New wheels and TPMS sensors; how to program?
Discussion in 'Wheels & Tires' started by MountainMan, Jul 17, 2023.
  1. Jul 17, 2023 at 12:34 AM
    MountainMan
    MountainMan [OP] New Member
    Idaho/Washington border
    2021 1794 Edition
    Bilstein 5100s, 285/70R17s, Tuff Country rear add-a-leaves, Rough Country rear bumper, Rough Country CAI, Dirty Deeds Ind. straight pipe kit, Ironman Raid front bumper, 13k lb. winch, Leer topper, custom rack, Decked bed drawer system, AuxBeam fogs, Midland CB radio.
    I ordered a set of new wheels from Tirerack.com with new TPMS sensors installed.
    I then took them to Discount Tire and had new tires mounted on them.
    I picked up the Tundra and no codes or error lights. I drove a short distance and checked the tire pressure. It showed only 33 lbs of air in LT285/70R17 10-ply tires. I returned to the Discount tire shop and had them aired up to 45lbs.
    The tire tech said that the actual pressure was 38 psi before he aired them up and not the 33 psi showing on my dash. Weird.
    I drove it for a week and forgot about it, then today, I suddenly got a TPMS warning light and message saying there was an issue.
    Pulled over and checked and tire pressure was fine. TPMS system no longer showing any pressures.
    I looked up a couple of videos and they said to turn the key to "on" and then press the TPMS reset button until the warning light flashes 3 times, then drive for 20 minutes.
    When I press my ignition switch twice to "on", the TPMS light is already on. Pressing the reset button causes it to start flashing and it will just keep on flashing. Driving it for a few minutes causes the light to stop blinking, and remain steady. Still no air pressure data.
    I tried this a couple of times and no progress.
    Who should I go to for getting the sensors to sync? TireRack, or Discount Tire?
    I've had custom rims put on Toyotas before with aftermarket TPMS sensors and haven't had issues.
    Is there a trick to getting them to work on the Tundra?
  2. Jul 17, 2023 at 1:18 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Sounds like Discount Tire didn’t program in the new sensors. This is common when I switch on/off my winter tires, they don’t remember to reprogram, so I take it back to the air check lane if open and they do it there without an appointment.
  3. Jul 17, 2023 at 4:37 AM
    Discount doesn't need to program them. The 2020 and 2021 models will register the sensors to the truck automatically through the ECU. Its just a PITA and takes time. Every truck reacts differently though. Some register fairly quickly, some take longer.
    batman900 likes this.
  4. Jul 17, 2023 at 4:52 AM
    This process is a pain and the manual is poorly written. I have dealt with it quite often. If I'm reading correctly, currently you have no pressures displayed and the flashing light? Try this and see what happens. Turn the ignition on without starting the truck. Hit the button so that the light starts flashing. Let it flash until it turns solid. It will flash for 1 to 2 minutes. One is stops flashing and turns solid, it should say something like "Racalibration in process, please wait until finished". Once you see that, shut the ignition switch off. Start the truck and drive as normal. As you drive, the system will start to program itself. Every truck is different, so it may take 3 or for miles, or it could take 10 miles for example. If you drive say from home to work as your initial drive and the pressures haven't come up yet, give it time. Once you initially hit the button to start the process, you don't have to hit it again. You can shut the truck off, and the process will pick back up from where it left off. This is all depending on if the sensors that you have are compatible.... I would confirm this with Tire Rack. These newer trucks don't like most aftermarket sensors. I put OEM Toyota sensors in mine.
  5. Jul 17, 2023 at 8:04 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    In my experience with a 2021 Tundra and 2022 4Runner, both ECUs have 4 slots (plus a optional spar slot) for specific TPMS sensor IDs and and after a winter tire change or tire rotation easiest way to get back to normal is to use a TPMS reader that then connects to the OBD2 port, about a 5 min process. Discount Tire will do this for free if asked specifically for it. There are possibly other ways for sure.
  6. Jul 17, 2023 at 9:48 AM
    MountainMan
    2021 1794 Edition
    With the push button start, I am assuming that "on" is when the button is pushed twice so that the dash lights up and is equivalent to turning the key to the position just before start?
  7. Jul 17, 2023 at 9:53 AM
    Yes that makes sense to me. Mine is key start.
