not cranking
Discussion in '2nd Gen Tundras (2007-2013)' started by divemech, Apr 1, 2017.
  1. Apr 1, 2017 at 6:12 PM
    divemech
    divemech [OP] New Member
    shawn
    08 black SR5
    have an 08 SR5. been driving fine. stopped at a store earlier, came back out and truck does not crank. cleaned the battery posts, battery putting out 12.3v. no crank, nothing. just a "click" and thats it. tried jumping it, nothing. same thing. didn't see any bad fuses. will go through them all tomorrow and check for continuity. thinking it's the starter. anyone else have this problem?
    GNTundra likes this.
  2. Apr 1, 2017 at 6:38 PM
    Starter solenoid/contacts are shot.
    Wonder if Toyota offers rebuild kits like those crappy "Merica" trucks?
    GNTundra and divemech[OP] like this.
  3. Apr 1, 2017 at 8:44 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Starter.
  4. Apr 1, 2017 at 8:46 PM
    thumper7799
    thumper7799 Bad Girls Drive Bad Toys!
    Erika
    2007 Nautical blue Tundra SR5 duel exhaust
    I know this one! Yes, it is the starter. It happened to my '07. The only problem I've had with it.
    NewImprovedRon and GNTundra like this.
  5. Apr 1, 2017 at 9:04 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Thank you, Doctor.
    Shall we go get a manwich now?
  6. Apr 1, 2017 at 9:06 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Open circuit battery voltage of 12.3V means nothing. If you measured that while the key was turned to the start position, then it's meaningful. Start with a battery load test. If the battery is good then the solenoid contacts would be the most likely.
  7. Apr 2, 2017 at 2:45 PM
    divemech
    shawn
    08 black SR5
    thank you everyone. replaced the starter and she started right up. awful design of how they have set it up in there. was able to replace it without having to drop the exhaust. good day of wrenching
