O6 SR5 DC Fog Light Add
Discussion in '1st Gen Tundras (2000-2006)' started by Seepick1, Feb 28, 2025.
  1. Feb 28, 2025 at 2:05 PM
    Seepick1
    Seepick1 [OP] New Member
    VA
    2006 SR5 Dual Cab 4.7L
    Read few different threads and seen a lit of good idea information, but wanted to confirm with those who have experience.
    My SR5 does not have fog lights. I want them.
    At first, its read that the blank switch on the dash was hooked up for the fog lights. Then I read that on my model truck, that blank switch is actually for the rear windshield defroster.
    Based on this, I would need to order a new steering column stem which includes a switch for the fog lights, which my current stem does not have.
    However, on my center console sole, there appears to be a switch for the rear windshield defroster, so i am not 100% which way to go. Been warm out so haven't had a chance to test it.
    The switch to install on the dash is no longer in production, and difficult to source, so I don't want to play the guessing game and waste time that i don't have chasing parts and spending money.
    Any information would be appreciated!
    Here are some pics of my dash and light stem for reference.
  2. Feb 28, 2025 at 2:38 PM
    You are mistaken.
    In the post-2003 trucks, fog light control is on the stalk. You need to update your stalk to have fog light controls. Someone must've swapped your stalk?
    The oval button you circled is for the RSCA (side curtain air bag) control.
    The button in the center dash you circled is for rear view mirror defrost, I believe? Or rear window. I'm too lazy to look.
    I know nobody bothers, but I'm 90% sure reading your Owners Manual - I know, I know, it's a radical concept - would have told you this :rofl:
    Kimosabe and jpink like this.
  3. Feb 28, 2025 at 2:39 PM
    Reference on RSCA:
    G_unit3000 and Seepick1[OP] like this.
  4. Feb 28, 2025 at 2:51 PM
    Seepick1
    VA
    Appreciate the input. I suspected I needed a new stalk. Yes, I do actually reference the owners manual all the time, but often times, it mentions things such "for models equipped with..." and honestly, after 20 years and 2 previous owners, I dont know what they did or what it was equipped with. I assumed from what I've read that I was going with the stalk, which is preferable anyway.
    shifty`[QUOTED] likes this.
  5. Feb 28, 2025 at 2:54 PM
    Definitely need the stalk. Watch out for aftermarket parts. You need to OEM part number? There's a 25% off sale at my go-to dealer, and they do no-tax and free-ship on anything over a certain dollar amount.
  6. Feb 28, 2025 at 3:02 PM
    Seepick1
    VA
    Which dealership? I usually use Ourisman Toyota of Ruchmond, formerly Mcgeorge.
  7. Feb 28, 2025 at 3:06 PM
    https://autoparts.serratoyota.com ==> This is specifically their Birmingham AL location, I won't deal with the other one farther south in AL. As long as you don't live in AL, they don't seem to charge tax.
    The 25% off sale starts March 1st.
    FYI, and I'm linking these directly at their site...
    G_unit3000 likes this.
  8. Feb 28, 2025 at 3:09 PM
    Seepick1
    VA
    Thanks!
  9. Feb 28, 2025 at 3:10 PM
    Np, just make sure you wait until 3/1/25 to order, and note: You will not see the discount applied until you make it to the checkout page.
  10. Feb 28, 2025 at 3:13 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    You are correct on both counts and OP can verify if mirror heater installed by the 15A MIR HTR fuse and MIR HTR relay in engine bay.
    TGIF :)
  11. Feb 28, 2025 at 10:03 PM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    I just added fog lights to my 2006 DC SR5. Yes, I had to change the stalk. There are a TON of used OEM ones on eBay as they are easy to uninstall from a wrecked or rusted one to sell. Don't eff about with a non OEM one.
    HOWEVER, you also need the relay. I had purchased the relay for 20 odd bucks, as everything said it was required. Went to install it and turns out the relay was already there. So have a feel behind and make sure the relay is not already there. You want to feel behind the fuse panel that is by the drivers left knee. Three relays on the rear of that at the bottom. Middle one is the one for the foglights. It it is empty, you need to buy one,
    Seepick1[OP] and G_unit3000 like this.
  12. Mar 1, 2025 at 7:05 AM
    Pic of '05-'06 DC fusebox from behind, with relays if it helps support what you're saying, with relays numbered. Stolen from fleabay.
    Fragman[QUOTED] likes this.
  13. Mar 1, 2025 at 7:05 AM
    Seepick1
    VA
    Glad I logged on here first. I was right about to order one. Thanks!
    PNW15 likes this.
  14. Mar 3, 2025 at 3:07 PM
    Seepick1
    VA
    So specifically, which relay number are we talking about here #3?
  15. Mar 3, 2025 at 3:15 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    for your 06 DC, it's down at bottom middle, n0. 6 in above pic....
