O2 sensor wiring (downstream) took a hit when Trans was replaced.
Discussion in '1st Gen Tundras (2000-2006)' started by John TRD helena, Jun 21, 2024.
  1. Jun 21, 2024 at 10:37 AM
    John TRD helena
    John TRD helena [OP] New Member
    2001 Tundra sr5
    Downstream o2 sensor connectors were cut off and wires twisted together when Trans was replaced. Need to purchase o2 sensor Denso probably and need to know how to wire it in. Can't use connector ends on sensor or harness for reference cuz they be gone. Do they sell connector end for harness side?
  2. Jun 21, 2024 at 10:39 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Wire colors don’t match?
  3. Jun 21, 2024 at 1:54 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Is your truck V8 or V6? I copied the link for the oxygen sensor connector for a V8 from RockAuto for you. Modify to V6 if you need that instead.
    https://www.rockauto.com/en/catalog...l-connector,oxygen+(o2)+sensor+connector,2604
  4. Jun 21, 2024 at 2:15 PM
    I’d cut another harness from another truck on scrapyard.
    Check the Megathread for a link to the electrical wiring diagrams (EWD) for colors if needed, but if you get from another truck with matching engine and cab and roughly year, I would expect a match (different cab, different engine, different year … not so much)
    Use the parts lookup tool @ www.densoautoparts.com to find the correct part for your truck, since different cabs/years/engine/drivetrain use different part numbers.
  5. Jun 21, 2024 at 2:47 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    There’s a special place in hell for idiots who cut OEM wiring harnesses and connectors. They should be banished to diving PT Cruisers.
    artsr2002 and shifty` like this.
