New wheels…TPMS sensor reuse.
Discussion in 'Wheels & Tires' started by brucega7x, Aug 21, 2023.
  1. Aug 21, 2023 at 10:35 AM
    brucega7x
    brucega7x [OP] New Member
    2022 Tundra SR5 CrewMax 4X4
    I see people say their dealer will re use the OEM TPMS sensors. My understanding is the sensor and valve stem are a one piece unit.
    I’m assuming they’ll simply swap the entire unit from the OEM wheels to the new ones I’m having them mount and balance?
  2. Aug 21, 2023 at 10:38 AM
    BeauDacious
    BeauDacious 040 > all other colors
    Beau
    14 DC 4x
    You are correct.
    If they fit, there are wheels that require different stems. But I doubt you bought that with this discussion.
  3. Aug 21, 2023 at 10:55 AM
    brucega7x
    Awesome, that’s makes things easy. Just making sure I didn’t need to buy valve stems or something.
  4. Aug 21, 2023 at 10:58 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2022 Limited Crewmax 6.5 Bed
    Lots of stuff!
    My tire shop took the ones out of my OE wheels and put them into my new wheels. I guess the issue is using aftermarket sensors sometimes don't work and you get TPMS errors lighting up the dash.
  5. Aug 21, 2023 at 11:01 AM
    brucega7x
    Yeah I don’t want all that. I’m perfectly happy with them re using the OEM valve stems and sensors.