  16. Mar 3, 2025 at 5:23 PM
    Fragman
    Fragman New Member
    TX
    BubbaW beat me to it. Number 6.
    shifty` and Seepick1[OP] like this.
  17. Mar 3, 2025 at 5:38 PM
    Fragman
    Fragman New Member
    TX
    Oh, one more thing! You want the Sequoia foglights. The Access /Regular cab ones will click into place, but the rear adjuster part on those is of a smaller diameter, so do not 'fill the hole' that they go into. The Sequoia ones come with a little doohickey that will fill that hole and stop the foglight from flopping up and down.
    Adjuster should look like this
    Not this
  18. Mar 3, 2025 at 5:48 PM
    Seepick1
    VA
    Interesting. I was looking at getting a set of LED fog lights from trail runner. I'll have to confirm fitment with them before I order anything.
    Thanks!
  19. Mar 3, 2025 at 6:01 PM
    Fragman
    Fragman New Member
    TX
    You can look quickly under your truck and see where the fog light will fit into (just need to undo 3 10mm bolts) You'll see the hole at the rear that the adjuster will poke through once installed. You'll see what I mean then.
    Ask me how I know! Of course, if I had paid attention to the mega thread, I would have triple checked the fit and not relied on eBay assuring me it would fit. Fortunately, the seller was great and took the return.
    However, once you have the 3 parts (relay, lights, switch), it is literally a 20 minute job. Quicker if you're younger and can get up off the ground easily!
    Seepick1[OP] likes this.
  20. Mar 3, 2025 at 6:10 PM
    Seepick1
    VA
    Well, I'm not "old" but I have a 2 or old boy and a 2 week old girl, so 20 mins is hard to find, but i can figure it. I managed to get new suspension installed over a weekend before the baby came. Priorities!
  21. Mar 3, 2025 at 6:14 PM
    You're in like company, my brother. Many of us have been there and done that, living life in 2-3 hour segments, which actually translates to 20-30min projects when reality sets in.
    You'll get there!
  22. Apr 18, 2025 at 9:27 AM
    Seepick1
    VA
    So back to this thread...
    Installed yellow led fogs from Trail Runner. Also bought a used fog light stalk off ebay, and bought an oem relay online.
    Fogs do not turn on. Can't figure out what the issue could be, other than a bad stalk. Checked the kick panel and the 15amp fuse is fine.
    Any suggestions? Might order a cheap stalk and test it out, but I'd love to hear any other thoughts.
    Also, i don't believe it is a resistance issue. No other lights are having issues. If it is a stalk issue, none of the other lights are affected. Pics for reference
  23. Apr 18, 2025 at 9:33 AM
    Did you follow the instructions here on the forum to add the necessary relay, I think in the engine bay? Is there a fuse you need to pop in? Maybe @Fragman or @BluegrapeVr6 can provide some insight.
  24. Apr 18, 2025 at 9:36 AM
    Seepick1
    VA
    I added the relay behind the fuse panel underneath the steering wheel, but i was not aware there was a 2nd relay to add in the engine bay.
  25. Apr 18, 2025 at 9:37 AM
    Seepick1
    VA
    This is the one I added
  26. Apr 18, 2025 at 11:08 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    There's not but 1 fog relay, which is the one you inserted.
    With no key in ignition to keep noise down(door open chime), if you turn your head lights on and semi stick your head down in the fuse panel area, you should hear the fog relay energize/de-energizing as you rotate fog light switch on/off.
    shifty` likes this.
  27. Apr 18, 2025 at 11:11 AM
    Thanks for confirming. I guess it's worth mentioning also, if the high beams are on, or if the truck thinks the high beams are on (because of LED headlights, or whatever), the fog lights won't turn on.
    IIRC, they also won't turn on unless the headlights are on? I forget, I know there's something weird with mine where I can't just have the fog lights on, I have to have at least the park lights on or something. So if @Seepick1 maybe disconnected his DRL harness next to the battery, I wonder if that would impact things?
  28. Apr 18, 2025 at 11:15 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    That’s reason I mentioned turn headlights on is because A…. they have to be on(low beam) for fog lights to work and B…. in above picture he posted, it appears but can’t really tell but fog light sw was on but head lights off ??
    shifty` likes this.
  29. Apr 18, 2025 at 12:42 PM
    Seepick1
    VA
    I have not unplugged any harnesses of any kind. High beans are no engaged while I am attempting to flip on the fogs.
    In regards to truck thinking high beans are on because the lights are LED, does anyone have experience with this, specifically with the trailrunner units? Idk how i'd diagnose that, other than connecting voltmeter while someone kicked on the lights
  30. Apr 18, 2025 at 12:44 PM
    Seepick1
    VA
    And yes, it is standard on all US vehicles that fogs disengage when high beams are on. Not sure if it's because of state or federal laws limiting forward facing illumination to 4 lights total.
