Noob looking for shock input for 2015
Discussion in 'Suspension' started by Abrax, Mar 5, 2025.
  1. Mar 5, 2025 at 1:55 PM
    Abrax
    Abrax [OP] New Member
    Currently my truck is all stock, 2015 tundra, double cab, SR5 with 4x4. 70k miles. It's my daily driver and I like it as a jack of all trades type vehicle. Dailies well, can tow/haul if needed, 4x4 for snow or the occasional mild off roading. Love it honestly. She's paid off and i'm doing some cosmetic changes like new grill, lights, bumpers, etc. to fix some damage and make it "mine".
    I am planning on swapping out the front and rear bumpers with something that will be a bit heavier than stock. Going for this bumper: https://rcimetalworks.com/product/arapaho-front-bumper-14-21-tundra/ which is should be ~125lbs + the lights (using the diode dynamics through RCI to save a bit). I do not have plans to add a winch at this time.
    Going after this rear bumper: https://www.fabfours.com/p-fab-fours-bumper-tt14-w2850-1 - Having a tough time finding the exact weight on this one. The 3rd gen tundra one from fab fours I found listed between 75 - 115 lbs here: https://theyotagarage.com/products/...BKn_xI6EDzsSpx0BEWArjCq_Y_tRNariBHLp3xMLfNay7
    So after doing some reading on the forums about weight of stock bumpers I think i'm in for something in the ballpark of ~50lbs increase in the front and rear (so ~100lbs total)?
    I'm looking at this set of bilstein stocks, i want new coils too. https://www.shocksurplus.com/produc...-toyota-tundra-4wd-rwd?variant=32514784690225
    Would you think this coil is good enough if I don't plan to add more weight? I asked the guys at shock surplus this same question and they said a heavier spring for such a little (?) increase in weight wouldn't be needed.
    I do not want to completely level my truck but I am ok taking away some of the factory rake. No plans to lift the rear. I'm thinking of going with the circlip at position 2. As in not the lowest possible setting but 1 up from there. I'm thinking that should level me out just a bit and be plenty comfortable for driving?
  2. Mar 5, 2025 at 8:01 PM
    Panda21MGMcMax
    Panda21MGMcMax New Member
    San Diego
    2021 MGM 4x4 CrewMax Limited
    RobertD, memario1214 and Rodtheviking like this.
  3. Mar 6, 2025 at 5:09 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    :bowdown:
    There's a whole lot to unpack here, and I definitely think it's worth just giving me a buzz whenever you get a chance! My line over here at Hotshot Offroad HQ is 406-936-0206. I can get you everything from the front and rear bumpers to the suspension, and likely save you a little bit across the board. I can also help answer questions about weights, spring rates, etc so that you're not left wondering if you're doing it all right.
    I can still answer some of the quick questions though. Rear bumper will add ~70lbs over your stocker. Since you're not adding a winch the stock Bilstein 6112 spring should be just fine.
    RobertD likes this.
  4. Mar 6, 2025 at 6:11 PM
    RobertD
    Robert
    DFW, Texas
    :anonymous:
    Shit.... is this a concern? Guess I need to add a topic to my running messages to you
    @Abrax Colton (aka @memario1214 ) is an awesome vendor. He works to help you understand your options and works to find the best product that fits your needs and budget. He doesn't just try to up sell you. Also, talk with him on prices before ordering from other places. I bet he can save you money on most the things you plan to buy and he is incredible to work with. One of the few companies with really good customer service.
  5. Mar 6, 2025 at 6:20 PM
    memario1214
    Colton
    Missoula, MT
    Full plate bumper + winch + almost always some sort of lights can add up to taxing spring rate. Your upcoming setup should be just fine as well.
    RobertD[QUOTED] likes this.
  6. Mar 6, 2025 at 7:23 PM
    Abrax
    Bro I wish I knew that a week ago! I've been slowly buying all my parts over the last couple weeks and the ONLY thing left was the shocks. Thanks for confirming the 6112 spring should work fine. If I had not put in an order from shock surplus already I'd give ya the deal. Didn't think to come to the forums before buying all my parts and trying to do a one big order.
    RobertD likes this.
