New to me 02 Timing Belt
Discussion in '1st Gen Tundras (2000-2006)' started by Steele, Apr 26, 2025 at 10:30 AM.
  1. Apr 26, 2025 at 10:30 AM
    Steele
    Steele [OP] New Member
    Saturday
    2002 Tundra
    IMG_3318.jpg IMG_3312.jpg New to me 2002. 115 thousand miles with unknown history. I did a timing belt inspection thinking that it was original from 2002 - sure looked good. Based on the picture below wanted to see if anybody was in agreement that it had to be replaced sometime along the way… older gentlemen owned the truck since 02. Second picture is of the downstream oxygen sensor. It looks like it bolts on and that the bolts are completely corroded. I take it. I can just Wrench, what is left of these off and throw some new 12 mm bolts on the studs?
  2. Apr 26, 2025 at 10:53 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Good luck with that approach. More than likely a nut splitter if it’ll fit or cutting a slot in the nut with a dremel cutting wheel to pry it apart.
  3. Apr 26, 2025 at 1:27 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    So you want to roll the dice on whether or not that timing belt is good? That's a great way to turn the truck into a "new to me 2002 paperweight". Recommended intervals for timing belts are 90K/9years. Why not just start with a fresh one for peace of mind? As for the O2 sensor: is it leaking? Are you getting CELs? Yeah it's gross, but if it ain't broken, don't fix it. If there's that much corrosion there, what does the rest of the frame look like? Point being; there might be areas that you would want to address first. Throw up some more pictures. And, have you read the mega thread yet? There's three things that will kill these trucks: 1) Frame corrosion. 2) Timing belt failure. 3) Lower ball joint failure. What's your status on numbers 1 and 3?
    Fragman likes this.
  4. Apr 27, 2025 at 7:35 AM
    I don’t think that belt has ever been replaced.
    Would not doubt if you have stored codes for cat efficiency (gauge bulb may be blown) due to the leak at that sensor. Have you canned for codes? But yeah, what you said is how I would handle. And use gaskets if EPC shows you need them. Sometimes they exist downstream. But note the bung mating surface looks borked also.
    If you haven’t already been there/done that: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
  5. Apr 27, 2025 at 9:04 AM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    If it's a single owner vehicle, 'unknown' is going to more than likely mean 'not done'. If they had done it, they would know (because it isn't cheap to get it done by someone else, so they'd remember!) and would have said so as it ups the value. Plus it doesn't look that new to me. I really wouldn't roll the dice on that one.
  6. Apr 27, 2025 at 1:40 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
