Noise After Shock Upgrade
Discussion in 'Suspension' started by dpast88, Apr 11, 2020.
  1. Apr 11, 2020 at 4:16 PM
    dpast88
    dpast88 [OP] New Member
    Dennis
    Furlong, PA
    2015 Tree
    1A63CAFE-DFBE-4FFD-BD39-09DD37560341.jpg 2437A6F7-C251-4CD4-B513-4BB8A428CAAE.jpg 7133F57B-3F64-4BCB-AD82-C054B0018C4E.jpg D6511E37-A098-4D87-A28E-506F6027FB15.jpg Hey Gents,
    A couple weeks back I had a shop install Eibach Pro-truck leveling shocks (2.5” of lift) and Toytec Boss in the rear with a 1” shackle. Now if I make a really sharp turn (cutting steering wheel to the max like for a U turn) I hear a creak. It happens in both directions. Any ideas? I posted photos of the drivers side but am not sure what to look for.
    Thanks in advance!
  2. Apr 11, 2020 at 5:12 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Not enough info to determine the noise. But your abs wire is not in the clip on the uca.
    BTBAKER and Flyinryank like this.
  3. Apr 11, 2020 at 5:15 PM
    timsp8
    NY
    I’m assuming they did an alignment too? Was it there right after the install? Maybe it settled and needs another alignment. Check that all bolts are tight too.
  4. Apr 11, 2020 at 6:16 PM
    dpast88
    Dennis
    Furlong, PA
    2015 Tree
    Nice catch thanks!
  5. Apr 11, 2020 at 6:21 PM
    dpast88
    Dennis
    Furlong, PA
    2015 Tree
    Yes they did an alignment. I didn’t make any tight turns until pulling into my driveway at home. Planning to get new tires soon so maybe I could do another alignment then.
  6. Apr 12, 2020 at 10:43 AM
    dpast88
    Dennis
    Furlong, PA
    2015 Tree
    Bump hoping for more replies! Happy Easter!
  7. Apr 12, 2020 at 10:52 AM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    What side of the vehicle does the creak? Also I was noticing and it would be the picture the sway bar end the bolts into the LCA looks to be angled (barrel) as if it’s not really bolted.
    A lot of times suspension creak can be resolved by re-torquing once the truck has full weigh on all the components. I’d maybe ask the shop to recheck that.
  8. Apr 12, 2020 at 11:07 AM
    dpast88
    Dennis
    Furlong, PA
    2015 Tree
    Both sides creak when you turn the wheel to the max. I will try to retorque what I can get to at some point this week. The shop is over an hour ago and might not be open right now due to covid-19.
  9. Apr 12, 2020 at 11:13 AM
    vhstejskal
    Vic
  10. Apr 12, 2020 at 11:15 AM
    Seaflea
    Seaflea New Member
    William
    I think you are hitting the wheel stops. Not the suspension at all. Put a light coat of grease on them and drive it around to see if that's it.
    15whtrd likes this.
  11. Apr 12, 2020 at 1:03 PM
    dpast88
    Dennis
    Furlong, PA
    2015 Tree
    What do you mean by wheel stops? Bump stops? 1 or 2 in the photo attached?
  12. Apr 12, 2020 at 2:06 PM
    Seaflea
    Seaflea New Member
    William
    #2. Thats where Toyota trucks always seem to make a noise at full lock.
  13. Apr 18, 2020 at 8:52 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    @dpast88 did you figure this out? I just found I have the exact same issue. I installed Bilstein 6112s at 1.9”, and just today noticed a noise almost like a loud creaking noise at full wheel lock in both directions. I had an alignment done too - the truck drives fine - but at full hard wheel lock I hear the noise.
  14. Apr 18, 2020 at 9:35 AM
    dpast88
    Dennis
    Furlong, PA
    2015 Tree
    Went through and checked the torque on all the components. Didn’t find any issues. Grease came in the mail yesterday, will be greasing the wheel stops today and see if that’s the issue. I am banking on this being the fix because I only hear the noise on full lock in either direction. Will update this thread today or tomorrow.
    glowblue[QUOTED] likes this.
  15. Apr 18, 2020 at 9:37 AM
    glowblue
    VA
    Thanks for the update - please keep us posted. I’ve got some grease laying around and will try to do the same thing.
  16. Apr 18, 2020 at 10:15 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I would start with spraying the suspected movement areas with a spray lubricant one at a time. Hopefully that makes sense.
    glowblue likes this.
