Need help with this door issue
Discussion in '1st Gen Tundras (2000-2006)' started by Larry999, Oct 27, 2023.
  1. Oct 27, 2023 at 1:33 PM
    Larry999
    Larry999 [OP] New Member
    2001 Toyota Tundra Regular cab long bed
    None totally stock
    I have the 2001 Toyota tundra regular cab long bed base model the driver's door latch has failed and the door is stuck in the closed position. Does anyone hear know of a way that I can get the door to open so I can replace the door latch assembly. The door panel I have managed to pull away from the door to gain some access to the inside of the door. I was able to remove the interior door handle and even using vice grips to pull on the inside latch cable no matter how hard I pull the door will not unlatch. The door is properly aligned to the cab if that helps. My truck has manual windows and the access I have to the inside of the door is from the top of the door panel pulled away with the window rolled down.
    This happened to me last week and I had to resort to you cutting open the outer door skin to gain access to the latch. I was able to locate a used door with latch assembly that latch lasted 3 days and it broke. I really don't want to have to sacrifice another door by cutting open the door skin. I am in Phoenix Arizona if I have to sacrifice another door next nearest door available to me is located in central California.
    Any assistance would be greatly appreciated thank you.
  2. Oct 27, 2023 at 1:39 PM
    Fieldnstreamer
    Fieldnstreamer Cold Researcher
    Sam
    East Tn
    2006 DC Limited 4x4 Phantom Gray Pearl, 2000 AC Limited 4x4 (R.I.P.)
    Brute force bumpers/sliders, OME 3" lift, SCS ray 10 wheels, ARB onboard air compressor, GX460 big brake upgrade, JBA UCA's, siberian Bushings, RCV high clearance axles, 333 Billet steering rack clamp, TMR customs 10" front limit straps, 1" diff drop, agility customs dual battery setup/battery isolater with heavy duty wiring/ grounding cable upgrade, F-er battery tray, HFW spindle gussets, remote oil catch can,
    You might get lucky and find someone with some locksmithing tools to be able to Jimmy the door open. I don't know about where you live but here I can get someone to come pop my door open for about 50 bucks. Cheaper than buying a new door :fingerscrossed:
  3. Oct 27, 2023 at 2:15 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
  4. Oct 27, 2023 at 2:52 PM
    Larry999
    None totally stock
    Thank you for the replies I did read through those three threads all three of those threads for trucks that were access cabs. Where you go through the rear door on the driver side and grind off the bolts to remove the striker to get the doors open I don't have that option as my truck is a regular cab. I guess it looks like I either have to decide to the sacrifice the door or cut open the cab corner to get to the striker bolts. I can't remove the window track because I cannot get to the bolt on the bottom of the window track as that is in the door jamb area which you can't access with the door closed.
    rouxster70 likes this.
  5. Oct 27, 2023 at 3:16 PM
    Fieldnstreamer
    Sam
    East Tn
    I'm honestly not very familiar with the single cabs or if you're single cab has any of the same points that I'm pointing to in the pictures as my DC but have you tried taking the screw out of the door latch that I'm pointing at or taking a trim remover and popping up the window control buttons or possibly accessing the hole under the armrest that I'm pointing to or the light that can probably be popped out fairly easily or maybe even the speaker cover if you have the same style speaker cover I have. My 2000 model has a different style speaker cover so you probably have that style but this style I have looks like it could be popped out with one of those plastic trim tools. They all look like potential access points that might not be optimal but might possibly have something you could utilize. I would just look for any trim or caps that could be popped off to access any screws at all make things a little more accessible or loose.
    16984444417554782448268048024858.jpg 16984445633765873280459965840560.jpg 16984447185095318498916371746560.jpg
  6. Oct 27, 2023 at 4:43 PM
    Larry999
    None totally stock
    Mine is a regular cab base model. Manual windows locks and mirrors. I have removed the inside window crank and interior door handle. My door panel I have loosened along the top of the door but I can't get to the screw that is between the door panel and dash to fully remove the door panel. Your door panel doesn't look like mine, mine has a door pocket that runs nearly the entire length of the door panel along the bottom. Mine also has no switches that area is where my window crank is.
    On my door there are 2 fasteners that hold in the rear window track, one bolt near the top that I have removed and the other is a nut located in the door jamb area near the bottom below the door latch. That I can't get to due to the door not opening. I pulled on the interior door release cable hard enough that it snapped the cable. I am going to try to bust up the latch with a long pry bar and a hammer. I don't know what else to do without cutting either the door or cab corner.i at least have spare door handles and window glass in case mine breaks lol.
  7. Oct 27, 2023 at 4:48 PM
    Fieldnstreamer
    Sam
    East Tn
    Lol well yes it sounds like your at a dead end road. If cutting stuff is your last resort, at least cut on things that can easily and relatively affordably be replaced. Keep us updated with your results!
  8. Oct 27, 2023 at 5:08 PM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Somebody on here, I seem to remember paid a body shop to open his door, and then he or someone replaced the latch. I slid through the passenger side when mine started to get shitty as to avoid this issue, I've since replaced the latch with an OEM part. Good luck. My fuel door wouldn't open this morning at the gas station. I had to go back home and mess with that lock, luckily I've got it opening again. I'm glad I was close to home when it quit turning.
  9. Oct 27, 2023 at 6:42 PM
    Call a locksmith to jimmy the door.
  10. Oct 27, 2023 at 9:45 PM
    Larry999
    None totally stock
    I had a locksmith come out and after an hour of trying he told me he couldn't get it open. I felt bad I could see his frustration.
    I decided to go full caveman on it so to speak. I took a hammer to the outer door handle to break it up. Then using a combo of a crowbar and a long pry bar with the hammer I just smashed the latch until it finally broke apart and and got the door open. I destroyed the outer door handle and broke the window glass but at least the danged door is open.
    I have a new Toyota latch ordered and I have a spare handle and glass already from the original door. I thank you all for the help. If all else fails beat it with a hammer lol.
    rouxster70 and JasonC. like this.
  11. Oct 27, 2023 at 10:41 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    when you reassemble it, check the window run isnt hitting anything. my door got stuck shut because the window run came loose inside the door and was bound up against the latch mechanism
    shifty` likes this.
  12. Oct 28, 2023 at 12:38 AM
    Larry999
    None totally stock
    I didn't think about that thank you I will check that. I plan on also using the window track pieces out of the original door that I had to cut just is case my caveman method did damage to them.
    I just hope this fixes it as the truck otherwise is perfect for my contractor work. Yes it may have near 400k miles on the 3.4 V6 5 speed combo but it runs like new still. Has been very reliable over the last 12 years other than this nightmare.
    rouxster70 and TheKleen like this.
  13. Oct 28, 2023 at 6:01 AM
    TheKleen
    TheKleen New Member
    Kyle
    Gulf Coast
    2002 SR5 AC 4.7L 2WD LSD
    My handle takes a couple of tries every now and then, usually works fine. Did you experience this symptom before it gave out? I might try and squirt some grease up in the mechanism.
  14. Oct 28, 2023 at 9:52 AM
    Fieldnstreamer
    Sam
    East Tn
    Make sure to only use OEM parts on stuff like this because I've dealt with the cheap parts store china brand issue before. Never again on anything that hoses you up bad if it fails.
    chunk likes this.
  15. Oct 29, 2023 at 8:40 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    White lithium or silicone-based.
  16. Oct 29, 2023 at 3:19 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
