o2 Bank 2 Sensor 2 Installation
Discussion in '2.5 Gen Tundras (2014-2021)' started by mzim, Feb 8, 2025.
  1. Feb 8, 2025 at 6:25 AM
    mzim
    mzim [OP] New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    Long story short, truck needs a new bank 2 sensor 2 oxygen sensor. Dealer has ordered the part and wants 374.00 to install. Looking at good ol you tube for this install, it looks easy enough. My question is, if I install the sensor, is there any calibration or anything like that after install? Also, what side is the B2S2 on? Thank you. -- Max
  2. Feb 8, 2025 at 7:10 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    It's on the passenger side, and no recalibration is needed, you should disconnect the battery first however before you start anything, then reconnect once everything is done.
  3. Feb 8, 2025 at 5:42 PM
    mzim
    Max
    Waterloo, Iowa
    Thank you mucho. I'm going to fix it myself then.
    ChesterTundra likes this.
