Newbie working with some frame rust
Discussion in '1st Gen Tundras (2000-2006)' started by cbp310, Apr 19, 2023.
  1. Apr 19, 2023 at 4:05 PM
    cbp310
    cbp310 [OP] New Member
    Tundra 1st gen 00
    As indicated by the title of the post - working on some frame rust for the first time myself after owning the truck for a few years and trying to get some guidance on how to handle this rust.
    This is above the rear driver's side wheel. The right side looks fine and the remainder of the frame looks to be in good shape. Replaced the exhaust and pipe last year due to rust, but that was mainly due to the connection points.
  2. Apr 19, 2023 at 4:21 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Looks like mostly surface rust under a rust encapsulator paint. Should be easy to take a wire brush, clean off and re-apply the encapsulator paint. If you really want it to look good, a die grinder and wire wheel attachment should easily remove all the surface rust.
    Edit: Looks like the original paint now that I see it up close on a 32" computer.
  3. Apr 19, 2023 at 4:24 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Needle scaler? What is it everyone recommends besides ospho?
    I dont have that bracket. Not really sure what it would be for...traction bar?
    maybe its for airbags...
  4. Apr 19, 2023 at 4:25 PM
    cbp310
    Tundra 1st gen 00
    Needle scaler + ospho and then fluid film?
  5. Apr 19, 2023 at 4:38 PM
    cbp310
    Tundra 1st gen 00
    Airbags -- I just took them out and put in springs and we didn't remove the bracket.
    Mr.bee[QUOTED] likes this.
  6. Apr 19, 2023 at 4:46 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Check the frame stiffeners, inside the frame rail where the front leaf spring mounts are.
    N84434 likes this.
  7. Apr 19, 2023 at 4:52 PM
    cbp310
    Tundra 1st gen 00
    here?
  8. Apr 19, 2023 at 5:06 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I think another spot to check is the spare tire hanger.
    FrenchToasty likes this.
  9. Apr 19, 2023 at 5:18 PM
    cbp310
    Tundra 1st gen 00
    here's the backend plus spindle.. thanks for the advice!
  10. Apr 19, 2023 at 5:32 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Zooming in and overlooking the dirtiness, I'd give it 7/8 frame condition for a 23 yr old truck
    Tundrastruck91, vtl and Aerindel like this.
  11. Apr 19, 2023 at 5:33 PM
    Aerindel
    Aerindel New Member
    Montana
    Yeah, really not too bad.
  12. Apr 19, 2023 at 5:34 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Pressure wash that nasty hoe so you know EXACTLY what the rust looks like but ignoring the dirt, looks decent.
  13. Apr 19, 2023 at 5:35 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Not too bad, if you flip your spare, it'll be easier to check the pressure.
    whats the swing-out doohickey in the reciever?
  14. Apr 19, 2023 at 5:45 PM
    cbp310
    Tundra 1st gen 00
    Thanks for all the feedback .. 7/8 is great news
    The swing out is a rockymounts bike rack that swings out to the side of the tailgate. Allows for hauling bike and not obstructing our camping setup
    Mr.bee likes this.
  15. Apr 19, 2023 at 5:51 PM
    906UP
    906UP New Member
    For a 23 yro truck that frame is spotless! UP here our trucks look like that after a winter or 2, phuckin salt!!!
    Jack McCarthy likes this.
  16. Apr 19, 2023 at 6:02 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    This what you get on a brand new truck in MA after the very first winter.
    If you're ok with a sticky frame for a year or two until it cures, Noxudol is superior product. Spray Noxudol 700 inside the frame and in all hard to reach joints, spray or brush 1600 everywhere else. This is a one time job, unlike fluid film.
    PermaFrostTRD likes this.
  17. Apr 20, 2023 at 2:01 AM
    w666
    Maryland
    Yes, but from the other side...looking inside out.
  18. Apr 20, 2023 at 2:14 AM
    rock01
    rock01 New Member
    Rich
    2006 Tundra SR2 2wd
    front hitch, timbrens, camper shell
    Looks great but you caught it in time. Once the paint starts to fail if the frame keeps seeing salt and moisture it will start rusting faster.
  19. Apr 20, 2023 at 3:41 AM
    PermaFrostTRD
    Northern NY
    That's in great condition given its age. As others have said, wire wheel/needle gun and apply some rust prevention. A good rinse to remove that salt and road grime in the pics will make things look a lot better (and give a better idea of where you should focus).
  20. Apr 20, 2023 at 8:44 AM
    cbp310
    Tundra 1st gen 00
    any recommended products for the rust prevention? I'm seeing fluid film and por15 thrown out in the forum. I assume this is after layering in a degreaser, right?
  21. Apr 20, 2023 at 8:47 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    https://www.noxudolusa.com/
  22. Apr 20, 2023 at 9:13 AM
    nowayout
    nowayout New Member
    NY
    17 CM
    I tried Fluid film but I like the Amsoil Heavy Duty Metal Protector much better. It leaves a good waxy like film that really lasts long. I never tried noxudol.
    https://www.amsoil.com/p/heavy-duty-metal-protector-amhsc/
  23. Apr 20, 2023 at 9:31 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Noxudol/Mercasol is what Swedes use in Volvo. My 2005 was rust free in 2017 when I totaled it. I'm in eastern MA, white road stuff in winter is salt, not snow. Its replacement with 220k miles has had some rust under right rear fender flare, but I suspect it spent a few years sitting in snow, with battery fully drained (battery is a part of chassis rust-prevention).
    So I sprayed my Tundra with Noxudol when it was new. I take it for semi-hard offroading a few times a year, Noxudol holds up pretty well. When it gets some frame spots scratched down to the metal, I just apply new Noxudol with a brush. Small pinches it heals on its own, no attention required. After 4 winters the frame is in spectacular shape. I was so impressed with both Tundra and Noxudol that we sold wife's Ford-era Volvo, got her a Sequoia, and sprayed it with Noxudol, too. Good thing is though 1600 is tar-like, it does not trap water, but instead pushes it away from metal. It also doubles as a sound deadening: reduces road noise in cabin transmitted by the frame.
    I'm sure others do something similar to Noxudol now, because it works so good, I just haven't tried. Paint, POR and fluid film are behind the anti-rust progress for sure.
  24. Apr 20, 2023 at 9:37 AM
    PermaFrostTRD
    Northern NY
    I've just used fluid film, but may look at Noxudol..
