new wheels means new alignment??
Discussion in 'General Tundra Discussion' started by Henry2019, Dec 4, 2022.
  1. Dec 4, 2022 at 9:25 AM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    one of the local shops near me had told me that if i get a new wheel setup then i would need an alignment to prevent any premature wear and tear.. does this soumd like bologna to you folks? TIA!
  2. Dec 4, 2022 at 9:26 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Changing wheels will not affect alignment at all.
    Installing a lift will.. wheels no
  3. Dec 4, 2022 at 9:27 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  4. Dec 4, 2022 at 9:31 AM
    Mostly bologna. Changing the offset of the wheels does change some geometry though. Shock Therapy did a video on it regarding offset changes on SxSs, but it is much more exaggerated on those. Not sure it'd be enough to impact a truck, but maybe?
  5. Dec 4, 2022 at 9:34 AM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    i did plan to change the offset of my wheel setup, not drastically though.
  6. Dec 4, 2022 at 9:36 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    I would say no but it is helpful if you have warranty issues with the tires. All responsibility is on one shop
  7. Dec 4, 2022 at 9:38 AM
    See if this makes any sense or applies. (Not all of the video)
    https://youtu.be/yfhYNiSs7aE?t=88
  8. Dec 4, 2022 at 9:39 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Might as well be spam!
    joonbug[QUOTED] likes this.
  9. Dec 4, 2022 at 9:43 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    When was your last alignment?
  10. Dec 4, 2022 at 9:45 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    New wheels/tires don't impact alignment. Is it possible there was a miscommunication and they are noticing unexpected wear on your current tires and are letting you know you should get an alignment?
    Mr.bee and FrenchToasty like this.
  11. Dec 4, 2022 at 2:29 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    couple of months ago
  12. Dec 4, 2022 at 2:30 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    it was all said over the phone. they haven’t even seen my truck yet Lol.
  13. Dec 7, 2022 at 4:13 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    New wheels do not throw the alignment off. People often get a new alignment with tire replacements just to keep things in spec. This is because an alignment can be thrown off from years of potholes and bumps and doing it with a new set of tires is good insurance that you’ll start off on a new set of tires with everything in spec. This isn’t the same as saying swapping wheels and tires out automatically requires an alignment. Personally, I do it with tire changes Which is every 5-ish years for me.
    Perhaps they should have phrased it as “we recommend starting off on new tires with an alignment” but to make the sale they phrase it like its critical. If it's been more than a few years since one was done it might not be a bad idea but if you see no evidence of uneven wear right now it is not the end of the world if you get your new rims and tires on then get around to it a little bit after that.
  14. Dec 11, 2022 at 7:06 AM
    2mchfun
    The key is to watch tire wear, it speaks loud and clear if you pay attention.
    Chadwicktr likes this.
