New headunit - need help on parts need
Discussion in 'Audio & Video' started by spdrcer26, Sep 29, 2019.
  1. Sep 29, 2019 at 6:41 PM
    spdrcer26
    spdrcer26 [OP] New Member
    Bakersfield, CA
    2017 Crewmax
    2017 Crewmax with non JBL-
    Installing new fosgate 6.5 speakers front and back - running off deck
    10" Pioneer IBflat 10"
    400 watt soundstream mono block amp
    Kenwood DNX7706S
    I don't have access to a car stereo shop and have spent countless hours trying to figure out what parts I need for the deck to use the factory usb and maintain steering wheel controls. Does anyone have the part # or a list of what I need to order. Also if it is better to run new speaker wires to the deck. Thanks
  2. Sep 30, 2019 at 6:15 AM
    marc32
    marc32 New Member
    Mario
    Maryland
    2015 Toyota Tundra SR5 4x4
    I would run new wiring. You bought yourself nice equipment, run it with nice wiring too.
    Not mistaken, your going to need a PAC-adaptor for the steering wheel controls.
  3. Sep 30, 2019 at 6:32 AM
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    Nope - don't need new wiring. Factory wiring for your new door speakers will be perfectly adequate. Just run some good OFC wiring for your mono block - 8 gauge should do for 400 watts. You should still have a factory amp under the passenger seat, even though it's not JBL. So your fosgates will be running off the factory amp, not the deck.
    For interface modules you have two options:
    Pac Audio RP4.2-TY11 (Radio Pro) OR
    iDatalink Maestro RR
    Camera retention is a little easier with the RR (extra harness required for PAC), however the PAC unit has a fully integrated main harness. You will have to buy the vehicle specific harness for the RR. USB retention will require an extra adapter either way part will be PAC USB - TY1 or TY2.
