Occasional popping sound in rear end
Discussion in '2.5 Gen Tundras (2014-2021)' started by Djone27, Oct 12, 2020.
  1. Oct 12, 2020 at 3:13 PM
    Djone27
    Djone27 [OP] New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    I have a '17 4x4 with 43.5k miles. Stock suspension (black shocks; not OR or TRD), stock brakes, TRD sway bars in front and rear, and 275/60R20 Cooper AT3 XLTs on TSS 20x9 +50 rims. Tires were replaces about 700 miles ago with an alignment. Both sway bars were installed (I believe) right before the alignment/tires; not 100% sure. Over the last week or so I've occasionally heard a faint pop here and there. I've heard it in drive and reverse. I think I've only heard it when turning. Any suggestions on what to check? Could the rear sway bar have some bind to it? Both sway bars were installed using toyota torque specs. I've read some suggestion that it could be the parking brake cable.
    Any pointers or advice on what to check is appreciated.
  2. Oct 12, 2020 at 4:58 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Anybody guess. I would check all fasteners, shock bolts, sway bar etc. Buddy had a horrible knocking sound in rear, drive you crazy. everyone convinced him his catalytic converter was loose inside the housing. I know. Replaced catalytic converter, zero change. finally decided to lay under car while someone pushed up and down, 3 seconds later it was determined lower shock bolt was loose.
  3. Oct 14, 2020 at 5:46 AM
    Djone27
    Thanks for the suggestions. I've noticed the sounds a little more and it would probably be considered more or a flexing creak. I got under there and didnt see any loose bolts or anything. Also bounced the bed and didnt hear anything. I did notice a small spot in the driveway near the rear passenger tire (about the size of my hand). Looks like an oil/grease spot, but nothing stuck to my hand when touching it, felt dry. This made me think maybe one of the shocks was busted, but I dont see any oil on anything under the bed; checked the shocks, calipers, and diff housing. I did notice the left bushing on the sway bar had a small ridge of lube/grease about 1/8" away from it. Almost like the sway bar slide side to side. Is that normal? Could that be what I'm hearing?
  4. Oct 14, 2020 at 6:05 AM
    mr_lasseter
    mr_lasseter New Member
    You by chance have a trd pro skid plate? I had some loud popping when turning and found a post on forum about it being the skid plate rubbing with the frame. Sure enough I put some thick foam in between skid plate at the back between it and the frame and popping noise went away.
  5. Oct 14, 2020 at 6:07 AM
    Djone27
    Thanks for the suggestion, but no. Still have the POS stock one.
  6. Oct 14, 2020 at 6:18 AM
    timsp8
    NY
    Post some pictures of your suspension and sway bar. Some have accidentally flipped the sway bar brackets the wrong way when installing. Are you sure it’s in the rear? I’ve had noises travel before and thought they were coming from somewhere they weren’t.
  7. Oct 14, 2020 at 6:39 AM
    Djone27
    Here's some pics from this morning. Pretty sure it's in the rear. I also noticed the endlink bolts on the passenger side just seem dirtier with more buildup. That could be the antiseize I used (shit was all over my hands), but not sure. New tires are 5lb heavier (56lbs each). Not sure if that would make a difference with the stock black shocks.20201014_070924.jpg 20201014_071027.jpg 20201014_071458.jpg 20201014_070956.jpg 20201014_070946.jpg 20201014_070845.jpg
  8. Oct 15, 2020 at 1:14 PM
    Djone27
    So I took my gear box out the bed, removed my mx4 cover, and completely swept the bed out so nothing would be left rolling around. Can definitely hear the sound more pronounced now. Just coasting about 10mph and turning the wheel back and forth generates the creaking/popping sound from the rear. Starting to think it might be a somewhat normal sound caused by the rear sway bar flexing on body roll.
    Do they tend to generate any sound when 'working'?
    Found the culprit. Bring on the ridicule. There was a damn acorn lodged between the cab and bed. When the bed flexed is when I would hear the creaking/popping. Circled where the indentations are that the bed and cab caused.
    thearborbarber likes this.
  9. Oct 15, 2020 at 1:41 PM
    timsp8
    NY
    From what I can see everything looks good. I have the same sway bar and no popping. Also had it on my 2010 tundra with no noise.
    Get someone to drive with you in the bed listening to narrow it down to which side and maybe exactly where it’s coming from.
  10. Oct 15, 2020 at 1:42 PM
    Djone27
    Edited my post above. It was an acorn wedged between the cab and bed... :anonymous:
  11. Oct 15, 2020 at 2:20 PM
    timsp8
    NY
    At least you found it. I hate chasing noises for weeks or months. Especially when they turn out to be something small that I never thought of.
  12. Oct 15, 2020 at 2:43 PM
    Medicineman
    Medicineman Not so new member
    Western MD
    2011 MGM Rock Warrior Crewmax
    Heated Leather Seats, Morimoto XB LED and 4-Banger fogs, TRD Pro “style” grille, Bushwhacker Flares, Line-X, Leer Cap, Yak Rack
    What a long, strange trip this has been.... one Hell of an acorn.Guess it really was a loose nut after all.
    Clemsonman14 likes this.
  13. Nov 6, 2020 at 6:35 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Did the sound come back? I have a warping/popping noise. It’s in the rear as well when going in a turn. Also hear it when going straight over uneven surfaces. Everything is torqued up in the rear also. Crap is annoying af! I’m pretty sure it’s not a acorn
  14. Nov 6, 2020 at 9:08 PM
    Djone27
    No, mine is still quiet after getting the jammed acorn dislodged. It was making noise with ANY body movement (even road expansion joints). Good luck, it drove me crazy trying to locate the source.
  15. Nov 6, 2020 at 9:44 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Ok, thanks
  16. Nov 7, 2020 at 4:30 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    For me its whole milk or ice cream.
    HulkSmurf14 likes this.
  17. Nov 7, 2020 at 6:20 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Djone27[OP] likes this.
