Need proper wheels for Load Range E tires, like 3500+ load rating
Discussion in '3rd Gen Tundras (2022+)' started by PaintDoctorMD, Dec 19, 2023.
  1. Dec 19, 2023 at 11:39 AM
    PaintDoctorMD
    PaintDoctorMD [OP] New Member
    2022 SR5 DC
    Cannot locate a single website where I can search for wheels by load rating. Ridiculous. Anyone know of some wheels that will fit our new lug pattern with good load ratings? Please & thank you
  2. Dec 19, 2023 at 11:41 AM
    Breathing Borla
    Northern Illinois
    what do you need higher load rating for?
    the OEM wheels will carry anything the tundra is rated for.
    but if you want to look for something else, there is a MASSIVE wheels and tires thread to search in
    DFS likes this.
  3. Dec 19, 2023 at 11:44 AM
    DFS
    DFS New Member
    2022 Capstone Tundra
    Yeah why do you need 3500+ rating? That's HD truck range that typically doesn't come in 6x139.7 pattern from what I've seen.
  4. Dec 19, 2023 at 11:52 AM
    PaintDoctorMD
    2022 SR5 DC
  5. Dec 19, 2023 at 12:04 PM
    nodak67
    nodak67 New Member
    JR
    could try custom offsets website, they list load rating per wheel but you would have to look at every wheel since they dont have a search by load rating.
    PaintDoctorMD[OP] likes this.
  6. Dec 19, 2023 at 2:56 PM
    Markysharky
    Markysharky New Member
    Even standard 265/70r18 116t load index (2756 lbs per tire at 50 psi) rated tires on the SR5 carry more than the GVWR. If you’re exceeding those values or near them on a regular basis I’d get a 3/4 or bigger truck. Albeit load E tires will tend to wear a little better and offer better puncture resistance. For a 1/2 ton the load carrying isn’t much of an issue with larger tires late model trucks come with from the factory.
    Mattedfred likes this.
  7. Dec 19, 2023 at 3:07 PM
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    You would need to move to a 8 lug wheel design to have a true Load Range E load rating for the wheel.
    Most quality aftermarket designs (flow formed or forged) are really only going to exceed the factory wheel load rating by 100-500lbs at most.
  8. Dec 19, 2023 at 3:10 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Here’s a good source for wheels with a higher load rating so you can haul more weight without worrying:
    https://www.gmc.com/trucks/sierra/2500hd-3500hd
    Conveniently the higher load rated wheels also include load range E tires already installed, along with beefier axles, brakes, frame, transmission, and engine.
    @Eurodriver might find this useful as well, he’s been on a similar quest.
    DFS, centex, Eurodriver and 2 others like this.
  9. Dec 19, 2023 at 4:35 PM
    Look like you found them. Looking for more options than that one? Rear axle is rated for like 4000#, so anything with 2000-2500# rating or more will meet the axle rating. Most I see don't readily list the weight rating, only some sites do.
  10. Dec 20, 2023 at 1:18 AM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    lol.
    Beadlocks aren't road legal, and you really don't want 40 lb wheels with -44 mm offset. They are in the correct bolt pattern, though!
    Why do you think you need such a high load rating for your wheels?
  11. Dec 20, 2023 at 3:04 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    You asked the internet a question and everyone is obligated to simply answer your question? No curiosity, no inquiry, no conversation?
    Your parents failed.
    Dfrink, teab, DFS and 4 others like this.
  12. Dec 20, 2023 at 5:33 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    A 6 lug wheel is made for a half ton truck. The load rating of the wheel is designed for a half ton application. There is nothing you should be, or even could do with your half ton truck that would require a 3200 lb per wheel rating. Thats what 8 lug wheels are for. Aka 3/4 and 1 ton trucks. If a wheel has a 2500 lb rating, that is per corner. If your truck has a GVWR of 7,000 lbs, then a 2500 lb rated wheel is more than your truck needs.
    teab and Mattedfred like this.
  13. Dec 20, 2023 at 7:14 AM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    Perhaps it's needed for Curb Hopping Mall Crawler so the wheel won't get bent as easy?
    teab likes this.
  14. Dec 20, 2023 at 7:35 AM
    Breathing Borla
    Northern Illinois
    I tried asking him that in the first post and got told it was none of my business, lol.
    we all know why.....
    teab likes this.
  15. Dec 20, 2023 at 7:44 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Another thread started by an OP with 3 messages total (2 being this thread for @PaintDoctorMD), where OP doesn't want to be questioned to why they are looking for what they are looking for, just give me the answer and I don't want to hear any of the reasons why what I'm looking for doesn't exist...guessing that's the last we'll hear from the OP.
    king.cong.1119 and Mattedfred like this.
  16. Dec 20, 2023 at 8:19 AM
    king.cong.1119
    king.cong.1119 New Member
    I am sure there is a reason, thought really hard and long for it, I believe it is likely due to a designed weakness, like someone else pointed out, it doesn't make sense to have wheels exceeding axle weight limit, so I am taking a wild guess, it's better to break a wheel and not axle due to carrying more weight.
    I do find one from icon alloy for my 2nd gen tundra, which are also what I used before, they look and perform great, unfortunately not for the 3rd gen.
