech floor mats
    Taking my tire down tomorrow and spraying/working assembly. I did it when I first bought truck 4 years ago but these type need to be lowered once a year and oiled.
  14. Apr 28, 2023 at 5:14 PM
    savagefen
    Jon
    2002 Toyota Tundra
    I missed the frame recall, but there frame is is in good shape. It had surface rust but we took care of it before it got worse. We would have addressed the crossmember if I would have looked at this earlier.
  15. Apr 28, 2023 at 5:42 PM
    NickB_01TRD
    Nick
    KY
    It's still active for your year. Mine looked good for the most part other than where the spare tire crossmember attached and that qualified it. When they smacked it with a hammer a couple mounting areas crumbled.
  16. Apr 29, 2023 at 3:10 PM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    I'd check car-part.com to find a good-condition used OEM wheel from a junkyard in your area.
    I found an identical wheel to my factory wheels for $50. I had it sandblasted and powered coated to prevent any corrosion or anything from occurring in the future. If you do the same, make sure you get a matching size tire if you're 4wd.
  17. Apr 29, 2023 at 8:00 PM
    savagefen
    Jon
    2002 Toyota Tundra
    I did check out car-part.com, awesome site. I ended up ordering a used steel rim/tire from ebay. Thanks everyone.
    scooterprint and Jack McCarthy like this.
  18. Apr 30, 2023 at 10:48 AM
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    Hopefully, I'm getting new tires tomorrow (including a new spare). Since I've never dropped the spare, I figured this would be a good time to practice and also get a look at things down there and spray some lube. I think it looks pretty good.
    I'm glad I did this "test run". It took a minute to figure out what this little adapter piece was for, as the manual didn't mention it.
  19. Apr 30, 2023 at 10:55 AM
    Jack McCarthy
    Bill
    North of Boston
    Time to wire brush that rear proportioning valve. You don’t want those brake line fittings to rust in place.
    shifty` likes this.
  20. Apr 30, 2023 at 10:59 AM
    Solid Snake
    West TN
    2006 AC 4x4 V8
    Good catch. Its now on the to-do list.
  21. Apr 30, 2023 at 11:13 AM
    savagefen
    Jon
    2002 Toyota Tundra
    Yours looks great in comparison.
  22. Apr 30, 2023 at 11:15 AM
    Solid Snake
    West TN
    2006 AC 4x4 V8
    Yeah, but its four years younger and spent most of its life in central Missouri.
  23. Apr 30, 2023 at 11:22 AM
    savagefen
    Jon
    2002 Toyota Tundra
    Yep, that makes a difference :/
  24. May 2, 2023 at 7:52 AM
    This is something I was debating about - whether to get a full-size spare or not. Knowing my luck, by the time I get to it, my wheel manufacturer will discontinue the line.
    I definitely need to replace my tire, this thing is original to the truck. Maybe I'll just paint the spare to color match my new wheels :rofl:
    JasonC. likes this.
  25. May 2, 2023 at 7:35 PM
    NickB_01TRD
    Nick
    KY
    I just got a used tire that matched the size of my current tires and put it on a stock starfish wheel. You could always find a 16 (or 17) inch tire that is very close in size to whatever you are running. Don't recall exactly what your plan is but would be a lot cheaper this way.
  26. May 2, 2023 at 7:36 PM
    I ordered a full size spare because I'm a dumbass :rofl:
