No brakes after Frame Replacement
Discussion in '1st Gen Tundras (2000-2006)' started by WinesburgDuroc, May 21, 2019.
  1. May 21, 2019 at 10:28 AM
    WinesburgDuroc
    WinesburgDuroc [OP] New Member
    2000 Tundra SR5
    I just got my 2000 Tundra back from the dealership for the frame replacement (tip of my cap to Toyota for standing by their product and replacing a 19-year-old frame with 190,000 miles). While the frame was being replaced, the dealer performed a number of other repairs at my cost. These included replacing the brake calipers and the front brake lines. They also told me I would need new brake pads and rotors in the near future, but I opted to hold that work for my regular mechanic.
    When my wife picked up the truck, she called me to say the brakes weren't working well. I just thought she was used to a new vehicle and she had forgotten how lackluster brakes on an older, full-size truck could be. I was wrong. When I drove the truck later that day, the pedal went completely to the floor with little response. I looked over the receipt from the dealer and noticed they had highlighted a portion of the comments that said "Brake pedal is on floor. Brakes were bled three times. Pads and rotors are very thin and should be replaced soon".
    Clearly, something is wrong with the brakes that goes beyond the thin pads and rotors. The brakes were fine when I took it in and they are terrible now. Do you think it's just a matter of air in the lines. They mentioned they had bled them three times, so they clearly recognized that there was a problem.
    Any ideas of what I should look for? Should I take it back to the dealer and demand they figure it out?
    Thanks!
  2. May 21, 2019 at 10:32 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I would. It definitely sounds like something happened while it was there. I would just explain that while you recognize it needs new pads and rotors, it wasn't like this prior to having them work on it.
    Are you seeing any leaks? I'm just wondering if something is loose or not installed properly.
    @empty_lord is it possible they damaged the master cylinder?
    15whtrd likes this.
  3. May 21, 2019 at 10:35 AM
    15whtrd
    15whtrd Mr. Blonde
    Maybe the rear adjuster needs to be addressed as I’ve read that can be an issue. But I also feel that when people bleed the brakes and push the pedal to the floor, they tempt fate on pushing the master cylinder piston into an area it’s not of its typical wear pattern. This could be part of the issue.
  4. May 21, 2019 at 10:38 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That was my thought. Especially if they tried it 3 times. Maybe they put an inexperienced tech on the brake job who was in there curb stomping the pedal...
    15whtrd[QUOTED] likes this.
  5. May 21, 2019 at 11:09 AM
    WinesburgDuroc
    2000 Tundra SR5
    I appreciate the thoughts on the master cylinder. I was wondering if it could be damaged by bleeding the brakes, and your comments about pushing the pedal too far make a lot of sense.
    Thanks
    15whtrd likes this.
  6. May 21, 2019 at 11:18 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Back to the dealer... a lot can go wrong. Make them own up to it
    The master can go bad when bleeding the brakes if it’s overtraveled and the seals were going bad. Other issue can be if the brake bleed didn’t get done right.
    15whtrd likes this.
  7. May 21, 2019 at 3:08 PM
    WinesburgDuroc
    2000 Tundra SR5
    I spoke with the dealership this afternoon. Their service manager spoke to the tech and then called me back, so this explanation is second hand - they said the piston or pistons in the old calipers were stuck, so there wasn't much room in the reservoir, but when I put new pads and rotors on, everything will be okay.
    Obviously, that explanation doesn't make sense. I really hope there was something lost in the translation between the tech and the service manager. The other weird thing is that they said they adjusted my rear brakes, so even if my front brakes were completely shot, I'd still think I'd have some pedal resistance (and stopping power) coming from the rear. I still think it's the master cylinder...or air in the lines.
  8. May 21, 2019 at 3:12 PM
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    I would think poor bleed job, or possible leak.
    I would also be very upset that they chose not to discuss that in depth with my wife,before turning her loose...
    ZappBrannigan likes this.
  9. May 21, 2019 at 3:16 PM
    15whtrd
    15whtrd Mr. Blonde
    That’s total bullshit! The thickness of the pads have no affect on pedal travel. This is not a bicycle with brake cables LOL. As the pads wear out brake fluid fills the piston/calipers even further which is why the reservoir drops as the pads wear. As my pads wear out my pedal travel is exactly the same as it always was. That is the beauty of hydraulics. Tell that guy to kick rocks LOL
  10. May 21, 2019 at 3:18 PM
    Professional Hand Model
    Hand Protectors
    Take it back and have them do the brake service on the needed pads/rotors even though you were saving those for your mechanic. This will force the issue at hand. They’ll have zero excuses for something they messed up.
