Noise when back window is down rattle and Clinging
Discussion in '3rd Gen Tundras (2022+)' started by Levo1228, Jul 24, 2022.
  1. Jul 24, 2022 at 7:28 PM
    Levo1228
    Levo1228 [OP] New Member
    Lunar rock Trd crew cab off road SR5
    When I rolled my back window down the other day it sounds like the bed is coming apart. It’s sounds more like the tailgate and the cables on the tailgate. Idk has anyone had this problem. Tks
  2. Aug 8, 2022 at 6:09 PM
    pauls22trdpro
    pauls22trdpro 2022 trdpro tundra
    2022 lunar rock tundra trd pro
    I have a 2022 tundra trd pro I just bought today makes a week …here is what Im dealing with it rite now I have 3 issues…
    1.really bad noises coming from the rear bed
    2. Rattling noises on my rear window win down
    3 my qi wireless charging pad works for few seconds them shows stopped charging…then goes back on then stops that’s how it operates…I was told to take out the phone case if that don’t work then there is something wrong with the qi charging pad …which I think is whacked if it is
    Troyboy84 likes this.
  3. Aug 9, 2022 at 8:28 AM
    fat_marshmallow
    fat_marshmallow New Member
    i just noticed this yesterday also, i normally have the back window down but i normally listen to my music at a higher volume and never noticed it. yesterday i noticed it for the first time. sounded like a loose sway bar endlink but from the mid/back of the cab. drove all day with no music just to pinpoint it. seems like its only happening at bumps going under 10mph. i spent an hour banging everything under the truck to try to duplicate it but couldn't. then i rolled the back window up again and the rattle went away. maybe something with the rear window.
  4. Aug 9, 2022 at 8:31 AM
    Craftty1982
    Craftty1982 New Member
    Rich
    When I picked my truck the other day I noticed the chain for the spare tire hanging down. Could it be that? I haven’t driven around with the window down yet.
  5. Aug 9, 2022 at 9:43 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Its the cables that hold the tailgate to the bed- go grab them and move them. Also the cables for the lock inside the tailgate make a racket- going to rubber wrap those.
    Levo1228[OP] likes this.
  6. Aug 9, 2022 at 10:19 AM
    Craftty1982
    Rich
    Ok. Just went for a drive. I hit every bump I could. Sounded like the tailgate was falling off. Ugh
  7. Aug 9, 2022 at 12:25 PM
    pauls22trdpro
    It’s both the rear window area when it’s down and when the window is up I get loud sounds from the bed area sounds like if it sway links going but it’s not …my trd pro is going to the dealership on Aug 30 2 guys from Toyota coming down to drive my truck without the bed and see where it goes from there …
    The other thing I noticed the qi charging pad works without the phone case with phone case does not operate correctly just an fyi or
  8. Aug 9, 2022 at 1:05 PM
    Craftty1982
    Rich
    My qi works with a case. Not that helps you but it’s should work with a case.
  9. Aug 9, 2022 at 1:09 PM
    pauls22trdpro
    I wonder if it’s cause my phone … ‍♂️ I have iPhone XS Max it’s weird tho my wife has iPhone 8 and does the same thing like mine did works for a few seconds then stops charging then works again then stops charging and if I remove the case now it stays charging weird ….now with the noises from the back is a crazy one ‍♂️ ‍♂️
  10. Aug 9, 2022 at 6:08 PM
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    My tailgate rattles a bit too. Here's the thing... I think they could fix it with thicker rubber bump stops. But that would make it harder to close the tailgate. You would have to "slam it" shut, but then it probably wouldn't rattle. I rather like how easy it is to close the tailgate, and I know it is positively latched and shut. If I had thicker bumpers and I slammed it shut, then I would wonder if it shut all the way, and open it and re-slam it... I've become ok with the tailgate rattle. I feel better about a little play in the tailgate vs making it too tight. Just my opinion.
  11. Aug 9, 2022 at 7:37 PM
    DexterL
    DexterL New Member
    I put some felt pads on the tailgate where they hit the bumpers, helped a good bit, but still rattles
  12. Aug 14, 2022 at 9:58 AM
    Craftty1982
    Rich
    I really think the louder thuds is the tailgate hinge itself. I can grab my tailgate and move it up and down enough to make me think that when I hit a bump that’s the cause.
