Nitto trail grappler MT 275/70/18
Discussion in 'Wheels & Tires' started by ckblough, Oct 25, 2022.
  1. Oct 25, 2022 at 7:06 PM
    ckblough
    ckblough [OP] New Member
    Hi there—is anyone running Nitto trail grappler MT 275/70/18 on a stock 2017 tundra TRD? Everything I have read says I should be fine to fit them without rubbing. The 275/65/18 that are currently on it are worn and fit fine as they measure around 31”.
    Online tire calculators say above mention nittos should measure 33.2”. Nitto website says 33.6”.
    Should I be worried they won’t fit?
  2. Oct 25, 2022 at 7:25 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
  3. Oct 26, 2022 at 6:09 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    that size fits fine on a stock truck. 285/70-18 will work as well. Some have installed 295-70s on stock trucks but it looks really stuffed, most run a couple inches lift in front with 295s. So yes, no problem fitting that size. 275/70s are usually E load, so be aware they will ride firmer than the stock standard load tires.
