Oil Capacity
Discussion in '3rd Gen Tundras (2022+)' started by ridre52, May 20, 2024.
  1. May 20, 2024 at 9:06 AM
    ridre52
    ridre52 [OP] New Member
    Robert
    This might be a silly question, so forgive me if it is. For oil changes, the manual says "7.7 quarts with filter." What exactly is the .7? Is that a little over half a quart or less than that? Thanks in advance.
  2. May 20, 2024 at 9:11 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  3. May 20, 2024 at 9:20 AM
    ridre52
    Robert
    Thank you for clarifying it.
    ryanwgregg[QUOTED] likes this.
  4. May 20, 2024 at 9:56 AM
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    My GoogleFu says 22.4 fluid ounces.
    Or 111.9 teaspoonfuls.
    Or 0.004 barrels.
    Or 662 ccs.
    Or 1.4 pints.
    Or 2.8 cupfuls.
    :D
    Or personally I would put in 8 quarts and call it a day, but maybe I am just lazy and imprecise.
    Kap1, 24_SR, CaptRussia253 and 3 others like this.
  5. May 20, 2024 at 10:15 AM
    eddiefromcali
    Eddie
    100% Stock
    I do 7 (Which is more than 6 but less than 8 btw) and then check it after a quick drive.
    DIYReid and VCheng like this.
  6. May 20, 2024 at 10:23 AM
    Markysharky
    Markysharky New Member
    I always add 8 quarts with a filter change. Usually the dipstick reads full or a tick over. No issues yet.
    VCheng likes this.
  7. May 20, 2024 at 10:28 AM
    ridre52
    Robert
    Lol You are very precise. I am thinking 7.5ish is just about right who the hell at Toyota came up with .7?
  8. May 20, 2024 at 10:40 AM
    VCheng
    VCheng New Member
    Upstate NY
    Thou shalt not question the wisdom of Toyota-san!
    :D
    (Seriously though, plus or minus half a quart either way would not matter at all to engine operation.)
    CaptRussia253 likes this.
  9. May 20, 2024 at 10:46 AM
    lapoolboy
    lapoolboy New Member
    Why not just measure out the additional 24 ounces they call for and put in the correct amount? Measuring cups are cheap.
    SWB Tundra likes this.
  10. May 20, 2024 at 2:35 PM
    angrygiraffe
    angrygiraffe New Member
    '22 SR5 CrewCab 5.5'
    I generally buy two 5-quart jugs of oil, put the entire first one in, add what I guess to be 1-2 quarts from the second jug, then check the dipstick after 5-10 minutes. Usually end up having to add a little more to get up to the right spot on the dipstick but I figure better safe than crazy overfilled. Run the engine for 30 seconds to make sure the oil filter is thoroughly filled, then check again and go from there.
  11. May 20, 2024 at 3:23 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
  12. May 21, 2024 at 5:22 AM
    Rickoo
    Rickoo New Member
    I buy three 5 quart Mobil 1 Extended performance jugs. Put in 1.5 jugs (7.5 quarts) and have the other 7.5 for the next time. Fills to just below the high line on the stick.
  13. May 21, 2024 at 5:33 AM
    jctmundra
    Northern VT
    can always get the sharpie out -
  14. May 21, 2024 at 6:11 AM
    jctmundra
    Northern VT
    ryanwgregg likes this.
  15. May 21, 2024 at 8:03 AM
    iforceAZ
    iforceAZ New Member
    This is the way...
    24_SR, 3d_pilot, ryanwgregg and 2 others like this.
  16. May 21, 2024 at 6:02 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
  17. May 21, 2024 at 6:17 PM
    jctmundra
    Northern VT
    22whatwedo, SWB Tundra and kirkb like this.
  18. May 21, 2024 at 6:43 PM
    99ways2die
    99ways2die New Member
    Second...although I have never, not even once, checked the dip stick after an oil change (or in between) ever since I bought this thing.
    If my truck makes it to 100K miles I'll start intermittent oil level checks, but otherwise color me heartless.
  19. May 22, 2024 at 6:34 PM
    chuckfinley
    chuckfinley New Member
    2021 LR Tundra TRD Pro
    2021 LR Sequoia TRD Pro
    Given that I just found that the dealership overfilled mine by 2Q last time, I will be checking from now on.
  20. May 22, 2024 at 6:49 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I think I recently seen a video where some Russian shop made a clear oil pan to see the effects of different oil levels.
  21. May 22, 2024 at 7:35 PM
    jctmundra
    Northern VT
  22. Jun 20, 2024 at 6:31 AM
    DMBfan
    DMBfan 2015 Tundra SR5 CrewMax
    My 2015 calls for 7.9 quarts. So I put in 8 qts. The level of oil on the stick is about a quarter inch over the full line. I know its nothing to be concerned about but why is it over? I have a tow package, so I am assuming I have an oil cooler (haven't verified). Once the cooler gets oil flowing through it, does it lower that level?
  23. Jun 21, 2024 at 5:44 AM
    Westerntowboss
    Westerntowboss New Member
    Yep .7 is more than .5
    KNABORES likes this.
  24. Jun 21, 2024 at 6:35 AM
    DIYReid
    DIYReid New Member
    KC
    2024 Ice Cap Tundra Limited
    There's a dipstick for a reason.
  25. Jun 21, 2024 at 6:53 AM
    aj350925
    aj350925 New Member
    The dipstick doesn't work well on these 3rd gen engines.
  26. Jun 21, 2024 at 7:42 AM
    DIYReid
    DIYReid New Member
    KC
    I'm sorry, what?
  27. Jun 21, 2024 at 8:44 AM
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    He means its hard to read, need to scuff it up a bit with a scratch bite pad, sand paper or any other abrasive to see where the oil is.
  28. Jun 21, 2024 at 9:02 AM
    DIYReid
    DIYReid New Member
    KC
    It's the same as my tacoma on mine at least.
  29. Jun 24, 2024 at 10:34 AM
    aj350925
    aj350925 New Member
