No GPS Audio from phone
Discussion in 'Audio & Video' started by Jota21, Jul 8, 2021.
  1. Jul 8, 2021 at 12:39 PM
    Jota21
    Jota21 [OP] New Member
    i have a 2015 sr5 without navigation. I assume my bluetooth is working properly because the truck will cut off the radio when i receive a phone call and allow me to talk. It will also do the same when i get a text, and even read me the text, or display it if stopped. My problem is that i want the GPS from my phone to interrupt the radio when i'm using google maps/waze, and i can't get it to do so. Bluetooth is turned on in the Waze app, and the voice directions work when it's not connected to the truck. Any thoughts?
  2. Jul 8, 2021 at 12:51 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    For Waze, you need to change the setting to "Play as Bluetooth phone call":
    I'm sure there's a similar setting for Google Maps.
    NewImprovedRon and HulkSmurf14 like this.
  3. Jul 8, 2021 at 12:52 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    For mine the audio source also has to be Bluetooth. So if I’m using pandora it works. If I use the radio it doesn’t. Also there may be a setting in your nav app for audio to play as a phone call. Try that for times when you are not using your phone for audio.
    mountainpete likes this.
  4. Jul 8, 2021 at 1:58 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    If on iPhone and using Google maps:
    1. Go to Settings > Google Maps > Notifications > Google Maps Notification Settings
    2. You are taken to Notification Settings but you want to click on the "<" (arrow back button on top left corner)
    3. Under Getting Around go to Navigation > Play as Bluetooth phone call
  5. Jul 8, 2021 at 2:01 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    My truck only work when I connected to my music player, while music is playing.
  6. Jul 8, 2021 at 4:35 PM
    Jota21
    I dont have a "Google Maps Notification Settings" in the notifications folder under google maps settings, nor can i find anything called 'getting around'...
    It's an older iphone 7, but my IOS is up to date...
  7. Jul 8, 2021 at 6:05 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    :notsure:
  8. Jul 8, 2021 at 6:11 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You can get to it directly from Google Maps. Click your profile pic in the top right, tap Settings, then this:
    NewImprovedRon likes this.
  9. Jul 9, 2021 at 5:10 AM
    Jota21
    good thought, but it is already is...
  10. Jul 9, 2021 at 6:00 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Good info, I was having the same problem.
