OEM running boards bracket sandwiching floor rubber plugs. Why would they do that?
Discussion in '2.5 Gen Tundras (2014-2021)' started by CanTundra, Apr 26, 2022.
  1. Apr 26, 2022 at 5:36 PM
    CanTundra
    CanTundra [OP] New Member
    2021 Tundra TRD Off Road
    So today I was installing my oem running boards on my 2021. Each side has 4 brackets but the front 2 brackets are right where the oem rubber plugs are located. I found it stupid Toyota would position them there.
    My OCD got to me with this. I was worried about future leaking (salt entering etc). What I did was remove plug added some Permatex sealant inside plug then pop plug back afterwards added a little sealant to outside and then added bracket.
    Was this a 2021 change or are your trucks the same way in other years?
    (Random internet pic of the plug)
  2. Apr 30, 2022 at 6:06 PM
    CanTundra
    Can you share some pictures of your step brackets I like to see if they all have this problem
  3. Apr 30, 2022 at 6:08 PM
    Rubberdown
