New battery and alternator, truck still won't stert
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sharla001, Nov 28, 2024.
  1. Nov 28, 2024 at 2:20 PM
    Sharla001
    Sharla001 [OP] New Member
    Tony
    2014 Thunder
    None
    Hello all!
    2014 TUNDR TRO!
    So my truck wouldn’t start was convinced it was the battery because I had just replaced the alternator. Got a new battery got it all hooked up and still nothing. The dash, cabin, head lights and radio all will come on but just won’t crank up. Any suggestions/ ideas?
    I did wreck it a couple of months back, was thinking maybe when they put it back together they might have pinched something. Maybe a new starter? I don’t know I am stuck and don’t know how to figure this out.
  2. Nov 28, 2024 at 2:23 PM
    Fobroader
    Fobroader New Member
    Alberta
    2020 Platinum
    Easiest thing, does your truck recognize the key?? Does the security light flash??
  3. Nov 28, 2024 at 2:28 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Check the sterter.
  4. Nov 28, 2024 at 2:34 PM
    Fobroader
    Alberta
    2020 Platinum
    hagrid[QUOTED] likes this.
  5. Nov 28, 2024 at 2:56 PM
    Retired...finally
    :devil:
  6. Nov 28, 2024 at 3:06 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Yup ^^^. Do you have a spare key AND FOB? If you do try it. MUST have the spare FOB for this test/check.
  7. Nov 28, 2024 at 3:45 PM
    JohnWhicker
    JohnWhicker New Member
    LOL tell ye what, that sterter is semthing else
  8. Nov 28, 2024 at 4:12 PM
    Sharla001
    Tony
    2014 Thunder
    None
    Thank you !! I will try the spare key when I get
    Home. And YESSSSS I have heard the starter is a BEAUT!!!
    hagrid likes this.
  9. Nov 28, 2024 at 4:21 PM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    I would check the starter relay for continuity, etc. OEM part # is 28300-0A011. There are also 2 starting system fuses I think. I would check those first. One is 7.5 amps and the other is 30 amps. Numbers 13 and 40 I think maybe. These are all in the engine bay fuse block, not the one inside under the instrument panel.
  10. Nov 28, 2024 at 5:29 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Your alternator could be crap also. Don't rule it out just cause it's new.
    My .02 / experience talking.
    HulkSmurf14 likes this.
  11. Nov 28, 2024 at 5:30 PM
    Sharla001
    Tony
    2014 Thunder
    None
    The key didn’t work, still won’t crank
  12. Nov 28, 2024 at 5:36 PM
    1UP
    1UP Truck Gang
    I dont have a good answer. Check the voltage of the battery. Try to jump it. If the jump works its a voltage issue. Either your draining the battery through a short or lack of charging via alternator. Link below is a good source for your electronic diagnosis.
    https://www.tundras.com/threads/ultimate-tundra-wiring-diagrams-collection.81448/
  13. Nov 28, 2024 at 6:05 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Make sure to also take a good look at all of the engine and battery grounds. A loose or corroded ground can cause enough voltage drop to prevent the truck from cranking
    Tundra family likes this.
  14. Nov 29, 2024 at 3:44 PM
    Scratch73
    Scratch73 New Member
    2017 Midnight Platinum Tundra
    So will it try to turn over? I had a similar issue going on but it would do the "long start". Last week it left me stranded at work, i took it to my mechanic and he tested the alcohol percentage and it was 68. It should be around 12. They reset, reprogrammed or just simply cleared it idk but now it's back to perfect.
  15. Nov 29, 2024 at 4:13 PM
    Sharla001
    Tony
    2014 Thunder
    None
    What is the alcohol test you speak of?? And the percentage?
  16. Nov 29, 2024 at 5:11 PM
    Scratch73
    Check into this. This is actually from these forums
    Reset Flex Fuel Alcohol/Ethanol Percentage Level with Bidirectional Scan Tool
  17. Nov 29, 2024 at 8:15 PM
    Sharla001
    Tony
    2014 Thunder
    None
    Thank you for your help !
  18. Nov 29, 2024 at 8:47 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Yup, just experienced this a few months back on my dad's truck.
    1UP[QUOTED] likes this.
