New 2001 Sequoia owner
Discussion in 'New Member Introductions' started by Vespagirl, Feb 9, 2025.
  1. Feb 9, 2025 at 7:42 PM
    Vespagirl
    Vespagirl [OP] New Member
    2001 Sequoia Limited
    Hiya, thanks for adding me to the forum.
    New member from the Okanagan, British Columbia.
    Purchased this vehicle in December to transport our two giant breed dogs around. (Photo taken the same day - it needed a good clean!). I am absolutely loving it.
    It’s a bit of a project car. 26OK km. So far, we’ve done the timing belt, water pump, brakes including calipers, brake lines (there was a leak that blew), recovered driver’s seat, new radio. Frame is rusty AF, but seems solid - will tackle in the Spring time (will clean/grind off the rust and coat with paint/rustproofing - hoping there aren’t any really bad bits) Sway bar mount had rusted and broken, so husband fashioned a new mount out of a scrap of metal and bolted to the frame for the interim.
    Lower ball joints and rear coil are on their way. Will be replacing the instrument lights etc (“D” is burnt out). You Tube has been a treasure of information on fixing stuff.
    Any suggestions on what to tackle next for preventative measures / common issues?
    Where are you all from? Tell me about your “tree” and what you love, what has been a headache?
    Any must have accessories? I love the “Twistep” for loading my dogs in the back.
    Lifer likes this.
  2. Feb 9, 2025 at 7:45 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Welcome, make sure you use OEM lower ball joints
    Vespagirl[OP] likes this.
  3. Feb 9, 2025 at 8:14 PM
    Vespagirl
    Thank you! YES - OEM ball joints ordered - they’re on their way!
    FrenchToasty likes this.
  4. Feb 9, 2025 at 8:27 PM
    imgreenlantern2
    imgreenlantern2 New Member
    Snake Plissken
    Central Texas
    2021 Tundra TRD Pro Double-Cab
    285/70/18 Nitto Ridge Grapplers. RCI rock sliders Leer Tonneau Cover NSV Hood Mounted Lightbar. Suspension air bags for better towing.
    Hell, I would OEM everything on that generation Sequoia. They are built like tanks and aftermarket I don't think can touch that quality.
  5. Feb 9, 2025 at 8:28 PM
    Vespagirl
    Great advice! Will do!
  6. Feb 9, 2025 at 8:44 PM
    NWPirate
    Zach
    WA
    Welcome from WA! Not too far south of you guys :D
    Good Sequoia info and my old 1st gen here in this thread.
    https://www.tundras.com/threads/what-have-you-done-to-your-1st-gen-sequoia-today.102359/
    Vespagirl[QUOTED][OP] likes this.
  7. Feb 9, 2025 at 8:57 PM
    Vespagirl
    Helpful - thank you. And yes - perfect dog hauler!
    NWPirate likes this.
  8. Feb 9, 2025 at 9:00 PM
    Welcome from NY.
  9. Feb 9, 2025 at 9:04 PM
    NWPirate
    Zach
    WA
    No problem!
    A little tip for a beginner- hit the "quote" and it'll copy and notify the person you're quoting. :thumbsup:
  10. Feb 9, 2025 at 9:05 PM
    Vespagirl
    Helpful - thank you!
    Got it!
    NWPirate[QUOTED] likes this.
  11. Feb 9, 2025 at 9:06 PM
    NWPirate
    Zach
    WA
    Nice! :fistbump:
  12. Feb 10, 2025 at 9:09 AM
    Les Robertson
    Les Robertson New Member
    Les
    2002 Toyota Tundra Limited short bed space cab
    O.E. paint is dark green and silver below side molding. ADDED SECOND OIL COOLER FOR FRANSMISSION FLUID
  13. Feb 10, 2025 at 9:12 AM
    Les Robertson
    Les
    Reply to what?
  14. Feb 12, 2025 at 3:49 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  15. Feb 16, 2025 at 2:25 AM
    Tacoma-Tundra
    Tacoma-Tundra New Member
    Tony
    06 Tundra SR5 LTD CC 4.7 V8 AT 2WD
    Welcome from NC :hattip:
