Oil Change Frequency
Discussion in '2.5 Gen Tundras (2014-2021)' started by LabRat, May 10, 2023.
  1. May 10, 2023 at 1:59 PM
    LabRat
    LabRat [OP] New Member
    Houston TX
    '14 Tunda
    Everyone seems to have an opinion on the frequency of an oil change but I'm asking anyway.
    I work from home and the Tundra gets about 6k miles a year. Admittedly there are plenty of short trips as 90% of the places I go are within a 5 mile radius of my house. We do take it on trips so it gets a bit of highway, but nothing like my old commuter did when I had to go into an office.
    CarFax is yelling at me to change it every 6 months, old school guys are saying synthetic is garbage (I just smile and nod), and I'm trying to justify how I need a full synthetic oil change after ~3000 miles. Sometimes less. Especially when the shop charges ~$100+.
  2. May 10, 2023 at 3:04 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I’m a 10k guy but I drive 18-20k a year. If I was in your shoes, I’d do whatever oil your heart desires (brand and weight) and change it every 5k or once a year. Those short trips are rough. Open her up on the highway and do an Italian tune up from time to time. My .02
  3. May 10, 2023 at 3:07 PM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    106.9 MHz. It'll also get you a local classic rock station.
    HulkSmurf14, hagrid and PermaFrostTRD like this.
  4. May 10, 2023 at 3:17 PM
    CTundraForMe
    CTundraForMe New Member
    I agree with Jaypown.
    Change it every 5k or 1 year, whichever comes first, with whatever synthetic brand you prefer.
    Changing the oil and filter yourself is quite easy, and you know it's done right. Or, at least how you did it! :)
    Rodtheviking and LabRat[OP] like this.
  5. May 10, 2023 at 3:49 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    +2. I do my own oil changes but it is a pain having to remove/replace the skidpan every 5K, LOL... and yes I know there are replacement skids with oil filter 'doors', yet pricey...
    LabRat[OP] and RustyShackle323 like this.
  6. May 10, 2023 at 6:12 PM
    PKFan
    Okay, I can be helpful, too. I agree with the CarCareNut's recommendation of 6 months or 5000 mi. I drive about the same mileage as you, so I typically end up doing it at 6 months. And there are plenty of horror stories on here (and elsewhere) of oil changes gone bad when left to a quick change place or the dealer, so I highly recommend doing it yourself. It's a lot cheaper that way, too (mine are typically under $40, but I shop deals on oil ahead of time).
  7. May 10, 2023 at 6:35 PM
    PermaFrostTRD
    Northern NY
  8. May 10, 2023 at 7:11 PM
    Red8654
    Red8654 New Member
    Eddie
    2014 Toyota Sequoia
    I like to do every 6k miles , get the tires rotated and then aligned as I got the Firestone unlimited alignment package , might be overkill but it works for me !
  9. May 10, 2023 at 7:44 PM
    Mike59
    Mike59 Kentucky Traveller
    Central Kentucky
    2021 Tundra DC Limited 4x4 SSM
    5k for me. I do it myself because the dealer hires idiots with impact tools.
  10. May 10, 2023 at 9:03 PM
    Ct. Rich
    Ct. Rich New Member
    Maine
    2016 Limited TRD
    Just cut a hole in yours, that’s all I did! Much easier!
  11. May 11, 2023 at 4:01 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    It would help if OP could tell us when the truck had its first oil change. If the answer is any value greater than 10 miles then this thread is moot.
  12. May 11, 2023 at 4:45 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Send your oil in for sampling. Just because you don’t put a lot of miles on the oil doesn’t mean it’s good. Oil goes bad just sitting in the engine. Condensation for one and oil dilution from gas.
    WalnutWest and Tyman like this.
  13. May 11, 2023 at 5:08 AM
    prevent
    prevent New Member
    2014 5.7L Tundra SR5 DC
    TRD Catback Stillen CAI DAP Tune Tow Mirrors Light sensor Dashcam TRD Pro Grill LED Interior lights + DRL’s
    I sent my oil in to Blackstone and they said that I can ignore those time constraints in regards to oil: “Thanks for letting us know about the oil having 13 months of service. Calendar time won't cause the oil to break down, so you can rely on mileage to determine oil change intervals.”
    If that’s the case then Amsoil Signature Series should last me 2+ years.
    Mike59 likes this.
  14. May 11, 2023 at 8:45 AM
    Quattroa4m
    Quattroa4m New Member
    I've been changing oil for over 50 years and started using synthetics when Mobil 1 first came out. Back in those days, a 3,000 mile conventional oil change would still net you sticky lifters and gummed up valve covers.
    Since that time, I've never heard a sticky lifter, or seen gummed up valve covers (with integral pcv plumbing), loose timing chains, or high oil consumption. Pretty much have adhered to 5,000 miles or 1 year oil changes...which ever comes first.
    Not all engines are created equal. Some can easily go further than 5,000 miles on an oil change, others not so much. (A huge variable here is also how they are used). The only way to know for sure is to do a postmortem.
    Oil analysis rarely catches engine damage before it happens. A case in point is a stuck oil ring that gouges the cylinder wall and you see high AI and Si or Fe in your next analysis. At that point, it's a bit late to be considering more frequent oil changes.
    As for the $35 or higher oil analysis fee...it might be better served putting it toward another oil change.
