Oil change
Discussion in '3rd Gen Tundras (2022+)' started by WasAChevy, Mar 11, 2022.
  1. Mar 11, 2022 at 12:24 PM
    WasAChevy
    WasAChevy [OP] New Member
    Has anyone done their own oil change yet?
    Any tips or pointers? I am assuming the filters are available at the stealerships?
  2. Mar 11, 2022 at 12:36 PM
    xc_tc
    xc_tc New Member
    Why not take it to the dealer for the service? It’s free for 2 years/25k miles.
    Mike59 and Syndicate like this.
  3. Mar 11, 2022 at 1:40 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    I’ve done my own oil change on my 2022 at 600 miles. Wanted to do it at 500 but oil filter wasn’t available yet at the time. Suggest getting a 15mm hose to drain the oil filter. Keeps everything clean. Got the hose off Amazon. Cut it in half and saved it for later. The original oil was really black.
  4. Mar 11, 2022 at 2:54 PM
    WasAChevy
    Well, I am a 4-5K oil change kinda guy. The "free" oil changes can only be done at 10k intervals.
    Allrsdup and lord.kinbote like this.
  5. Mar 11, 2022 at 2:56 PM
    WasAChevy
    Thanks! How many quarts? I had heard that the filter was designed in an upside down vertical position....doesnt look like it. Did you use an OEM Toyota filter?
  6. Mar 11, 2022 at 3:21 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    Yes oem filter and I also got oem oil. Truck takes 7.7 qts 0w-20.
    WasAChevy[QUOTED][OP] likes this.
  7. Mar 11, 2022 at 3:34 PM
    737fixer
    737fixer New Member
    Huge fan of the break-in oil change. Everyone including the manufacturers say it's unnecessary but throughout this form (1998-2022) when people send their first sample to Blackstone it always comes back high in metals. Blackstone always states this will reduce in subsequent changes after break-in. I also do the diff's as they also have shown early high metals from Blackstone. TFL Truck literally just did a video on their 2022 Tundra and it also showed high break-in metals on first oil change. Pretty cheap and simple maintenance to argue against it.
    kstateskier, Mike59, raylo and 2 others like this.
  8. Mar 11, 2022 at 4:52 PM
    xc_tc
    xc_tc New Member
    Ah, I see. Well you can get a every other oil change free.
  9. Mar 11, 2022 at 9:43 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    That's not a Toyota policy, that must be your dealer making up rules. I was told to use them whenever I wanted. I asked about the "need" to change the oil at 500 or 1000 miles and was told it wasn't necessary but could use my "free" oil changes and do 500 and 1000 if I wanted to.
  10. Mar 12, 2022 at 1:12 AM
    Osiris
    Osiris New Member
    20 Plat
    You can tell them to do it at 5k if you want. I had them do both 2 free oil changes at 5k and 10k.
    The manual states to do them at 5k if you're a normal driver that drives where temperatures go below 32F or don't drive 300-400miles a day.
    https://www.youtube.com/watch?v=TevK-u3vkx4
  11. Mar 12, 2022 at 8:20 AM
    coolbeans
    coolbeans New Member
    Has anyone here actually had a dealership use the wrong fluid or otherwise mess up a fluid service?
  12. Mar 12, 2022 at 10:09 AM
    JPCanadian
    JPCanadian New Member
    Just did mine yesterday:
    -12mm socket
    -14mm socket
    -46 mm oil filter wrench.
    - length of 15mm hose
    Had a bitch of a time getting oil filter off until I got the proper oil filter wrench. Could not get strap wrench to budge it, it is a tight area.
    toyofan87 likes this.
  13. Mar 12, 2022 at 10:41 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Oil threads never gets old...wait for it!!
  14. Mar 12, 2022 at 1:32 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    I think the oil filter was tighten on by the Hulk. That shit was tight as hell. :rofl:
    I manage to get it off with a Harbor freight oil filter pliers. Crushed the hell outta the filter though. There was tons of room for me, once the engine undercover was removed.
    Torque specs if anyone wanna follow "factory spec" even tho it was tighten way more when they assembled the engine:
    I just hand tightened it.
