NorthStar 27F Finally Installed
Discussion in '2.5 Gen Tundras (2014-2021)' started by HaydenF, Mar 14, 2020.
  1. Mar 14, 2020 at 6:47 PM
    HaydenF
    HaydenF [OP] New Member
    Hayden
    2016 Limited Tundra Crewmax
    3.5 Zone Lift, 35x12.5x18 Nitto Ridge Grapplers, 18x9 Fuel hostage 3 Grey
    Well I finally got around to install the NorthStar AGM battery today. I also bought the HKB alternator booster fuse and with a voltage tester I’m getting the correct 14.6v output which NorthStar recommends. The GP audio distribution post really cleans everything up. Pics below
  2. Mar 14, 2020 at 7:23 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I've never heard of a alternator booster.......what exactly does it do?
  3. Mar 14, 2020 at 7:33 PM
    Stig
    Stig New Member
  4. Mar 14, 2020 at 7:38 PM
    HaydenF
    Hayden
    The Alt-S fuse on our tundra limits the alternator output to a max of 13.8v. All AGM batteries are designed to have a higher charge profile at 14.6v. Oddsey, Optima, NorthStar all say to achieve a float charge (topped off) we should be delivering 14.6v. Anything less will/could damage the battery over X amount of time and you would never achieve 100% capacity.
    There are other manufacturers with a fuse that only cost you $5.
    I went with the HKB $50 fuse but I like the built in safety features of the HKB..
    https://www.tundras.com/threads/cus...ging-profile-for-odyssey-agm-batteries.58290/
    RitcheyRch likes this.
  5. Mar 14, 2020 at 8:07 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    How do you like the ridge grapps?
  6. Mar 14, 2020 at 8:21 PM
    Danimal86
    Daniel
    Sacramento, CA
    I'm rocking the same battery....ill have to look into this
    619Tundra likes this.
  7. Mar 14, 2020 at 8:44 PM
    HaydenF
    Hayden
    Quietist hybrid tire on the market in my opinion. Love them.
    14burrito[QUOTED] likes this.
  8. Mar 14, 2020 at 8:52 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Thanks, trying to figure out what to switch out to from my KO2s.
    I really loved my Cooper Maxx, except at the boat ramp....so trying to find something like those that will have good wet traction. Between ATIII and the Ridge Grapps.
  9. Jan 25, 2021 at 9:28 AM
    Paulismydog
    Paulismydog New Member
    2020 Black Limited Double Cab
    Hi. I've researched but wanted opinions. I have new northstar 27f. I want to swap out without losing my truck settings. I have a Noco gp150 and a Ctek 7002. Any suggestions as to best method. Thanks. Bob
  10. Jan 25, 2021 at 9:34 AM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    How long did it take you to get the fuse? I see they're are in Australia.
  11. Jan 25, 2021 at 9:41 AM
    Danimal86
    Daniel
    Sacramento, CA
    I didn't loose any truck settings when i swapped my battery. I would say you are more likely to mess something up by trying to keep voltage to the battery terminals than just quickly swapping the battery.
  12. Jan 25, 2021 at 9:42 AM
    Danimal86
    Daniel
    Sacramento, CA
    I think mine took 2 months back in April 2020, so it might be a little quicker now.
    619Tundra[QUOTED] likes this.
  13. Jan 25, 2021 at 10:24 AM
    Paulismydog
    Thank You.
  14. Apr 14, 2021 at 12:20 AM
    Blue Thunder
    Washington
    Just a FYI. I picked up my Northstar 27F today from a local dealer and it was their last one in stock. They told me Odyssey bought them recently and is discontinuing the entire Northstar brand.
    Get one while you can...
  15. May 30, 2022 at 10:04 PM
    seahaul
    seahaul New Member
    Just noticed there is now an odyssey 27F battery online. Looks exactly like the northstar except its red. I reached out to the battery world store and they said its the same battery.
  16. May 31, 2022 at 5:59 AM
    Blue Thunder
    Washington
    Nice. Hopefully it is just a re-brand
    Tundra14Platinum likes this.
  17. Jun 2, 2022 at 6:38 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    Yep got my 2+ northstar installed an added the hkb. Only took me two tries on the hkb install. 50 50 chance on installing right the first time ,an I lost . Lol
  18. Jun 2, 2022 at 6:54 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Same here on the HKB :fistbump:
  19. Jun 2, 2022 at 7:07 AM
    Ericsopa
    Ericsopa Old man and the sea
    Both Odyssey and Northstar batteries are owned by Enersys, and have been for a while. All the Northstar Pro series batteries have been replaced by Odyssey Extreme. But it's really the same battery. The old Northstar number was NSB-AGM27F and the new Odyssey number is ODX-AGM27F.
    Next up ..... the $1500+ lithium ion battery ....... :eek:
    texasrho83 likes this.
  20. Jun 2, 2022 at 7:29 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The Northstar looks way better :crapstorm:
    619Tundra and Ericsopa[QUOTED] like this.
