OBD2 SCANNER LINK ERROR
Discussion in '2nd Gen Tundras (2007-2013)' started by Tundra321, Mar 31, 2023.
  1. Mar 31, 2023 at 4:27 AM
    Tundra321
    Tundra321 [OP] New Member
    Troy
    2007 White Tundra
    Any suggestions just recently purchased an 07 tundra and the check engine light came on. I tried hooking up a code scanner that's been used on the truck several times prior but now is saying link error when trying to scan for codes and won't pull the code. I had an auto parts store also try their scanners and are getting the same link error message too. Truck runs fine but I can't pull the code for the check engine light.
    Any help or suggestions?
    Thanks,
  2. Apr 1, 2023 at 12:10 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Pull that kick panel, I think it's x2 12mm bolts and pull down. Check the obd2 port, see if there is an additional port plugged into it, if not check wiring and grounding point to ensure you have continuity.
  3. Apr 1, 2023 at 12:31 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    There is a dedicated fuse for it there too in panel next to it. Pull the fuse and test.
    Danny3737 likes this.
