OBD 2 Port Splitter
Discussion in 'Electrical' started by MadMaxCanon, Mar 4, 2023.
  1. Mar 4, 2023 at 7:07 PM
    MadMaxCanon
    MadMaxCanon [OP] New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I am trying to have my Ultragage and Veepeek simultaneously plugged into the OBD port so I don't have to switch them out and I wanted to have a switched splitter so I can switch between the 2 without removing anything. Will this item below do that?
    https://www.ebay.com/itm/332904437759?epid=2029457064
  2. Mar 4, 2023 at 7:13 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Should be fine. I’ve been using this one for a year or two with no issue, running my Maestro stuff and OBD Fusion at the same time. I feel like there’s something else hooked up but can’t remember what.. maybe remote start?
    OLLGEN OBD2 Splitter Cable,OBD-II Extension Cable,1 Male to 3 Female Car Diagnostic Extender Cord Adapter,16 Pin Right Angle,1.6ft/50cm https://www.amazon.com/dp/B01AUJH01M
    MadMaxCanon[OP] likes this.
  3. Mar 4, 2023 at 7:17 PM
    MadMaxCanon
    So are you getting data packets sent to each at the same time or are you using them just for power?
  4. Mar 4, 2023 at 7:19 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’m 90% sure both work simultaneously, but let me double check in the morning. Someone else may be able to chime in before then though
  5. Mar 4, 2023 at 7:33 PM
    MadMaxCanon
    Thanks. I always thought it won't be able to actually communicate vehicle data from the ecu to 2 separate modules, but can definitely power 2 things with only 1 getting ecu info.
  6. Mar 5, 2023 at 7:00 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
  7. Mar 10, 2023 at 2:06 PM
    MadMaxCanon
    Update today I installed my Ultragage and Veepeek together at the same time using the splitter and to my shock both were able to communicate simultaneously. Awesome.
    TRDFerguson likes this.
  8. Mar 10, 2023 at 2:07 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Crap! I totally spaced on checking that out. Glad you tested it and it worked though.
  9. Mar 10, 2023 at 2:33 PM
    MadMaxCanon
    For 15 bucks I rolled the dice. Great find. Now I need to tuck all the wiring and such.
    TRDFerguson[QUOTED] likes this.
