New shocks and struts?
Discussion in 'Suspension' started by Grayfox7, Mar 25, 2023.
  1. Mar 25, 2023 at 7:31 PM
    Grayfox7
    Grayfox7 [OP] New Member
    Chase
    2007 Tundra Limited CrewMax
    Hello all and thank you for reading my post!
    I have a 2007 Tundra CrewMax 2wd and a 2010 4runner. The 4runner rides a lot smoother and definitely do not feel every bump like my Tundra. I’ve had the truck for about 2 months now and just seems like it might be time for new shocks. My buddy’s 2012 Tundra rides better than my 4runner very smooth and you don’t feel every bump. Should I just go ahead and replace it all? Any thoughts or suggestions would be much appreciated!
    PhotoNerd likes this.
  2. Mar 27, 2023 at 8:11 AM
    Grayfox7
    Chase
  3. Mar 27, 2023 at 8:51 AM
    PermaFrostTRD
    Northern NY
    Any service history of the truck before you purchased? Total miles on the truck? Type of current shock? Budget?
    Providing these details will help others steer you in the right direction much more than a "bump" will.
  4. Mar 27, 2023 at 8:52 AM
    CTundraForMe
    CTundraForMe New Member
    Hi, tires play a factor in this as well. Plus any load already on your truck, like steel?
  5. Mar 27, 2023 at 8:52 AM
    CTundraForMe
    To clarify, tire size, tire inflation, and tire rating all affect it. For example, E-rated ride hard.
  6. Mar 27, 2023 at 9:43 AM
    MyActualName
    MyActualName New Member
    I recently replaced my worn stock black front shocks with KYB gas-a-just shocks. Night and day difference in ride quality. Before the ride as rough, harsh, and uncontrolled. After it is smooth, comfortable, and very controllable.
    KYB is a budget option though (~$100 per corner) and will require the usage of a spring compressor for install. If I get 3-5 years out of these I'll be happy.
    I replaced my rear shocks with KYB gas-a-just and didn't notice nearly as much improvement compared to changing the fronts.
  7. Mar 27, 2023 at 12:01 PM
    txtundra311
    txtundra311 New Member
    The answer to this question depends on how much you have to spend?
    best oem value option:
    trd off road shocks (bilstein 4600)
    best option medium:
    bilstein 5100
    best option medium plus:
    bilstein 6112 & 5160
    best option premium:
    kings, Fox
  8. Mar 27, 2023 at 12:52 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    That would be 6112 & 5160.
    But, you were close, haha
  9. Mar 27, 2023 at 1:00 PM
    txtundra311
    Haha close enough, after researching different brands/models etc, the numbers intertwine together
  10. Mar 27, 2023 at 9:28 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    Haha, they sure do!
  11. Mar 27, 2023 at 10:03 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I just put on some OEM red trd shocks up front. I tried kyb mono max, after 10k miles the kyb weren’t riding well, not enough rebound valving.
    The oem red bilsteins are waaaaaay better
  12. Mar 28, 2023 at 10:22 AM
    Grayfox7
    Chase
    168 K on the truck and it has yellow and blue shocks. Tires are 275/65/18 Michelin at3 on black DX4 wheels. Budget wise probably a in the medium range. Should I also replace struts?
    Thank you all so much
  13. Mar 28, 2023 at 11:04 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    sounds like you just need some stock replacements and call it a day
  14. Apr 4, 2023 at 11:14 AM
    Grayfox7
    Chase
    What about struts? What is a good mid grade to go with?
  15. Apr 4, 2023 at 11:49 AM
    MyActualName
    The front struts are composed of an inner shock wrapped in a coilover spring. If you don't want to replace the entire assembly (due to expense or whatnot), either you or a shop can replace just the inner shock and reuse the coil spring. The answer from txtundra311 still applies.
  16. Apr 4, 2023 at 12:40 PM
    Grayfox7
    Chase
    Would you recommend changing out the coil springs?