  15. Mar 12, 2022 at 1:47 PM
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    Oil talk makes my brain hurt. I don’t talk politics, COVID or oil lol. You’re right though “winter is coming”
    toyofan87[QUOTED] likes this.
  16. Mar 13, 2022 at 3:39 PM
    JPCanadian
    I wanna know how you got a copy of the shop manual!
  17. Mar 13, 2022 at 4:04 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    13 lb-ft for the filter. Think: snug aspirin bottle lid. That's it.
  18. Mar 14, 2022 at 6:04 AM
    kmangino47
    kmangino47 New Member
    2022 limited TRD off-road
    waiting waiting waiting to take delivery
    FYI did oil change at 1k with dealership $88.44EEC9BA5A-0EBC-458C-8123-70C762C14981.jpg
    coolbeans likes this.
  19. Mar 15, 2022 at 3:30 PM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    The fact they have to list the oil fill quantity without changing the oil filter is scary. I can't think of a reason you wouldn't change your filter during the oil change, but I guess it happens enough that Toyota felt the need to list it. As least the dry fill, I can understand if you had to drop the oil pan or some major engine work.
  20. Mar 15, 2022 at 3:44 PM
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    If you change your oil every 2.5-3k miles say with a vacuum extractor - there’s no need to change the filter very often.
  21. Mar 15, 2022 at 3:47 PM
    Rwaters
    Rwaters New Member
    @toyofan87, SD172 might have started the debates
    :crapstorm:
  22. Mar 15, 2022 at 3:50 PM
    sd172
    sd172 New Member
    South Dakota
    There might be a somewhat new crowd here, all 2/2.5 gen people already know what’s going on. :deadhorse:
    toyofan87 and Rwaters like this.
  23. Mar 15, 2022 at 3:54 PM
    Rwaters
    Rwaters New Member
    I’m here to watch haha. I enjoy the pure anger and passion folks have about the topic.
  24. Mar 15, 2022 at 3:55 PM
    KroppDuster
    Bilstein 5100s
    I don't really "change" my oil as much as I leave the drain plug off and have a giant, gravity fed tank of fresh oil just constantly feeding into my engine.
    Pros:
    • Engine ALWAYS has fresh oil.
    • Engine will last forever.
    Cons:
    • Oil is REALLY heavy, thus gas mileage is awful.
    • It's not exactly what you would call "environmentally friendly"
    • Carrying a giant tank of oil makes the engine work a lot harder due to weight...thus probably eliminating the #2 bullet above.
    PomDad, Kap1, ArcticEd and 3 others like this.
  25. Mar 16, 2022 at 1:07 PM
    Oil dammit!!!!! Arrrrghhh!!!! Loud noises!!!!!
  26. Mar 17, 2022 at 8:54 AM
    alex17117
    alex17117 New Member
    Alex
    2024 limited, Lunar Rock
    Dealers should agree to do the free oil changes at any time you want. On my 2021 Tacoma, I had the dealer do the 10k service with the oil change at 5k. I will likely do the same with my new Tundra.
  27. Mar 17, 2022 at 10:54 AM
    Phil_G_93
    Phil_G_93 New Member
    Phil
    2017 MGM Tacoma Limited
    You should request $5 back! Haha, don’t they know the 22 is a 6 cylinder not an 8??
    Donas, Ely010606, toyofan87 and 2 others like this.
  28. Mar 17, 2022 at 3:50 PM
    kmangino47
    Honestly did not even pay attention, I just paid 90 at jeep for wrangler v6.
  29. Aug 20, 2022 at 12:38 PM
    Livin
    Livin New Member
    Kevin
    24 Black Pro
    Well
    Then ,, this 3.5 is completely different than Tacoma 3.5 ,,
  30. Aug 20, 2022 at 12:40 PM
    alex17117
    Alex
    I changed my oil at 6k and was shocked how black the oil was… wish I had changed it much earlier. I am sending it in for analysis. I’ll post here with the results.
    Also going to stick to a change every 5k.
    Carolina Peej and Hadelson like this.
