Oil capacity level
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1Tundra5, Dec 31, 2022.
  1. Dec 31, 2022 at 4:12 PM
    1Tundra5
    1Tundra5 [OP] New Member
    Junior
    2015 White SR5
    2015 TSS SR5 Crewmax.
    I can’t remember and haven’t been able to find the information anywhere. What’s the capacity of engine oil for my truck?
    Not sure if it was 7 or 9
  2. Dec 31, 2022 at 4:17 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I have a 2019 5.7, and the listed capacity is 8.5 quarts.
    TXBrit, georgiey22, coldcanuk and 2 others like this.
  3. Dec 31, 2022 at 4:19 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    x2
    I have an ‘18, 8.5qt with filter for the 5.7
  4. Dec 31, 2022 at 4:20 PM
    CTundraForMe
    CTundraForMe New Member
    From my 2015 owner's manual:
    Mike59 likes this.
  5. Dec 31, 2022 at 4:24 PM
    1Tundra5
    Junior
    2015 White SR5
    What page was this from? I know I’ve seen it in the past but wasn’t able to today.
  6. Dec 31, 2022 at 4:25 PM
    CTundraForMe
    Page 512.
    I believe you can find the owner's manual online on Toyota's website, in PDF format? I'm pretty sure that's where I got mine.
    1Tundra5[QUOTED][OP] likes this.
  7. Dec 31, 2022 at 5:37 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Any idea why Toyota went from 7.9 to 8.5 in 2018?
    georgiey22 likes this.
  8. Dec 31, 2022 at 6:04 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Nope.
    But my 2107 with the 5.7 engine ALWAYS takes 8.6 to get to the top line on the stick.
  9. Dec 31, 2022 at 6:50 PM
    CaptRussia253
    Ruslan
    Good to know. I’ll have to check mine as I just changed it and did 8 quarts. I too have a 2017.
  10. Dec 31, 2022 at 8:55 PM
    737fixer
    737fixer New Member
    Try to remember the top line of the dipstick is a "Hot" reading. Please when you fill after a change try to go to 1/2-3/4 on the stick.
  11. Dec 31, 2022 at 9:08 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Where is it written that this is a hot reading? Never heard that before. I call BS here for the first time in 2023. :)
  12. Dec 31, 2022 at 9:29 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    The manual states the engine should be at operating temperature. Not the ideal phrase, but it could be considered a “hot reading”.
  13. Dec 31, 2022 at 10:58 PM
    737fixer
    737fixer New Member
    Not here to argue but yes, oil levels are designed set to a baseline. Let’s say operating temperature is 200F. That remains very close no matter where I’m driving whether it by -60F in Anchorage or 120F in Phoenix. If you changed your oil in Anchorage and refilled it compared to Phoenix you would have a huge difference based on the rough standard 4% thermal expansion of motor oil for every 100F. So where is it written? In the cubical expansion coefficient for conventional oil that is about 0.0005 1/deg-F. If the oil temperature increases 150F the resulting expansion is 0.0005*150 = 0.075, or 7.5%. I'm in Phoenix so today being 65 degrees when my truck warms up I would be a mere 9oz overfilled if I did it your way. I don't know where you live but if its colder then here, you're overfilling even more. Not BS, just the way all engines are designed. But to your point, I 100% guarantee the engineers at Toyota and every auto manufacturer takes what you're saying and gives a significant amount of wiggle room.
  14. Jan 1, 2023 at 3:50 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    when I change oil:
    When i refill, I put in a dash over 8 qts. then I start it, pull it off the ramps & idle for as long as it takes me to put up ramps & crap.
    I turn it off & let it sit for about 15 minutes while I clean up the giant mess I made.
    then, I re-check the dipstick....it's usually 7/8th of a smidge low. So I fill to the top line.
    thermal expansion science is in there, just in a highly relaxed fashion.
  15. Jan 1, 2023 at 5:26 AM
    And let’s remember, a guy overfilled his truck with 8.5 qts of oil, after not draining his oil pan ( 17qts total). His engine still ran and did not skip a beat. That extra half quart ain’t hurting anyone.
    richsadams and CaptRussia253 like this.
  16. Jan 1, 2023 at 6:08 AM
    centex
    centex New Member
    I put just shy of 9qts when I did mine and it got me midway on the mark. Cranked it after 8 and let it run while I added and checked.
  17. Jan 1, 2023 at 8:13 AM
    1Tundra5
    Junior
    2015 White SR5
    Thanks, man! Kind of dumb question: When it says, “with oil filter”, does it mean you did drain and fill WITH filter replacements?
  18. Jan 1, 2023 at 8:24 AM
    blanchard7684
    blanchard7684 New Member
    I've seen reference material before that the entire lubrication system is 9.3 quarts.
    I've done oil changes before where I let it drain over night and I had to crack open the 9th quart bottle to get it to the top mark.
    1Tundra5[OP] likes this.
  19. Jan 1, 2023 at 10:49 AM
    CTundraForMe
    I was taught to ALWAYS change the filter. So I use the larger number.
    A long time ago I had situation where an extra 4 quarts of oil were added to my car (pre tundra days) and it only held 4 quarts to begin with.
    It did NOT go well. Anyone remember the Spy Hunter arcade game, with the smoke cloud evasion trick? Think that. Plus soaked air filter. Plus blown seals.
    The engine lasted maybe a week before it completely blew out all the oil and seized up.
    That tends to make me careful when I change the oil. That said, I believe there is a bit of "wiggle room" there. I've been doing my best to put approx 7.9qt in, which leaves me with bottles with a smidgen of oil sitting around. :/ Next time I'll use all 8 and be done.
  20. Jan 1, 2023 at 3:53 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Answer: YES.
    WILLINH likes this.
  21. Jan 1, 2023 at 6:30 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    From my experience.
    6 quarts low mark
    7 quarts almost in the middle
    8 quarts to the full mark
    After running need to add .5 to get back to full mark so capacity with oil and filter is 8.5qts
    nobodyintexas and CaptRussia253 like this.
  22. Jan 1, 2023 at 6:32 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Like other poster said it's in the manual. When I change my oil it takes about 8 quarts. If I do 8.5 it's overfilled when hot.
  23. Jan 4, 2023 at 6:05 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    Not sure if any of you use the toyota app. But it is pretty good, manuals, specs, dash lights, make appointments, service history you can add for your truck etc..
    CaptRussia253 likes this.
  24. Jan 4, 2023 at 7:33 PM
    CTundraForMe
    I don't do apps. My portable tracking device works well enough without them.
  25. Jan 4, 2023 at 8:46 PM
    Mr Badwrench
    Mr Badwrench New Member
    Amazing. I can remember what page number it is on in the manual, but I can't remember the capacity . My head doesn't work real good sometimes.
  26. Jan 5, 2023 at 6:45 AM
    CTundraForMe
    I look it up every single time. Bad things happen if i remember incorrectly.
  27. Jan 5, 2023 at 6:47 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I have to write it on the inside of the hood of each of our cars.
    TXBrit, pursuit2550 and 1Tundra5[OP] like this.
  28. Jan 5, 2023 at 7:08 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    I have the quarts and torque spec for the wheels on my truck and wife’s suv. Getting old sucks.
  29. Jan 5, 2023 at 10:03 AM
    WaterTrash
    WaterTrash New Member
    This is just good practice. 3 different vehicles and a trailer at my house so I do the same. Got tired of scouring the manual or google for the torque specs every time I rotate tires
    TXBrit and pursuit2550[QUOTED] like this.
