Nitto Terra Grapplers G2 tire pressure recommendation
Discussion in 'Wheels & Tires' started by chinadog, Sep 2, 2019.
  1. Sep 2, 2019 at 4:51 AM
    chinadog
    chinadog [OP] New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    Just put a set of 285/55/20 Nitto Terra Grapplers G2 on my 2018 Tundra. I've got less than 3 miles on them. :)
    I looked at the pressure quick and Discount Tire put them at 35 on the front and 40 on the rears.
    Based on searches that seems to be a little low, at least on the fronts. What are you guys running these tires at?
    I'm mostly on the road, don't tow. Only occasionally on dirt/gravel roads. Pretty much my commuter vehicle.
    Thanks.
  2. Sep 2, 2019 at 5:00 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Thinking those are an e rated tire, 40-43 psi cold is a good starting point.
  3. Sep 2, 2019 at 5:06 AM
    Jettech
    Jettech New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    TRD Exhaust, DC 305/55/20s, TRD PRO Shocks, HID's, JOBOX, Bully Dog Tuner, TRD sway bar, Shorty FM Int,
    I was told they run lower pressure than other brand tires. I think we ran 35-38 in the last set
  4. Sep 2, 2019 at 9:28 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    When a tundra comes with that size as a port installed option (Texas Edition, TRD, etc..) the door placard calls for 49PSI.
    So, that’s what I’d recommend.
  5. Sep 3, 2019 at 10:52 AM
    chinadog
    Knoxvegas
    Thanks for the feedback guys!
  6. Sep 3, 2019 at 11:01 AM
    TheBeast The Beach
    I say start at 40 psi and go from there.
  7. Sep 3, 2019 at 11:11 AM
    chinadog
    Knoxvegas
    Just got a response from Nitto:
    Thank you for the information.
    Regarding your inquiry, based on the vehicle information you provided, the recommended replacement psi for the Tires is 40 psi for front and 47 psi for the rear tires.
    (NOTE: Although the email indicates a “noreply” email address, function for correspondence is available and photos or documents can also be added as attachments.)
    Thank you,
    Nitto Technical Services Department
    Nitto Tire U.S.A
    Fueled by Enthusiasts
  8. Sep 3, 2019 at 11:13 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Think it through. Why would the psi he higher in the rear than front on an empty pickup....that makes zero sense
    Nm6300'asl likes this.
  9. Sep 3, 2019 at 12:12 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    To compensate for payload and tongue weight.
    They’re giving him specs for minimum pressure to handle full GVWR. They can’t/ won’t tell him to put 40 in the rear. If so he would have a higher likelihood of tire failure while fully loaded.
  10. Sep 3, 2019 at 12:20 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I get that. But 90% of tundra owners drive around with an empty bed 90% of the time.
  11. Sep 3, 2019 at 9:19 PM
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
  12. Sep 4, 2019 at 4:06 AM
    chinadog
    Knoxvegas
    After dinner, I put 40 in the fronts and 44s in the rears, but haven't driven it yet. I'll adjust more. Expect it'll feel different than 35/40. I'll see how it feels today. I'm amazed how the numbers vary. Thanks for the input, we'll see how it goes.
  13. Sep 4, 2019 at 4:27 AM
    War Machine
    War Machine SSEM # 5 3MW
    Slightly embarrassing, but I didn’t know until a couple of days ago that PSI recommendation was on that placard. I only found out because I was checking the pressure in my daughter’s Tundra. I googled for psi recommendation and read that.
    So, the psi on the placard is really what I should go by?
  14. Sep 4, 2019 at 4:32 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I've had 275/60/20 Terra Grappler G2's on my Tundra since new. Did a bit of air pressure "searching" when it was new. Settled in at 44 or 45 front and rear. The wear has been even across the 275mm's of tread during their 54,000 miles of life. Mine is 4X4.
    chinadog[OP] likes this.
  15. Sep 4, 2019 at 9:22 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    All in all, yes.
    If you want to drop it by a few to potentially help ride quality just make sure to reset the baseline TPMS setting and know that max payload is reduced.
  16. Jan 25, 2022 at 4:03 AM
    ronrich
    ronrich New Member
    Greetings …. just found this post and forum hoping to get some input on this since the post is somewhat dated. I just got a new set of Nitto Terra Grapplers G2 305 55 20 XL size from Discount Tire yesterday for my supercharged Tundra 2WD Crew Cab. I asked the rep what they recommend and he stated 35 PSI, unless you are going to be doing a lot of towing. The old set got just over 42,000 out of them until excessive wear got to the them on both outer edges especially on the fronts which were bald. Since it wore like that I do not think it is an alignment issue with toe in. I definitely ran them down to the wear bars, so they probably should have come off sooner. I kept those at 35 PSI also and rotated them around every 8k miles around every synthetic oil change. So I am a bit baffled as to why they didn't last to their rated 65,000 miles and most of all why there was a uneven wear pattern. I'd like to try and get better life out of these. I mostly drive on paved roads in town with an empty bed and have never towed. I've read about the "chalk test" and may try that; but I'm interested in what folks are running in similar situations. Have y'all got ever got those kind of miles out of a set? What tire pressures would you recommend and rotation frequency? Thanks!
  17. Jan 25, 2022 at 4:37 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    I'm on my 2nd set of Terra Grappler G2's. My first set wore great. Even wear when I took them off at 63,000 miles. As I noted above over two years I ran that first set, and am running this 2nd set at 44 psi on all four tires.
    I would tell you that the 35 psi "recommendation" is one that dates back 25 years. I ran all of my vehicles at 35, including my 1997 T100 4WD truck, and their tires wore great. I started my Tundra at that and notices at 5k miles that the outer edge just didn't look to be wearing right. So I upped the pressure after doing some "consulting" on that thar internet thing. 44 has proven to be juuuuust right.
    Good luck.
    EDIT: here's a picture. 17,000 miles. 44 psi.
    Taco-Spike likes this.
  18. Jan 25, 2022 at 6:26 AM
    Taco-Spike
    Two Trucks
    I agree. I run these on my Tacoma. When I first put them on, I ran them at 35 and they felt odd. Almost sluggish and felt kind of a sway when turning. bumped them up to 40 and they felt perfect. They do get to 42/43 in summer time driving for a while. they do feel a little more stiff in a bounce but steering feels tight (which I want and like) for control.
  19. Jan 25, 2022 at 8:01 AM
    ronrich
    ronrich New Member
    Thanks for the quick replies and picture! I'm going to try this, your tire wear looks uniform and great compared to the one's I just replaced. I just finished airing them up from 35 to 42 PSI cold.
