New member - Sequoia 2006 SR5 2WD
Discussion in 'New Member Introductions' started by clementl47, Nov 22, 2024.
  1. Nov 22, 2024 at 7:50 AM
    clementl47
    clementl47 [OP] New Member
    Little RockAR
    2006 Toyota Sequoia SR5 2WD
    No modifications done
    Hello,
    New member wanting to say hi to the community.
    I've got a maroon 2006 Toyota Sequoia SR5 2WD.
    So far I've done some work on it :
    • Control arms, lower (OEM) and upper BJ, shocks and struts, sway bar link, steering rack bushings...
    • Spark plug, coolant and steering flush, changed v belt and and the threaded pulley (it was very bad)
    • Swapped all lightbulbs for LED
    • New tires and alignment
    • Rear hatch actuator
    • Cleaned throttle...
    • And I'm forgetting a lot of things
    What needs to be done :
    • Front left bearing,
    • Resolve a rattle noise coming from either a heat shield or the vbelt, located close to the driver exhaust manifold, and the AC compressor
    • Find a new aftermarket rocker switch for my heated seats (they work but have been switched by aftermarket one) as the OEM one does not work and I need a 3 pin
    And I'm planning to build a wooden platform to go fishing and camping with this car!
    FrenchToasty likes this.
  2. Nov 22, 2024 at 7:58 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  3. Nov 22, 2024 at 7:58 AM
    Welcome from NY.
  4. Nov 22, 2024 at 8:01 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  5. Nov 22, 2024 at 8:14 AM
    clementl47
    Little RockAR
    Thank you all!
    KNABORES likes this.
