Need thoughts on Toytec vs 6112
Discussion in 'Suspension' started by jaflynn738, Feb 12, 2022.
  1. Feb 12, 2022 at 2:27 PM
    jaflynn738
    jaflynn738 [OP] New Member
    So like everyone else, I have been waiting to lift my tundra 3 inches since summer. I’ve been waiting for the release of 6112 from being back ordered and know that Toytec is available.
    Whats everyone’s thought on Toytec vs the 6112? For the ones that went Toytec, what’s your thoughts and reviews ?
    Thanks
  2. Feb 12, 2022 at 3:53 PM
    Clrems77
    Clrems77 New Member
    Tag. In this same boat. Thanks for posting.
    jaflynn738[OP] likes this.
  3. Feb 15, 2022 at 11:42 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Toytec alumas will be better than 6112s. Good info, pics, reviews for those and many other options in the suspension forum here and use search in upper right to more easily find that you are looking for.
    BlueRibbon4x4 and Black Wolf like this.
  4. Feb 15, 2022 at 11:44 AM
    THIS^^^^ Aluma's
  5. Feb 16, 2022 at 11:51 AM
    tgsfire
    tgsfire New Member
    2014 Toyota Tundra
    I'm in the same boat, waiting on the 6112's to come in stock. But I'm wanting to piggy back off of the OP from @jaflynn738, and ask a follow up question.
    How do the Toytec 2.0 Aluma Series Rear shocks compare to the 5160's. Not sure if I'm just wanting to be brand loyal or something, but feels odd to have Toytec's on front and Bilstein's on rear.
    I have used the "box in the upper right" and haven't found much for comparing Toytecs vs 5160's.
    Stock issues are having a lot of us rethink our future set up's.
  6. Feb 16, 2022 at 6:08 PM
    jaflynn738
    Thank you all for the responses, I'm defiantly torn.
  7. Feb 16, 2022 at 6:32 PM
    Tundra1D6
    What about the eibach setup?
  8. Feb 19, 2022 at 5:37 PM
    jaflynn738
    Had given it much thought, but I have been looking at those. Have also looked at 5100's,Eibach and also EMU. Any thoughts on those ? It would be used 99% on road and not off road.
    Thanks again
  9. Feb 19, 2022 at 5:40 PM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    I installed the Eibach front coilovers and rears shocks on my truck and am really pleased with the ride. I was considering 6112s/5100s but the wait time wasnt worth it to me. Couldnt be happier with the choice i made.
    Skew12 likes this.
  10. Feb 19, 2022 at 6:04 PM
    jaflynn738
    Thank you for that, Which ones did you go with and what settings?
  11. Feb 19, 2022 at 6:11 PM
    Blang805
    Blang805 New Member
    Build in Signature
    I went with the Stage 1 Kit up front set at 2" and then no rear lift. Just replaced the shocks.
  12. Feb 19, 2022 at 6:17 PM
    jaflynn738
    Thank you again for that, do you mind sending picture of your truck so I could compare. What size tires and wheels did you go with?
  13. Feb 19, 2022 at 6:21 PM
    Blang805
    Blang805 New Member
    Build in Signature
    I went with 295/70/18s on Toyota OEM +60mm wheels and only have a very slight rub on the passenger side sway bar at full lock. I would consider getting one of these shims to help with the typical "driver side lean" like I did.
  14. Feb 19, 2022 at 6:24 PM
    jaflynn738
    thank you for that, that looks great. I like it a lot. So those tires are 34.2 tire size?
  15. Feb 19, 2022 at 6:26 PM
    Blang805
    Blang805 New Member
    Build in Signature
    Thanks.
    They're something like that. I just took a look at the TRD Pro wheel and tire threads and people didnt have any issues with the factory 2" lift they have from the dealer with OEM wheels in that tire size. I would not go any wider in tire size because it will rub on the upper control arm since there's maybe a finger width left of room.
  16. Feb 19, 2022 at 6:34 PM
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    Love my OME nitrochargers. great ride on and off road and multiple accounts of them lasting 100k miles.
    Skew12 likes this.
  17. Feb 21, 2022 at 12:25 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    In what sense?
  18. Feb 22, 2022 at 9:15 AM
    frichco228
    Better ride. Lots of info and reviews on this site to support that statement.
  19. Feb 22, 2022 at 9:37 AM
    rruff
    rruff New Member
    I'm not seeing that at all. I can believe Toytecs are a better choice if you want a smooth street ride, but that isn't a universal "good" if your priority is better handling or offroad performance. In capability the Toytecs are like the stock Bilsteins (2" monotube), only with different valving and adjustable preload.
    6112 fronts are bigger and the rears have an external reservoir, which are good for avoiding overheating and fade when you are using them hard. They also have higher damping and digressive damping which increases small bump harshness, but improves handling and offroad performance.
    Sierradevil likes this.
  20. Feb 22, 2022 at 9:41 AM
    rruff
    rruff New Member
    Just so you know... if you lift the front ~2" you'll be level... and you won't need anything else. If you lift 3" you need UCAs, your CV joints will wear out sooner, and you need to lift the rear.
    A 2" lift is more than enough for 37s.
  21. Feb 22, 2022 at 5:33 PM
    jaflynn738
    Yeah thank you for that. I was leaning on the old man Emu 612's which is at 3 inches, but I'm up in the air again since I won't be using it much for off-road. I will say that my stock Bilstein rides nice and imagine the 6112 would be the same. I just hate to wait till May before being able to get the 6112.
    rruff[QUOTED] likes this.
  22. Feb 22, 2022 at 6:47 PM
    rruff
    rruff New Member
    Probably not the best choice for street. I think you'll be fine with Toytec or Eibach for street use. I'm not sure what Toytec says, but you can dial in the ride height of the Eibachs with them still on the truck, which is very nice.
  23. Feb 24, 2022 at 7:46 AM
    Yotatrucks7
    Yotatrucks7 New Member
    2017 DC Tundra
    I’d call around on the 6112/5160’s. This past fall they were seemingly on back order everywhere but if you call different suppliers sometimes they can give an accurate eta. I was set to go with Toytec when I found a supplier in CA that said they were getting a new shipment in that week. Ordered them and they shipped within two days even though the site still said “back ordered”. Just a thought if the bilstein is really what you want.
  24. Feb 24, 2022 at 6:29 PM
    jaflynn738
    Thank you for that, what notched did you go with the 6112 and how did you like to ride? Also what tire size did you go with?
  25. Feb 24, 2022 at 7:14 PM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    Also, if you go with the 5160s in the rear they only extend an extra 2 inches.
  26. Feb 24, 2022 at 8:55 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    My 6112s are stiff as f*ck.
    Rear 5160s ride the same as the 5100s I had on before them.
    Chucksmith07 and rruff like this.
  27. Feb 25, 2022 at 7:14 AM
    jaflynn738
    You have them on the 4th setting?
  28. Feb 25, 2022 at 7:29 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    The second setting from the bottom..
  29. Feb 25, 2022 at 7:38 AM
    jaflynn738
    Damn, so you would go different route if you were looking to install again?
  30. Feb 25, 2022 at 8:39 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    From what I've read I'd go with the Toytecs..
    frichco228 likes this.
