Need a manufacturer and part number for replacement differential cover
Discussion in '1st Gen Tundras (2000-2006)' started by girtlerIII, Apr 3, 2024.
  1. Apr 3, 2024 at 10:39 AM
    girtlerIII
    girtlerIII [OP] New Member
    I have a 2006 Tundra 4X4 Double Cab Limited 4.7 which has developed a leaking rear differential cover. I have been searching all over and can not find a weld on cover to specifically fit my truck. Can any one help me in this matter? My epoxy patch jobs do not hold for more than a few days.
  2. Apr 3, 2024 at 10:45 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
  3. Apr 3, 2024 at 10:53 AM
    NickB_01TRD
    Nick
    KY
    Looks like bolting on may be an option too if you drill and tap for it. Take a look at this whole thread too.
    LINK
    The Black Mamba likes this.
  4. Apr 3, 2024 at 2:44 PM
    Burgmane
    Burgmane New Member
    Apollo Beach, FL
    2005 Limited DC 4WD
    Recently I hit mine aggressively with a wire wheel brush around my two pinholes and used steelstik putty, so far so good with those patches. Getting to bare/clean metal is paramount. Did traditional JB weld in the fall without the sanding/wire wheel and they leaked relatively quickly.
    Not trying to dissuade you from doing the fix for real, I will have to do the same before too long. Have also seen discussion on here that the dorman cover 100% will fit all 2wd and 4wd, @shifty` and others here more well versed than I have said as such.
  5. Apr 3, 2024 at 5:13 PM
    This latter info came to light recently and is my recollection too.
  6. Apr 10, 2024 at 4:25 AM
    girtlerIII
    I would like to thank those who responded to my 'cover' question. I have purchased the suggested Dorman cover and I am waiting for an appointment with my welder to install. So far the external measurements prove it to be a good fit.
    FrenchToasty likes this.
  7. Apr 12, 2024 at 5:40 AM
    girtlerIII
  8. Jun 9, 2024 at 1:47 PM
    Charlie603
    Charlie603 New Member
  9. Sep 8, 2024 at 6:55 AM
    sprink281
    sprink281 New Member
    Bob
    2004 Tundra base model 2wd.
    have same problem, unable to find welder, Chicago area
  10. Sep 8, 2024 at 4:01 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I've seen at least one example (on line) of someone who drilled/tapped holes in the diff housing, and then bolted the Dorman cover on...
  11. Sep 9, 2024 at 12:24 PM
    sprink281
    Bob
    thanks for info, have not found that video yet. i have 2 small leaks , leaves puddle size of golf ball or tennis ball. thinking of using drill and wire brush and sandpaper then jb weld or epoxy.
    w666 likes this.
  12. Sep 9, 2024 at 12:58 PM
    w666
    Maryland
