No start issue
Discussion in '2nd Gen Tundras (2007-2013)' started by Jeffro22, Dec 4, 2019.
  1. Dec 4, 2019 at 11:35 AM
    Jeffro22
    Jeffro22 [OP] New Member
    2013 platinum crewmax 4x4
    Truck has been starting just a little slow first thing in the morning over the last few weeks.
    Not bad but can tell a difference. Starts kind of weak but Seems to smooth out after a few seconds
    today about the same , but after sitting for a few hours i went to start it to go to lunch and it just cranked but didn’t fire. Took 4 try’s to get it started. Ran pretty normal after that.
    yes - it is a ffv
  2. Dec 4, 2019 at 8:36 PM
    Mr. Seven
    Mr. Seven New Member
    Rolla, MO
    07 DC 4x4 4.7
    Eibach Lift Level 8 MK6 18x9 ET12 295/70R18's 4.88's Auburn JBA exhaust
    Try to prime the FP a few times before starting (key to on position (not start), then off, on, etc). If that speeds up cranking time...may be fuel pump related. Unfamiliar with FFV sensors & issues, no help there.
    NewImprovedRon likes this.
  3. Dec 5, 2019 at 8:24 AM
    Jeffro22
    Tried it this am and still seemed to start just a little funny. Smoothed out after a few seconds.
    fuel mileage seems even worse than normal. Getting 10 mpg
  4. Dec 5, 2019 at 10:29 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Battery is first thing that comes to mind for the weak starting, though that wouldn't affect mileage. Maybe spark plugs too. How many miles?
    Rex Kramer and MS22 like this.
  5. Dec 6, 2019 at 8:51 AM
    Jeffro22
    I did go ahead and test battery and it is fine. A little over 1 year old
    i have 240k on the truck but just put new plugs in a couple months ago
    ( other than the time it didn’t start) To me it’s more of a low idle/ fuel issue for first few seconds in the am. It starts but sounds like it’s about to die for a few seconds and then revs up normal. Thinking it’s the ffv issue. Maybe need a reflash? Although truck runs great and is smooth as can be. Poor mpg and that one no start issue
  6. Dec 6, 2019 at 9:01 AM
    Uhhhh....
    Dave
    7” BDS, 37s
    Not to belabor the point, but the battery can still be bad even if it's only a year. Was it tested under load?
    At 240k - maybe the throttle body needs to be cleaned? Diff vehicle, but I had around 200k on a Camry I used to have and started having idle issues - cleaned the throttle body & it was right as rain.
    Rex Kramer likes this.
  7. Dec 6, 2019 at 9:16 AM
    NWExplorer
    NWExplorer this guy
    Washington
    2010 CM Platinum 4x4
    Start with the simple things. Make sure battery connections are clean and tight. Air filter is clean. Etc. If the battery truly is good it could just be a loose/corroded connection. A few days ago I got into my truck and had absolutely no power. Everything completely dead and the battery is brand new. Wiggled the connections at the battery and it fired right up. Tightened everything down and no more problem.
    MS22 likes this.
  8. Dec 6, 2019 at 11:35 AM
    Jeffro22
    I did get battery load tested at autozone. It’s not a weak/dead battery feel. Starter has plenty of power, motor turns over Fine
    Recently wen through all the normal majntance stuff. Cleaned tb , new air filter
    NWExplorer and Uhhhh.... like this.
  9. Dec 22, 2019 at 5:48 AM
    Jeffro22
    Had this happen again last night. Turned over for about 10 seconds but no start. Took 3 tries before it started. Started kind of rough but finally smoothed out
    Based some searching here I am thinking it’s a ffv issue Thinking of taking it in for the updated flash unless anyone thinks it’s something different
    mpg’s seem worse than usual also, and normally first start in the am is a low / weak idle for a few seconds before it smooths out
  10. Dec 22, 2019 at 6:59 AM
    Jeffro22
    I’ll have to run by parts store and have them check. Would code throw a light? No lights are on
  11. Dec 22, 2019 at 10:43 AM
    Mickale
    Mickale New Member
    2008 Silver Tundra Limited
    A fucking lot.
    My truck used to have a similar issue. I would go to start and it would idle very low and act sluggish. Turns out that I had barely any oil in my truck. Did an oil change and it ran strong again. Also replaced spark plugs too, so that might have contributed.
  12. Dec 22, 2019 at 11:34 AM
    Coldjustin
    Coldjustin New Member
    Justin
    2008 Limited Crewmax
    Kenwood ddx9904s, leveled with 305/55/20 nitto terra grapplers g2's. Dual flow masters
    I'd have to lean toward the fuel pump issues noted many times on this forum. It "floods" the engine with fuel or doesn't send enough depending on the calculations the ecus are making for the amount of ethanol it is sensing. With a obd2 reader and the proper app on your phone you can monitor alcohol density and be able to tell if it's fuel pump related. May not be logical for you to purchase these things and it may be better to have the dealer check it. I went through this on my flex fuel Rock Warrior with 220k+ miles on it but mine acted different than yours. Mine had more of a miss or stumble during acceleration. But i read of crank/no start issues while searching for my answers that ended up being alcohol density related. Good luck and I feel worst case scenario you'll need a fuel pump or a fuel pump ecu.
  13. Dec 23, 2019 at 5:14 AM
    Jeffro22
    Thanks- is there a good obd2 reader that is recommended for these trucks
  14. Dec 23, 2019 at 8:13 AM
    Coldjustin
    Justin
    I can't remember which one I bought but it was pretty inexpensive. I think it was less than $30 And I had/have the torque pro app that read alcohol density. Pretty cool that you can have a code reader for $30-$40 now days.
  15. Dec 23, 2019 at 8:14 AM
    Coldjustin
    Justin
    I'll see if I can find it and post a picture. It worked flawlessly
  16. Jan 3, 2020 at 3:07 PM
    Jeffro22
    went by advance today and pulled a p1604 -startability code
    also ordered a reader today that can hopefully read alcohol content soon
    -is that mean i need a dealer visit for reflash?
  17. Jan 3, 2020 at 4:05 PM
    Coldjustin
    Justin
    Some have had success with a dealer reflash but it was a fuel pump replacement for me. I didn't have any codes though.
  18. Jan 7, 2020 at 5:43 AM
    Jeffro22
    Just got my torque pro app installed and am reading 85% alcohol!
    been running regular 87 octane (10% ethanol)
