Need Fuse Help ASAP
Discussion in '3rd Gen Tundras (2022+)' started by ByeF150HelloTundra, Oct 1, 2022.
  1. Oct 1, 2022 at 8:05 AM
    ByeF150HelloTundra
    ByeF150HelloTundra [OP] New Member
    DFW
    2022 Tundra SR5
    Is there a common fuse that controls both the radio and the power outlet above it? Maybe an ECU fuse? Would greatly appreciate any help. Otherwise, gonna have to take the truck into the dealership, which I’m trying to avoid. Thanks!
  2. Oct 1, 2022 at 8:08 AM
    devron11
    devron11 New Member
    Ron
    Denver
  3. Oct 1, 2022 at 8:25 AM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    ColoradoTJ likes this.
  4. Oct 1, 2022 at 9:06 AM
    Were you doing something like mods?
  5. Oct 1, 2022 at 9:08 AM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Yeah, was doing some test fitments for an anytime camera (plugging into the back of the radio)
  6. Oct 1, 2022 at 9:21 AM
    Oh boy. This can get spicy. Let me see if I can get you some help. Stand bye
  7. Oct 1, 2022 at 9:24 AM
    @Jeff_5_7 is very helpful in wiring diagrams and troubleshooting. It's his "thing"...
  8. Oct 1, 2022 at 9:34 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I actually saw this post this morning and was going to come back to it when I was home at my computer.
    2022 right? I haven’t looked at the 3rd Gen wire diagrams that much but I do have them.
    Can you post a pic showing which power outlet you are referring too? I don’t have a 2022 and am not sure exactly what you mean by power outlet above the radio.
    I assume you have the large display radio and it is not coming on anymore at all after experimenting with adding a camera plug in the back?
  9. Oct 1, 2022 at 9:43 AM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    thanks for all the help! Here’s a picture. I actually have the smaller display. The radio unit and power plug seem to be the only two things affected. EC864631-5562-4705-9903-C9398B233B92.jpg
  10. Oct 1, 2022 at 10:00 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I am not seeing a link between the power outlet and the radio.
    The power outlet seems to be on its own single fuse. 15A Power Outlet No.1 in fuse box on the bottom of the body control module.
    Tundrastruck91 and 1lowlife like this.
  11. Oct 1, 2022 at 10:07 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Is the AC control panel dark also. Just looking at your photo, either it has lost power or the key wasn't on.
  12. Oct 1, 2022 at 10:14 AM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Key wasn’t on. AC panel works fine
  13. Oct 1, 2022 at 10:14 AM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Yeah, this is what has me confused. And I changed the fuse but still no power.
    Jeff_5_7[QUOTED] likes this.
  14. Oct 1, 2022 at 10:17 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    That is what I found as well,
    May not be the correct HU, but I'd guess they are similar.
    Perhaps they share a common ground?
    But I couldn't find it.
    Although the power outlet and the Switch & Volume Assembly of this HU seem to share an IE ground point..
  15. Oct 1, 2022 at 10:19 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Does the USB port still have power?
    Check the 5A ECU-ACC fuse. If it is bad, the relay will never close to send power to the power outlet fuse.
    The 5A ECU-ACC fuse also seems to provide power to the radio when the key is turned to Accessory. This is probably the wake up trigger for the radio display.
    1lowlife likes this.
  16. Oct 1, 2022 at 10:28 AM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Yeah, USB still has power. Everything else from what I can tell works perfectly fine.
  17. Oct 1, 2022 at 10:29 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Yes that’s tells me it is most likely the 5A ECU ACC fuse. It is tied to the radio and power outlet. It’s in the same fuse box as the other. Lower right corner in the diagram I posted above
    aeroo777 likes this.
  18. Oct 1, 2022 at 10:35 AM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Will give it a try in about 45 mins when I get back home. Thanks for taking the time to help me out!
  19. Oct 1, 2022 at 10:41 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If the radio doesn't work it's time to trade it in.
  20. Oct 1, 2022 at 10:46 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Lemon law..:eek2::thumbsup:
  21. Oct 1, 2022 at 10:53 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    100%
    ColoradoTJ and 1lowlife[QUOTED] like this.
  22. Oct 1, 2022 at 11:12 AM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    i love this forum. Thanks so much @Jeff_5_7 @ColoradoTJ @1lowlife
    SC4333, ryanwgregg, X42069 and 7 others like this.
  23. Oct 3, 2022 at 8:22 AM
    nodak67
    nodak67 New Member
    JR
    props to @Jeff_5_7
    great support as always :)
  24. Feb 12, 2023 at 10:32 AM
    Hawkeye2015
    Hawkeye2015 New Member
    2022 Lunar Rock Tundra TRD
    In the engine compartment on the driver's side of a 2022 tundra is one of the fuse boxes. In that box there are two ECU-IGP fuse locations each holding a 5A fuse. They are numbered 3 & 4. Obviously, they are controlled by the ignition, but what are they actually for? I want to use an add-a-circuit to control the switch in a relay using one of these fuse locations. One of these would be sufficient to accomplish the task, but I am not certain whether I would be interfering with something I should leave alone. Please advise. Thank you.
  25. Feb 12, 2023 at 10:39 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Hell of a thread necro… I’d have probably started a new post.
    You’re best served pulling down the wiring diagrams from the thread linked above and chasing out those particular fuses through the diagrams or fuse list to see what circuits they are part of.
    That all said, if you are using proper fuse taps and orient them correctly (so the load and source sides are aligned correctly with the factory routing), then you’re not impacting the factory circuit at all by installing a tap. Put the factory rated fuse in the lower position and your add-a-circuit fuse in the upper position and you are GTG.
  26. Feb 12, 2023 at 10:48 AM
    Hawkeye2015
    Thank you. Found the information I was looking for in the fuse definition list link above. No. 3 is involved in the Hybrid System and the Stop and Start system.
  27. Feb 13, 2023 at 10:29 AM
    RickyBobbysTundra
    RickyBobbysTundra New Member
    Phoenix
    2023 Solar Octane TRD Pro
    Reading through this just so I can better understand my own truck. I would never have been able to troubleshoot this on my own, thanks to all involved. Lurkers like us get to learn a little something in the background
  28. May 1, 2023 at 1:17 PM
    CBRN_Monkey
    CBRN_Monkey New Member
    Many thanks to Jeff 5_7! Someone give this guy a medal! My story was similar; adding usb-c ports and then all of a sudden, no radio. I checked fuses, but not the 5A ECU ACC. I was about to make an appointment with Toyota and decided to check here one more time. Thank God!
  29. Jul 29, 2024 at 10:45 AM
    larlap
    larlap New Member
    Larry
    Illinois
    2008 Toyota Turnda
    Duplicate Post. If you've seen it,, please ignore...
    Hey.... I'm working on my 2022 1794... Somehow one of the fusable links blew the feed to my 7 way trailer wiring. I tried taking the fuse box apart...It appears to be above my paygrade...HELP....
