Need to replace brake rotors and pads!
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by ackthresher, Jun 13, 2024.
  1. Jun 13, 2024 at 2:38 AM
    ackthresher
    ackthresher [OP] New Member
    Jamie
    2017 cement crew max tundra pro
    2017 tundra crewmax,Needing to replace rotors and pads,was thinking cryo slotted.i would like an upgrade do to towing a 22 ft boat .thank you.
  2. Jun 13, 2024 at 5:08 AM
    StopTech Sport cryo treated and slotted only. Do not get slotted and drilled.
    QuikreteTundra likes this.
  3. Jun 13, 2024 at 4:02 PM
    ackthresher
    Jamie
    Thank you!
  4. Jun 13, 2024 at 4:07 PM
    I looked at several places online today. Tire Rack is the cheapest.
  5. Jun 13, 2024 at 5:11 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Agree with @Tundra234 on rotors, got cryo slotted stoptech from tirerack. Add in akebono performance pads, very low dust and good bite.
    Tundra234 likes this.
  6. Jun 13, 2024 at 5:18 PM
    blenton
    blenton New Member
    Akebono is/was an OE supplier for Toyota brake pads. I don't know about Tundra pads, but from everything I could find, they were nearly identical the OE pads for our old Avalon. Price, appearance, finish, even part numbers were near identical. I ended up with the Akebono's and they worked great.
  7. Jun 13, 2024 at 5:59 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    My stock rotors warped at about 25k miles due to heat then water. I put cryo slotted rotors on with Ebc yellow pads, WOW, big difference. Yellow pads make lots of dust though.
    Cryo rotors haven’t warped in same conditions as stock.
  8. Jun 13, 2024 at 6:06 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Cryo are gonna be hard to find. I got stop tech slotted from tire rack but not cryo. Installed. No ragrats.
  9. Jun 13, 2024 at 6:10 PM
    Correct. 3 out of the 4 are August delivery.
  10. Jun 14, 2024 at 2:16 AM
    ackthresher
    Jamie
    Great !thanks for all the feedback.
  11. Jun 14, 2024 at 10:46 AM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    I finally pieced together a set of stop tech cryo slotted. Took about 6-7 months. 3 of 4 are on tire rack now. If that is what you want and you can wait get those 3 now and get in the back order for the others. Best case price I found was RCA garage. I just cancelled my back order there.
    blenton likes this.
  12. Jun 15, 2024 at 12:04 PM
    blenton
    blenton New Member
    I appreciate the info.
  13. Jun 16, 2024 at 7:41 AM
    ToyotaToolbox
    ToyotaToolbox Oso Blanco
    Franklin, TN United States
    2016 Tundra TRD Pro
    LEER Topper | Rhino Rack | Cargo Glide| 305/65-R18 K02's | 1.5" ToyTec rear lift | 2019 OEM LED Headlights | Full LED lighting upgrade | Expedition-One all steel rear bumper
    I'm about to do the same thing. Been considering the Big Brake Kit, will that setup work on the Pro?
  14. Jun 22, 2024 at 8:17 PM
    Looking online, RCA has some not so favorable reviews, to include the BBB.
    ToyotaToolbox likes this.
  15. Jul 18, 2024 at 9:20 PM
    blenton
    blenton New Member
  16. Aug 25, 2024 at 9:33 AM
    VUDUBLU
    VUDUBLU New Member
    David
    2019 TRD PRO Tundra
    Ready lift 2 inch lift with 295’s
    Another notch for stoptech rotors. I have slotted ones as well
  17. Sep 10, 2024 at 10:27 AM
    ssnyt
    ssnyt New Member
    2019 Tundra Pro
    After a ton of research, I too bought StopTech Cryo Sport slotted rotors from buybrakes.com for $218 per rotor. Paired those with the NRS Premium Galvanized pads. Got the stainless lines to go with it from SDHQ.
  18. Sep 10, 2024 at 10:45 AM
    Are the Cryos back in stock?
  19. Sep 16, 2024 at 8:04 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Those SS brake lines will be real nice.
  20. Sep 26, 2024 at 3:46 PM
    ssnyt
    ssnyt New Member
    2019 Tundra Pro
    they were when i called, really good guy and he even gave me a good discount on the brake pads and rotor combo.
  21. Sep 26, 2024 at 3:48 PM
    ssnyt
    ssnyt New Member
    2019 Tundra Pro
    i was hemming and hawing on those... stoptech had their stainless set on sale for a lot less than the price of the SDHQ ones. i think i paid $250 or so for the SDHQ, the stoptech's were $77.
  22. Sep 26, 2024 at 3:57 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Yeah same, I think I may have seen those too, but it was after I pulled the trigger on the SDHQ kit. The stopping power between OE line and the actual SS line is substantial. Especially when you know it won’t flex the line under pressure/heat.
  23. Sep 26, 2024 at 4:04 PM
    ssnyt
    ssnyt New Member
    2019 Tundra Pro
    yeah, the reason i ended up going with the sdhq was due to the extended lines since my truck is lifted over 2 inches over stock. i wanted to make sure i didnt need to exchange anything if i bought the stoptechs.
    pvn.beluga[QUOTED] likes this.