  8. Jul 18, 2023 at 5:47 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Haha just tried this out and it legitimately works, this is pretty cool. Did a tire rotation and removed two wheels out of the rotation, got the usual tpms warning the next day then tried this process and all set to go in 10-15 minutes.
  9. Jul 18, 2023 at 6:03 PM
    Glad it worked for you. It took me quite a while to figure it out on mine.
  10. Jul 18, 2023 at 6:35 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Sounds like for 4runners they don’t have a tpms button, I can’t find one. However in the menu there is a tpms reset option so will give that a shot. I wonder if Gen3 Tundras are the same (no physical button).
  11. Jul 18, 2023 at 6:45 PM
    Correct...the 4Runner TPMS stuff is in the menu. We have a 2020.
  12. Jul 19, 2023 at 12:40 AM
    MountainMan
    2021 1794 Edition
    Well, poop... I've tried all the suggestions and my sensors just aren't working.
    When I push the button to the "on" setting, the dash and all warning lights come on, just like when you would turn the key to the last position before starting the engine. But, the TPMS warning light is already flashing and pressing the reset button does nothing. I wait until the light stops flashing and turns solid. I then turn the ignition off, then immediately start the engine. There is no message about re-calibrating the sensors.
    What I get on the screen displaying the TPMS info is a message saying the system is experiencing a malfunction and to report to the dealer.
    Looks like TireRack screwed up when they installed sensors in my rims that don't work with my vehicle.
  13. Jul 19, 2023 at 5:17 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    I noticed hitting the tpms button didn’t do anything while the tpms light was flashing. Then I kept hitting it after the tpms light went solid and after a while the notification changed to recalibrating as well as the tpms light turns off. I waited like 30 seconds then shut down the vehicle (was in the on position the whole time previously). Then turned on the vehicle and it still said recalibrating, drove it 1 mile and it then popped up with all 4 tire pressures.
  14. Jul 19, 2023 at 5:20 PM
    MountainMan
    2021 1794 Edition
    I had to disconnect the battery today when I installed a new RC CAI system. TPMS light no longer on, but still no tire pressures.
  15. Jul 19, 2023 at 5:48 PM
    CTundraForMe
    CTundraForMe New Member
    When I got new tires from DT, there was a sensor that was completely dead. They apparently don't always validate them before saying "it's done".
  16. Jul 19, 2023 at 5:50 PM
    Try the procedure that I posted again and see what happens this time.
  17. Mar 29, 2024 at 7:35 PM
    Suterman
    Suterman New Member
    2021 Tundra SR5
    Black Alloy Wheels
    Ok. I’ve read through all the postings on TPMS programming problems for 2021 Toyota Tundras and all the advice regarding using special replacement sensors. I replaced my steel wheels with alloys and used aftermarket TPMS sensors that initially did not program, even after an attempt by my local tire store using an Autel programmer. I got the one minute flashing tire light and then a solid one, and the tire pressure reading continually stated it was in programming mode. After 300 miles and no change, it was back to the tire store I went. The team there called Autel and were instructed to ID my original TPMS sensors from my truck’s ECU and (as I read in a few forum entries) “clone” the new ones by assigning the original sensor IDs. Must be pretty easy to do because it didn’t take long once they were given the instructions. Now, my aftermarket TPMS sensors are programmed at the 315 hertz frequency and my ECU is being fooled into thinking it has those original factory sensors. Most important, the truck’s display is providing the correct tire pressure for all four tires. My biggest fear was being saddled with very expensive valve stems and forking out more dough for 4 additional sensors from my Toyota dealer. Contrary to what you may have read, NOT NECESSARY!! I love my Tundra.
    Ponderosa_Pine likes this.
  18. Mar 29, 2024 at 8:13 PM
    6rian
    6rian New Member
    I wouldn't expect your external tire pressure gauge to read exactly the same as the TPMS. If might, but there's always going to be variances between devices. My external tire gauge is 2 PSI off from the TPMS. No way to know which is truly the correct one. I just split the difference.
  19. Apr 2, 2024 at 11:32 AM
    BC Tundra
    BC Tundra New Member
    Just to add to the TPMS topic, I just got my 2020 Tundra back from the dealer for it's 60,000km service just last week and I had to get them to re-flash (that's what they called it) the factory sensors on the stock aluminum rims that came with the truck because they weren't being 'read' by the vehicle.