  17. Apr 18, 2020 at 10:34 AM
    glowblue
    VA
    I just checked one of my LCA bolts and it was way too easy to turn and doesn’t seem torqued - I am going to take it back to the alignment shop and have them recheck everything.
    When I installed my 6112s I loosened the LCA bolts which were super tight - took me and my cheater bar all we had to loosen them.
    anyone know the torque specs for the LCA bolts? It’s not in the torque spec Sticky thread.
    edit: found that the LCA cam bolts should be torqued to 207 ft-lbs. No way mine were torqued at all.
  18. Apr 18, 2020 at 1:36 PM
    dpast88
    Dennis
    Furlong, PA
    2015 Tree
    @Seaflea you da man! Greasing the wheel stops worked. No more noise.
    @glowblue you should give this a try. 2 spots in front and back of each wheel (4 total for each front wheel).
    glowblue, georgiey22 and Seaflea like this.
  19. Apr 18, 2020 at 2:19 PM
    glowblue
    VA
    Awesome glad it worked out. I suspect mine might be loose LCA bolts after my alignment - but I’ll try that too just for shits and grins.
    dpast88[OP] likes this.
  20. Apr 18, 2020 at 4:02 PM
    Seaflea
    Seaflea New Member
    William
    Thanks for the shout out. Sometimes its the little things. At least it didn't cost you much to fix
    glowblue, dpast88[OP] and georgiey22 like this.
  21. Apr 22, 2020 at 12:49 PM
    glowblue
    VA
    OK, so my noise is still present. Here is what I've done with no luck:
    1. I took the truck into the alignment shop - they tightened/re-torqued all my front suspension bolts. No fix.
    2. Greased the wheel stops both sides of each front tire - no fix.
    3. Disconnected my front sway bar - no fix.
    I am at a loss. I only installed Bilsteins set at 1.9" with Boss 1/4" shims on each coilover. Here is a video of the sound. It only occurs at or near full wheel turn in both directions while moving foward - you don't hear it in reverse.
    Any ideas?
    https://youtu.be/q8vVO3j6cIc
  22. Apr 22, 2020 at 12:52 PM
    dpast88
    Dennis
    Furlong, PA
    2015 Tree
    Jesus mine was nothing like that. Just a creak. Hoping someone here can help!
  23. Apr 22, 2020 at 1:15 PM
    AZBoatHauler
    So.Arizona
    Tire rubbing the stock splash guard. Pull the splash guard and the sound should disappear. You'll need to trim the sides to make those tires clear.
    EDDO and Hbjeff like this.
  24. Apr 22, 2020 at 1:27 PM
    glowblue
    VA
    I checked and don’t have clearance issues that I can see - I am running 275/70R18. But I’ll take the splash guard off just to rule it out.
  25. Apr 22, 2020 at 1:32 PM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    You guys are scaring me. I just got my 6112's and 5160's in via UPS today. Friday install at local lift/tire guys. I am praying that I don't have that noise come up. I will update after install.
  26. Apr 22, 2020 at 2:13 PM
    glowblue
    VA
    Ok I checked again and it appears to be tires rubbing on the stock skid plate! I’m going to take it off and see for sure but I’ll be damned... I never read where the skid plate can cause interference with 275/70R18s!
    Edit: confirmed...taking off the stock skid plate was it...I just didn't fully see the interference until now. Gives me a reason to look into upgrading to an RCI or TRD skid plate!
  27. Apr 22, 2020 at 3:21 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Don’t overthink it. I installed the Eibach Pro Truck 3” lift yesterday , no issues.
  28. Apr 22, 2020 at 3:43 PM
    glowblue
    VA
    You’ll be fine - I installed 275/70R18s on stock TRD Pro wheels and never have I come across anyone reporting issues with rubbing on the skid plate. I did my own install of the 6112s and 5100s in the back so I was worried I messed something up but my install was spot on.
    The alignment shop had to adjust the toe so possibly that caused my issues. I just didn’t think to consider the skid plate.
  29. Apr 22, 2020 at 4:16 PM
    AZBoatHauler
    So.Arizona
  30. Apr 22, 2020 at 4:53 PM
    glowblue
    VA
    Thanks - actually have me a reason to buy the RCI skid plate. I just changed my oil and thought about it since I hate removing the stock skid plate - and now this makes it easy to justify the upgrade!