    Time is money.
  11. May 21, 2019 at 3:44 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    I was going to say the same thing. Clearly they screwed something up, so now just say okay change the pads and rotors and show you there isn't still an issue. When said issue still persists then its on them to correct.
    Njmike13 likes this.
  12. May 21, 2019 at 4:29 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Take it back and tell them to fix them the right way and this needs to be done by a qualified mechanic and not some half wit idiot that was hired because he is the owners idiot son in law that cant get a job some place else because he is a total failure in life.
    Explain to them when your wife got in the truck you should have stopped her due to she could have died.
    Call them out too.
    This bullshit needs to stop
  13. May 21, 2019 at 7:05 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Did the trucks brakes work good before getting the frame replacement, or were they the same as they are now?
  14. May 21, 2019 at 8:22 PM
    02goes
    02goes New Member
    They will if the vehicle was received that way and the customer doesn't want them to fix it.
  15. May 21, 2019 at 8:52 PM
    02goes
    02goes New Member
    Then they can't give the trk back w/o operational brakes as they were when turned in for a new frame. That is if the brakes worked good and not marginal to bad.
    marbleville likes this.
  16. May 21, 2019 at 9:16 PM
    02goes
    02goes New Member
    Thnx. I reread and see that his brakes were working fine.
    I made a simple comment about the dealership and their responsibility which could be of help to the OP's last sentence of initial post.
    If they broke it they are responsible to fix it, and it sounds like they don't want to.
    15Yota and marbleville like this.
  17. May 21, 2019 at 9:28 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The pedal going to the floor is a huge issue that new pads and rotors won’t fix. If there is some pad left and metal left on the rotor the brakes should work. Maybe not great but they will work.
    Giving you the truck back with a known safety issue is fucked up and a huge liability. You or your wife could have been heart or killed. That’s on them.
    Make them tow it back to the dealership and have them fix the issue.
    15Yota, marbleville and 15whtrd like this.
  18. May 21, 2019 at 9:32 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    When they replaced the frame, as well as the calipers & lines, there are a lot of potential problems they could’ve induced. The rear parking brake cable as well as all of the hard brake lines are mounted on the frame. They need to send a flatbed & pickup the truck for repair. This may entail paying them for rotors & pads so they don’t have an excuse. As others have said, if they used the brake pedal to bleed the brakes, the master cylinder seals could’ve been damaged by going beyond the normal wear pattern.
    Sending the truck out without informing you or your wife of the brake bleeding issue was potentially a huge liability for them.
    15whtrd likes this.
  19. May 21, 2019 at 9:57 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    I would doubts about taking to that dealership again for any kind of work.
  20. May 22, 2019 at 2:34 AM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    It sounds like the ABS has been compromised with air entering its modulator valve assembly, or the master cylinder seals have failed. I would suspect that there would be possible problems with moving the brake lines and such from one frame to another, air intrusion of the lines and valves being of certain concern. This should all be on the dealer and the warranty program. Any additional parts not part of the warranty work should remain the responsibility of the owner. Labor is the dealers biggest cost and his paying for the work to be done twice is punishment enough on the issue of assuring the vehicle's integrity on their work. As to them releasing the vehicle, they had no choice, they can not keep your car without some type of lien.
    BUT, they are guilty of not fessing up to the suddenly unsafe and unsound condition of your vehicle and for not forewarning you of the danger of operating the vehicle in its current state of disrepair. I don't believe this matter meets any standard or standing for suit, since no damage was done. Still I would demand an apology while they fixed my truck, after showing them the video I took of its condition, brake pedal travel, etc., and how I was thinking of starting a YouTube channel with this video being my inaugural video, "Crooked Auto Dealers Should Be Hanged, A Parody", editing in some bad jokes and thereby deflect any libel suit.
    Yes, take it back to the dealer and impress upon him the responsibility of him making things right. This one might have standing in civil court, so if he refuses hire an attorney to write a "Demand Letter", informing the dealer he is legally responsible to return the vehicle to a state similar to when it entered his shop. Or so I believe it is written in the laws and codes of most local jurisdictions across the country, except Louisiana.
