Now What?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Inferno16, Sep 30, 2016.
  1. Sep 30, 2016 at 8:01 PM
    Inferno16
    Inferno16 [OP] New Member
    Spyer HL with HID conversion kit
    Spyder HL
    single row LED with Headlight Revolution bracket. Forgot to take pic with GTR LED fog lamp.
    Spyder tail light with GTR Reverse LED bulb
    KRN FED (E85)
    BIL 5160 rear
    Bil 5100 set top
    Toytec Shackles set max top
    What now?? Wheels and tires?? Any suggestions.
  2. Sep 30, 2016 at 8:18 PM
    ToyotaTundraMike
    2015 Tundra
    Got a link for the bracket you used on the lightbar? Looks good!
  3. Sep 30, 2016 at 8:22 PM
    Inferno16
  4. Sep 30, 2016 at 8:23 PM
    Inferno16
    I thought it was headlight rev. but it's rigid ind.
    SouthBoundSteve likes this.
  5. Sep 30, 2016 at 9:48 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Want M/T or A/T tires? What offset are you looking for on your wheels?
  6. Sep 30, 2016 at 10:27 PM
    Inferno16
    AT but with some ballzy treads. As for offset, +18 = +20?? i would like it to stick out past the fenders an inch?
  7. Sep 30, 2016 at 10:32 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Which light bar did you get? That's the same place I wanted to get one for. Thanks!
  8. Sep 30, 2016 at 11:19 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Toyo at2's what I have and I love them.
    Duratracs, terra grapplers (might not be as ballsy as you want), st maxx, and toyo RT's should be up your alley
    As for wheels
    Black rhino, method, fuel, FN BDS, raceline, plenty other brands have good 18-20 offsets. All about what blows your skirt up!
  9. Oct 1, 2016 at 12:57 AM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    How was it installing the light bar? And what light bar did you go with? I really wanna put one my truck
  10. Oct 1, 2016 at 1:43 AM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    Nice truck! Color matched (or plasti-dipped) bumper ends would go a long way. Tires and wheels would definitely take it to the next level.
  11. Oct 1, 2016 at 4:21 AM
    Cox3497
    Cox3497 New Member
    Toyota Tundra Crewmax
    Super Nice Truck, man! Quick question for ya. I too have bilsteins on the front and Toytec shackles on the back. Had them installed 2 weeks ago. I also had the poly bushings installed, and I am getting a crazy amount of squeaking now from the rear suspension. Thinking about taking it apart and greasing everything up with some lithium grease. The dealer installed (and scratched the paint on the rear door in the process, ugh) and I don't know if they used any grease on the new bushings. Have you had any similar problems? I read of one other guy (either here or on another forum) having the same problem. Thanks!
  12. Oct 1, 2016 at 6:20 AM
    TexasMofo
    TexasMofo New Member
    Chad
    Great Country of Texas
    2017 Toyota Tundra TRD Pro
    Illegal Tint 2 Shims/ 3 inch Shacke
    Post a close pic of the mounting for the light bar in the bumper. Looks good!!
  13. Oct 1, 2016 at 8:20 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Do you have the stock tires on there? Im about to get the same suspension setup and was curious if you could post a picture of the side so I can see what it looks like with the stock michelins.
  14. Oct 1, 2016 at 8:24 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Nevermind. I just looked at one of your older posts and saw it. Looks good!
  15. Oct 1, 2016 at 1:10 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Looks great! +20 offset wheels would be perfect.
  16. Oct 1, 2016 at 5:21 PM
    GilyMonster
    GilyMonster New Member
    Trey
    2016 Tundra 1794 6in lift 4x4
    6 inch Procomp Lift, 20in Fuel wheels with Toyo RT tires, Retrax matt black electric bed cover, AMP retractable steps, etc will add the few other things on the truck later
    I like the Toyo R/T . I've had a set of Toyo A/T and there both great tires but I like the look of the R/T better.
    Law323[QUOTED] likes this.
  17. Oct 1, 2016 at 6:45 PM
    Inferno16
    any of these 30" single row LED.
  18. Oct 1, 2016 at 6:45 PM
    Inferno16
    GoHuskers likes this.
  19. Oct 1, 2016 at 6:50 PM
    Inferno16
    No squeaks here... but crawl under your truck and add grease top and bottom of shackles where the nuts and bolts are.
    Cox3497[QUOTED] likes this.
  20. Oct 1, 2016 at 7:07 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Agreed. I love the RT's. I may get them in a 275/70 or the AT's in 295/70 next time around. I gotta keep the weight relatively low since I got the 4.6L
    I swear when time comes around to get a new tundra, I'm getting the damn 5.7L LOL
    zcarpenter92, veg hed, rons23 and 2 others like this.
  21. Oct 1, 2016 at 7:23 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Toyo/Nitto FTW.
  22. Oct 1, 2016 at 8:25 PM
    GilyMonster
    Trey
    FTW? Is that referring there made by the same company?
  23. Oct 1, 2016 at 8:27 PM
    Inferno16
    I would have to remove the front grill to get a better pic but It's actually very easy to install. My suggestion though is to remove the grill when installing as you'll have a clear view of what you're doing. I did it all from under the truck. Don't have to remove skid pad or anything. There are 3 screws left and right side that hold the bumper cross beam. you need to remove 2 screws from both sides, install the bracket and tighten them up. BUT I eventually had to remove the front grill to shave a small amount from the bracket that was rubbing against the cross beam. I think another member here also had this rubbing issue that caused squeaking noise.
  24. Oct 1, 2016 at 9:04 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Same company. Same rubber compounds and very similar tread patterns across their product lines as well.
    zcarpenter92 likes this.
  25. Oct 2, 2016 at 6:22 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Law, I made that terrible mistake buying my first Tundra, won't happen with next Tundra. I'm also concerned about moving up to a 295/70/18. I will probably just go up to 275.
  26. Oct 2, 2016 at 6:27 AM
    veg hed
    veg hed Thug
    Utah
    2016 Ta-Tundra Barcelona Red
    Nice truck...I second color matching the chrome with the grill. :thumbsup:
  27. Oct 2, 2016 at 7:22 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    The 275 AT is just fine. No power loss and speedometer is SPOT ON. I think as long as I don't go MT in 295, it'll be fine.
    SuperSilverTundra likes this.
  28. Nov 9, 2016 at 7:08 PM
    Inferno16
  29. Nov 9, 2016 at 7:24 PM
    Inferno16
    and then this happened today.
    driverdog and CaptTyler like this.
  30. Nov 9, 2016 at 7:33 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Very sexy! What size BFG's did you go with