    As an FYI...this conversation seems to be revolving around the Tundra V-8. Imagine the additional abuse the oil in a twin turbo V-6 Tundra endures. Yet Toyota still adheres to 10,000 mile change intervals...at least for the purposes of the 2 year "free'' maintenance plan.
  15. May 11, 2023 at 8:49 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    5k miles or 6 months. /endthread
  16. May 11, 2023 at 8:56 AM
    Quattroa4m
    Synthetics can easily handle 12 months...always have.
  17. May 11, 2023 at 8:57 AM
    LabRat
    Houston TX
    '14 Tunda
    Thanks guys for the responses. Sounds like the consensus is 5k miles or 6 months. No use in pushing it beyond that.
    @hagrid - Carfax shows it was "serviced" at the dealer with 9 miles on the odometer then again at 2900.
    hagrid and Sierradevil like this.
  18. May 11, 2023 at 9:10 AM
    MadMaxCanon
    people are free to do whatever they like. I take advice from people who work on cars everyday of their lives like the car care nut who is a master toyota tech. Not just because youtube tells me to, because he has experience, explains why and most of all it makes sense.
    All those claims of 12 months, or guaranteed for X amount of miles or X amount of time all have caveats and most of the time are only for perfect scenarios and marketing gimmicks. Yeah if you drive 300 highway miles a day straight, I would agree you meet the criteria for 10k oil changes, but not 1 year as that would turn into like 30k miles for your oil change, and vice versa if you only make short trips or drive 10 miles a day, 10k miles would take you years. Those 2 extreme scenarios are the reason why there is a mileage AND a time interval, whichever comes first. The fact is, you can drive 0 miles and idle your engine every day for hours and your oil would still get contaminated, even moreso than if you drove it. Everytime you run your car, fuel gets into your oil as does moisture, all of which degrades your oil from the moment it happens.
  19. May 11, 2023 at 9:27 AM
    LabRat
    Houston TX
    '14 Tunda
    I drove a jetta TDI (diesel for those who don't know) for years and the commute was 50 miles/day. I abided by the recommendation of every 10k miles and never had issues. Didn't matter in the end - VW bought it back because a judge told them to haha.
    Mike59 likes this.
  20. May 11, 2023 at 9:31 AM
    Quattroa4m
    We're only talking about 5,000miles or 12 months. Not 12 months unlimited mileage.
    Some Toyota 4 bangers have had a notorious problem with high oil consumption as a result of poor piston cooling (oil spray, etc.). If 6 month oil changes make folks feel better...so be it.
    This entire thread is dedicated to more oil changes...not fewer.
    MadMaxCanon[QUOTED] likes this.
  21. May 11, 2023 at 9:58 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Every 5000 miles and I use 5w-30 without any problems. 225k+
    Mike59, LabRat[OP] and Quattroa4m like this.
  22. May 13, 2023 at 7:53 AM
    sotex
    sotex Sic 'em Bears!
    Jeff
    San Antonio, TX
    2020 White Tundra SR5 Double Cab 4x2 SX
    I go at least 7,500 and sometimes to 10,000. I'm of the school of thought of a freshly drained engine cranking can do more damage than one with oil flowing freely (I know there can be 10-20% of the oil remaining when drained). I mitigate the number of times my engine has to do that by using synthetic (of course) and extending the miles between changes. With 8.5 quarts of oil circulating, I imagine it takes longer for iron to show up with unacceptable PPM.
    Appears I'm in the minority here.
  23. May 13, 2023 at 8:07 AM
    Retroboy1989
    Northern Utah
    2012 DC 4x4 5.7 SR5 TRD OR Barcelona
    Softopper TRD Sport wheels 275/60R20 Tires Secondary Trans Cooler
    I was onboard for 10k/12mos with a good synthetic. This was supported by people reporting great results from their oil change analysis....Then I started reading about oil control rings fouling....back to the 5k bandwagon.
    My tundra sees less than 5k a year so it's on the annual plan.
    Mike59 likes this.
  24. May 13, 2023 at 8:23 AM
    sotex
    Jeff
    San Antonio, TX
    Hmmm. Hadn't read that. Which vehicles experienced oil control rings fouling?
  25. May 13, 2023 at 8:35 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Any with the low tension rings so most any Toyota from the past 2 decades. If a ring gets stuck from coked up oil deposits the engine starts burning oil a lot faster. Or so the internet says
    sotex and stevesgraytundra like this.
  26. May 13, 2023 at 8:48 AM
    Quattroa4m
    There's quite a bit of information regarding 4 banger Camrys and "stuck" oil control rings.
    sotex[QUOTED] likes this.
  27. May 13, 2023 at 9:21 AM
    sotex
    Jeff
    San Antonio, TX
    So not as big a concern in our Tundras?
  28. May 13, 2023 at 9:47 AM
    Bill3648
    Bill3648 New Member
    Loudoun County, VA
    2019 Silver Sky Limited Crewmax
    Diamondback SE RCI skid plate Husky Mats WeatherTech bed-liner SCS Ray10's Eibach Stage 2 coilovers Toyo AT3 275/70/18 RAS HD Tuffy console safe
    Normally do 5-6k it's all under $75 diy
  29. May 13, 2023 at 12:35 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    The answer to this question has always been:
    Read the manual.
    Do what it says.
    Simple, isn't it?
    Jaypown likes this.
  30. May 13, 2023 at 4:37 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Not when it’s made complicated
