Need help with creating a USB-C power source behind the dash
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shadowfax1, Sep 26, 2023.
  1. Sep 26, 2023 at 11:27 AM
    Shadowfax1
    Shadowfax1 [OP] New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    I recently bought a Rago dash plate and some mounts. I intend to run permanent (hard-wired) charging wires (four USB-C PD) down through the dash. I want them to be wired up from there -- behind the dash -- rather than coming back out the dash to use an exposed power port.
    I am looking for enough watts of power to simultaneously fast-charge:
    2 large phones (one fast-charges at 20 watts and the other at 29)
    1 large tablet (fast-charges at 45 watts)
    1 large high-end laptop (fast-charges at 140-watts)
    I would need all to be able to charge while the engine is off. If I have to or should make that enabled by use of a switch, that's okay.
    So what is the easiest way of doing this?
    Should I tap into an existing power source somewhere?
    Or would it be easier and safer to mount a power inverter somewhere behind the dash or in the engine compartment and wire it directly to the battery? (I do have a Krieger 1100 watt 12V inverter with two 110V AC outlets on hand that I bought a while back but never did anything with). What mounting locations would you suggest?
  2. Sep 27, 2023 at 6:28 AM
    CaptRatBoy
    CaptRatBoy New Member
    Somewhere around 2500' Western Blue Ridge, NC
    Capeable, extensively modified, 2016, Limited, 4 x4 Tundra Off Road, 3td. one
    I'd start at the source. Like where's the power to run what all going to come from. Most likely you've the 180 watt alternator on board since it's 1794 with the Off Road package. It's not like you're running a welder or starting a gen set. Total up the total wattage and start from there. Opp's hit wrong key... Sorry! Anyways figure in a reserve capacity say 33% and use that as your additional load. Thankfully not to likely all equipment will be running at one time. I'd draw a schematic and take it from there. That will give you a clue as to what you really need along with the inverter.
    bulldog93 likes this.
  3. Sep 27, 2023 at 6:58 AM
    You’ll need a DC to AC power inverter for the laptop. Laptops use an AC to DC power supply to charge their 19v batteries. So the inverter will be required if the laptop is to share the dash power supply. If you want to plug the laptop in elsewhere, you can run 12v power supply to the dash mount area to charge all of the mobiles. It will be tidier they’re not having to have all the AC to DC converters for all of the mobiles. You could just have the USB C outlets for the mobile cables. Then mount the inverter anywhere that’s convenient and run the 120v outlet to somewhere inconspicuous for the laptop mount.
    Shadowfax1[OP] and bulldog93 like this.
  4. Sep 27, 2023 at 7:08 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    You would need a 12 to 10 GA positive wire to run all this load. 12 GA would be with no reserve. If I had absolutely to do it, I'd run a separate cable from the battery. There's a rubber nipple in the firewall that you can cut off and run your wire safely to the cabin. See a yellow cable here:
    You would also need a similar GA negative wire to the closest cabin ground point.
  5. Sep 27, 2023 at 8:34 AM
    Shadowfax1
    The laptop is charged by USB-C cord with an AC adapter on the end. The inverter has two AC ports on it. So if I use the inverter, why do I need a converter? Or am I not following you?
  6. Sep 27, 2023 at 8:35 AM
    The laptop power supply is the AC to DC converter.
  7. Sep 27, 2023 at 8:35 AM
    Shadowfax1
    Thanks. I've already gone through that nipple for my FRAC, so it should be pretty straight forward to feed through it again.
  8. Sep 27, 2023 at 8:55 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    There's a second one on passenger side, too.
