Odyssey Extreme Battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ctaylor76, Jan 4, 2024.
  1. Jan 4, 2024 at 6:21 PM
    Ctaylor76
    Ctaylor76 [OP] New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    So I have a 2021 tundra with 27k miles on it, recently had to replace the oem battery with a new one.
    I purchased the battery from oddessey and received it today. Hooked the battery up and truck drove just fine, came home parked.
    Truck is now completely dead, no crank no click no lights (everything is off). Truck is basically dead and has zero power.
    any ideas ?
  2. Jan 4, 2024 at 6:35 PM
    Corsa1
    Corsa1 New Member
    2021 Cavalry Blue Crewmax
    Do you own a trickle charger? I would maybe start there and see if it's just been sitting for too long. Costco has them for like $30 bucks. Or put in the old battery if you still have it and make sure its the battery not something else. I assume its a fault in the battery though.
  3. Jan 4, 2024 at 6:39 PM
    As mentioned I would put a charger on it. Is it an AGM battery? I would also contact the seller and see what they say.
  4. Jan 4, 2024 at 6:49 PM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    Can you jump start the truck? Maybe connection got loose somewhere.
  5. Jan 4, 2024 at 6:51 PM
    Ctaylor76
    Chaz
    Houston
    It’s a 27F battery (extreme) brand new , I did try to jump it no dice.
  6. Jan 4, 2024 at 6:55 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    AGM battery don’t work well with tundra
    ShawnTRD and 1lowlife like this.
  7. Jan 4, 2024 at 7:00 PM
    Dawoofles
    Santa’s Village
    Does the old battery still start the truck? Haven’t had any issues with AGM, GM diode mod is pretty easy to boost the volts to 14.4
    HulkSmurf14 and Ctaylor76[OP] like this.
  8. Jan 4, 2024 at 7:23 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    These trucks are not designed to properly charge agm batteries. You have to modify the electrical system. More than likely, you got a battery that’s been sitting and you really should have topped it off with a trickle charger before using it. You starting the truck probably drained it of what little charge it had left after sitting on the shelf. Unless you plan on keeping a trickle charger on it, or changing the charging voltage, return it and get a wet cell battery. These trucks are not designed to use agm batteries and they really aren’t necessary in a stock daily driver
    1lowlife likes this.
  9. Jan 4, 2024 at 7:44 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Yes they do. I've had an AGM battery in my 2018 for years, no diode and it starts briskly every morning without issue.
    Black Wolf and Ctaylor76[OP] like this.
  10. Jan 4, 2024 at 7:47 PM
    Ctaylor76
    Chaz
    Houston
    Weird battery has 12.9 voltz verified on volt meter ?
  11. Jan 4, 2024 at 7:53 PM
    Ctaylor76
    Chaz
    Houston
    So check this out I’ve been waiting for this battery for over week and half so I went to advanced auto parts bought a 27F AGM die hard battery and had zero issues before this.
  12. Jan 4, 2024 at 8:09 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    You do you bruh, I ain’t gonna waste $400 for an AGM battery that doesn’t give me any benefits, and there’s only two kinda batteries, it either start the truck or it doesn’t.
    koditten likes this.
  13. Jan 4, 2024 at 9:43 PM
    Ctaylor76
    Chaz
    Houston
    Anyone have an idea ? Battery has 12.9 volts maybe it’s not drawing any amps ?
  14. Jan 4, 2024 at 10:01 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    LOL.
    Tell that to my ancient 12+ year old AGM that is still working better than the OEM battery down to -30F.
    HulkSmurf14, texasrho83 and reywcms like this.
  15. Jan 4, 2024 at 10:14 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Do you have lights or anything? What did you try jumping with?
    Start simple connections, ground, power to fuse block
    Get a charger on that battery top it off
  16. Jan 4, 2024 at 10:35 PM
    Ctaylor76
    Chaz
    Houston
    I have nothing.
    yes i checked grounds reconnected cables everything.
    I used a basic jumper box
  17. Jan 4, 2024 at 11:58 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Did you try to reconnect the old battery to start it? Start there and report back….
    even though it’s registering 12.9 v you may need to have it load tested……
  18. Jan 5, 2024 at 6:18 AM
    CaptRatBoy
    CaptRatBoy New Member
    Somewhere around 2500' Western Blue Ridge, NC
    Capeable, extensively modified, 2016, Limited, 4 x4 Tundra Off Road, 3td. one
    Hopefully ya checked it, i.e. the voltage, before installing? Most AGM's recomended/need to be charged before install.
  19. Jan 5, 2024 at 7:10 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Dual Odyssey agms in the old man’s rig with zero issues. I’d take that one back grab a new one make sure it’s full charged via trickle charger. Then throw it in.
  20. Jan 5, 2024 at 5:53 PM
    Ctaylor76
    Chaz
    Houston
    Fixed the issue, so with that battery you need to have really strong terminals. Terminals were the issue.
    pwpblue, HulkSmurf14, reywcms and 2 others like this.
  21. Jan 5, 2024 at 6:01 PM
    koditten
    Kirk
    Midland of the Mitten
    Are we twins separated at birth?
    100% truth.
    I got no issue running to Walmart at 10:30 pm to get my 6 year old battery swapped out.
    It's just a battery. Some good, some bad and we all drive different.
  22. Jan 7, 2024 at 4:16 PM
    ConcordCarlos
    ConcordCarlos New Member
    Carlos
    2021 Tundra SR5
    Curious what you mean by strong terminals?
  23. Jan 7, 2024 at 5:02 PM
    Danman34
    Danman34 New Member
    Danny
    The starter only pulls what it pulls. It doesn’t pull more power because there is a different battery. The oem terminals work for every other tundra on the road. Sorry, but The terminals are not the issue.
  24. Jan 7, 2024 at 5:11 PM
    koditten
    Kirk
    All Toyotas have battery post clamps that are prone to corrosion.
    If the clamp is corroded, you will not get a strong transfer of current to the starter.
    It's pretty common. Research this and you will agree.
    pwpblue likes this.
  25. Jan 7, 2024 at 5:21 PM
    Danman34
    Danman34 New Member
    Danny
    If you’re changing the battery and totally ignore a corroded terminal, you probably shouldn’t be touching anything on a vehicle.
  26. Jan 7, 2024 at 5:35 PM
    koditten
    Kirk
    If a person is on this site, there is a good chance they want to learn how to maintain their vehicle.
    If one is not willing to help new people learn here, then this site might not be for you.
  27. Jan 7, 2024 at 5:41 PM
    Danman34
    Danman34 New Member
    Danny
    I have been here for quite some time and have helped many as I have learned from
    Many. But I’m not going to sugar coat. Sorry you’re offended so easily.
    koditten[QUOTED] likes this.
  28. Jan 7, 2024 at 5:47 PM
    koditten
    Kirk
    Not sorry. You just need to research how often the battery clamps are the root of the problem.
    AutoZone techs are only gonna clean the clamps half assed. It's on us to inform peeps that these clamps are going to corroded. Not maybe corrode, they will corrode.
  29. Jan 7, 2024 at 5:49 PM
    Danman34
    Danman34 New Member
    Danny
    Op purchased the battery directly from Odyssey and installed it themself. Nobody said anything about the tech at auto zone ignoring a corroded terminal.
  30. Jan 7, 2024 at 5:52 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Clean your battery clamps.
    Tundras are NOTORIOUS for the thin film of corrosion on the clamps..
    Don't ask how I know..