  13. Aug 14, 2022 at 5:20 PM
    pauls22trdpro
    I’m not sure if that’s the cause because I went to the Toyota dealership and inspected the hinge on that tailgate and did the same on a new 1794 also a buddy of mine has a Tacoma and does the same on the hinge …and I also had gotten a few things at lowes and had weight on the tailgate when it was close and still does noise when I went over bumps and I would of thought that could help the issue….so in my opinion I don’t think it’s the tailgate…mite be the actual bed or something loose underneath the bed where the frame is ‍♂️….my truck is going back to the dealership on Aug 30 so hopefully I can get an answer
  14. Aug 14, 2022 at 6:47 PM
    deepdesign
    deepdesign New Member
    I really think it’s the bed rattling. When I look in side mirror it’s as if the bed is shaking.
  15. Aug 15, 2022 at 12:25 PM
    pauls22trdpro
    It’s definitely a mystery for sure … I think it’s in the frame area needs to be tightened or a broken part ….I know they retourqed the bolts hold the bed down and didn’t fix it also ‍♂️
  16. Aug 15, 2022 at 12:42 PM
    Breathing Borla
    Northern Illinois
    could it be something in the 5 link ?
  17. Aug 15, 2022 at 12:50 PM
    deepdesign
    I was told it that it was tailgate. And a field tech made an adjustment today. I’ll pick it up tonight and check it out
  18. Aug 15, 2022 at 1:16 PM
    pauls22trdpro
    Two weeks ago when I dropped off my 22 trd pro for the noise they drove my truck with the tailgate and still did the noise they believe it’s to do with the bed ‍♂️
  19. Aug 15, 2022 at 1:18 PM
    deepdesign
    without the tailgate?
  20. Aug 15, 2022 at 2:06 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    Have you checked the exhaust? I had a rattle I took weeks trying to find… ended up being one of the clamps on the exhaust just needed tightened… good luck
    AND likes this.
  21. Aug 15, 2022 at 2:34 PM
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    What is the temperature when your phone wont charge? I noticed, if its hot out and when I first get in it will not charge until the cab cools down. And it will keep cycling back and forth until it is cool enough and then my phone charges with no issues. And I have a case. I have heard about this issue from other owners. I am not sure if the heat is the problem, but I convinced myself it is.
  22. Aug 15, 2022 at 3:54 PM
    pauls22trdpro
    The technician took out my tailgate and drove it around and still made the noise ….also I take out my phone case and place my iPhone on qi charging pad and it does work better that’s what they’re gonna tell u it’s whacked but ‍♂️ …I know my 2020 Silverado high country that I had never had an issue with that …all these cars and trucks have pros n cons
  23. Aug 16, 2022 at 11:40 AM
    deepdesign
    Ya so they adjusted my tailgate and it’s quiet now. But who knows like they would admit that the back of the truck was not on all the way.
  24. Aug 16, 2022 at 11:47 AM
    nrm91
    nrm91 New Member
    Boise, ID
    2022 Platinum CrewMax Magnetic Grey
    35/11.5/20 Toyo AT III's
    Where on the tailgate did you put the pads? Got a pic?
  25. Aug 16, 2022 at 11:52 AM
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    Do you know what exactly they did to adjust the tailgate?
  26. Aug 16, 2022 at 11:59 AM
    deepdesign
    You know honestly I have no idea what they did exactly. There was a Toyota field technician from Toyota at my dealership who was aware and what to look for and told the dealership what kind of adjustment to make. Update: here is a photo of the receipt.
  27. Aug 16, 2022 at 12:02 PM
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    Would it be too much to ask the dealer the exact fix they did? I think lots of us would be super grateful on this information, as most of our dealers don't want to do anything about it!
    Breathing Borla likes this.
  28. Aug 16, 2022 at 12:07 PM
    deepdesign
    I update my post with what they did.
    jproy12[QUOTED] likes this.
  29. Aug 16, 2022 at 12:08 PM
    Craftty1982
    Rich
    Seems like almost all trucks do it
  30. Aug 16, 2022 at 12:11 PM
    deepdesign
    Yeah. I can still here some noise back there but I’d say it’s about the same as my 2013 tundra now. Before it was extremely loud and annoying and I’d cringe every time I heard it. Now I have to really try to listen for noises.