    Long story short, I bought the truck in the fall and TPMS worked fine. Took the stock wheels/tires off and put on studded winters on factory rims with aftermarket TPMS and was able to recalibrate the winters no problem using the re-set button. Then, two weeks ago I went to swap the tires back to the factory wheels/tires/TPMS set-up and the vehicle would NOT recognize the factory TPMS no matter what I tired (and I tried what I thought was virtually everything). When I dropped the vehicle off for the service I told them the stock wheels/tires/TPMS was not reading at all - the service tech there told me that factory TPMS require 're-flashing' in order to work and will not simply re-set with the button under the dash (do not know if that is true, that's just what the tech told me). $50.00 later (on top of the rest of the 60,000km service charge) everything works fine.
  20. Apr 2, 2024 at 1:07 PM
    The tech was wrong. It's a PITA but the 2020 will read them without having to be reflashed.
  21. Jun 11, 2024 at 5:25 PM
    Ebart
    Ebart New Member
    Ernie
    2021 Toyota Tundra TRD Pro
    I’ve tried everything on my 24 tundra and nothing works. Any other suggestions?
  22. Aug 23, 2024 at 6:52 AM
    Maxclout
    Maxclout New Member
    Ian
    I too now join the TPMS error club now that I have new tires, wheels and sensors. Anyone figure something out?
  23. Aug 23, 2024 at 7:19 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Stick with oem. Newer Toyota electronics don’t mesh well with aftermarket.
  24. Aug 23, 2024 at 1:06 PM
    Maxclout
    Maxclout New Member
    Ian
    Strangely enough the aftermarket sensors work perfectly after going to DT and assigning them to the ECU manually. :notsure::notsure:
  25. Aug 23, 2024 at 3:55 PM
    wcoastpi
    wcoastpi New Member
    Mario
    So CAL
    2024 Tundra Limited TRD Off Road
    Having the same problem with '24 Limited. Followed instructions from manual on how to reset the tpms. Seemed to work but no readout? Then checked my app. App is working but is still reading old tire pressure value before I aired up the tires and adjusted all 4 with a digital tire sensor. Drove around for several minutes but nothing changed. The only thing I did prior to that was removed the OEM tires and put on new meat on the same stock TRD wheels. Blowing my mind. Never had this problem with my 2017 Tundra. I'd take back that V8 in heartbeat. I saw a 2025 reveal for the new Tundras. According to information, the 5.7 was going to be offered again in addition to the V6 twin turbo. If true, should've waited to get the '25. My build was July 11, 2024. Keeping my fingers crossed, didn't know about the engine problems with the V6 until after I purchased.
  26. Sep 12, 2024 at 10:24 AM
    How did you see the 5th position on your Tundra? This is a project that I need to get back to working on.
  27. Jan 22, 2025 at 8:43 PM
    chay2263
    chay2263 New Member
    2024 Tundra Platinum iForce Max 4x4
    Welp….add me to the list of folks that swapped to aftermarket wheels and TPMS (Autel) and I can get them to register with the truck. I’ve tried going through the menu and selecting “identifying wheel and position” in the menu and driving the truck around. It says it’s identifying but it never finishes. I drove the truck for about 20mins. Not sure what I’m missing.
  28. Jan 22, 2025 at 8:44 PM
    chay2263
    chay2263 New Member
    Then when I pull back into the garage where my old wheels are, the TPMS picks those back up on the dash. The shop were “cloning” these TPMS sensors with the same IDs as the OEM ones. Still not sure what’s going on
  29. Jan 23, 2025 at 7:36 AM
    wcoastpi
    wcoastpi New Member
    Mario
    So CAL
    After all this time, still having minor problems. Still can't see tire pressure readout on the dash instruments, except when first going through the resetting process. After that, no readout. But works perfectly fine on the app.even after airing up - Go figure.
  30. Jan 23, 2025 at 9:31 AM
    mfranzen89
    mfranzen89 New Member
    Mat
    Kansas City
    2021 Tundra TRD Pro LR
    Thanks for having me here - newest member to the TPMS Problem Club. Got aftermarket wheels and Autel MX TPMS sensors - not reading on dash. The app still displays the old tire pressures. Going back in to try and get this fixed. Taking my old Pro wheels with TPMS sensors in case they need to swap them back in....
