Oil changes 3000 miles or 5000 miles?
Discussion in '2.5 Gen Tundras (2014-2021)' started by kcaustin66, Dec 3, 2018.
  1. Dec 3, 2018 at 7:43 PM
    kcaustin66
    kcaustin66 [OP] New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    I have a 2015 CM with a 5.7L I have been changing the oil at 5000 miles, my daughter has a 2010 CM with a 4.6L she was told to change at 3000 miles.
    we both use Mobil one 0w20 Synthetic Motor Oil.
    I try and check my oil about every 2-3 fill ups. it looks like it could be a little low on oil. (no leaks or burning oil that I can tell).
    seen where someone made a comment that when you go 5000 miles between oil changes that it is hard on the Cam Tower seals any truth to that. Could that be what is making the Cam Towers seals leak.
  2. Dec 3, 2018 at 7:45 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Oil change intervals should be as recommended in the owner's manual. I have a FFV and it recommends 5,000, but I think it is even lower depending on the actual gas you are using. Some engines are 10,000 intervals.
    Absolutely no truth to the oil change interval being related to the Cam Tower seals. The seals are just a crappy design. Some of them will leak no matter what you do.
    Watt maker likes this.
  3. Dec 3, 2018 at 7:48 PM
    wyone
    wyone New Member
    2018 Tundra DC
    dashcam... more to come
    My 2018 DC 5.7 just had my 5000 mile maintenance... they told me the oil gets changed at 10,000 in the new trucks
  4. Dec 3, 2018 at 7:55 PM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Leitner Designs ACS
    Same. ^^^^^
  5. Dec 3, 2018 at 7:59 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    As stated. FFV is 5000. Non FFV is 10k.
    Not sure what you have? Check your gas cap to see if you can use E85 or not.
    UNTMatt and BTBAKER like this.
  6. Dec 3, 2018 at 8:01 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    This^^^^
    Also, the 5.7 takes 7.9 qts. I use 6.9 qts of oil and use 1 qt of Lucas Oil, Full Synthetic Stabilzer. Used the stuff for years and swear by it.
    I know some DOD ninjas over in the sandbox that use it in their rigs. Good enough for them, good enough for me.
    Fishman57, Black Wolf and wyone like this.
  7. Dec 3, 2018 at 8:05 PM
    kcaustin66
    kevin
    my is FFV 2015 CM 1794 5.7L and I use 87 octane regular unleaded
    my daughter uses super sometimes hers is the 4.6L 2010 CM SR5
  8. Dec 3, 2018 at 8:08 PM
    Jengel451
    The Bitterroot, MT
    Go by the manuals recommendation and you'll be fine.
    kcaustin66[OP] likes this.
  9. Dec 3, 2018 at 8:22 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    I'd just go by the manual on the interval. I can see changing it early on the first oil change when brand new (though I hear it's really not necessary). But otherwise, I think changing the oil at 3k miles is a waste.
  10. Dec 3, 2018 at 8:35 PM
    wyone
    wyone New Member
    2018 Tundra DC
    Non flex fuel here.. so 10,000... still seems weird.. lol
  11. Dec 3, 2018 at 8:39 PM
    Gibo244
    Gibo244 New Member
    KG
    Maui
    Up to u. It may be old school but I have 300k+ cars with no engine trouble 4 years old. 3k mike changes. They put 10k cause maintenance is free for two years. :anonymous: Your car will be ok up to the warranty period.
    GAknight, B737 and wyone like this.
  12. Dec 3, 2018 at 8:45 PM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    I agree w this. I do tundra between 5000-7000, do what makes you feel good without exceeding 10 (non flex fuel).
  13. Dec 4, 2018 at 1:35 AM
    rsgt
    rsgt New Member
    2019 crew cab TRD sport 4x4
    all stock
    My new flex fuel 5.7 Toyota care does it every 5000 miles or 6 months which is my case. Bought in oct 2019. Door sticker reads 9 2019 built.
  14. Dec 4, 2018 at 1:39 AM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    37k miles. Oil change every 10k as per manual. No issues
  15. Dec 4, 2018 at 4:36 AM
    leesrig
    leesrig dick
    2014 double cab 8 ' bed sr
    bam budget muffler, tinted windows, nfab wheel to wheel nerf bars, 3" lift front , 2" lift in back and airbags, l.e.d. head lights , tail lights, interior lights, window visors, fender flares, tailgate folding step, system one ladder rack and tool boxes, rigid led fog lights, rear seat back folding mod, rims and 35" tires
    got a 2014 with 61,000. do it every 10,000 as per toyota. no problems
  16. Dec 4, 2018 at 4:44 AM
    lawfarm
    lawfarm New Member
    2018 Tundra SR5 Premium TRD Crewmax
    Huh. I have an 18, 5.7, non-FFV. Manual specifies 5k oil change interval, currently paid with Toyota care.
  17. Dec 4, 2018 at 4:48 AM
    NixonVZ
    NixonVZ New Member
    2018 Cement Tundra SR5
    TRD wheels, TRD leather seats, TRD Bilstein shock upgrade in the front and rear.
    Took mine to the dealer at 5k and they told me oil changes are every 10k on the newer trucks. Seems weird but I will follow the manufactures recommendations.
  18. Dec 4, 2018 at 5:15 AM
    15whtrd
    15whtrd Mr. Blonde
    I do around 5k oil changes. Which for me is about once a year.
    OR18TRD likes this.
  19. Dec 4, 2018 at 5:49 AM
    Atomic City Tundra
    Devin
    New Mexico
    The online manual for a 2018 non-FFV indicates a 10,000 mile oil change interval. Might want to double check yours. Page 38 in the maintenance log, you can see the maintenance log and oil changes are only on the 10,000 marks. Not that changing every 5K is bad, but just a waste of money. There is "maintenance" recommended every 5,000, but each interval does not recommend oil changes for non-FFVs.
    T500 and 15whtrd like this.
  20. Dec 4, 2018 at 6:08 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I have a 2017, 5.7L, FFV (flex fuel). I change every 10,000 miles. Use Mobil 1 0W20 full syn. I've sent my last 3 oil changes to Blackstone Labs and the report back from them is all is great. They actually suggest using a 13,000 mile oil change interval now. You'll want to know my last change was at 40,000 miles and I'm at 42,000 miles now. I didn't send the lab the Mama Toyota original oil.
    Now. The 5,000 mile interval for FFV engines in the Toyota manual. That manual MUST address the possibility that the owner of a FFV engine WILL run E85 gasoline. Therefore the lower mileage interval. This is the concept of "lowest common denominator." You can have an FFV engine, not run E85, and change it every 5,000. But my belief is you sure don't have to.
    And now the lawyer part: YMMV.
  21. Dec 4, 2018 at 6:19 AM
    Jengel451
    The Bitterroot, MT
    Can you post the last Blackstone Lab report? I haven't submitted mine yet and would love to see how it looks. TBN report is worth the extra few bucks. It's good to hear that they are recommending extending intervals, shows the engine tolerances are pretty good and using a quality oil reaps benefits.
    FFV intervals, in my mind are shorter as a CYA/Litigation effort, they actually recommend 2500 mile oil changes if you're actually using E85, show's how crappy that fuel really is on parts.
  22. Dec 4, 2018 at 6:26 AM
    BoTheTundra
    BoTheTundra New Member
    Thomas
    2007 tundra TRD sr5
    Lift with rims and tires, exhaust mirrors skid plate, whole interior sound system and head unit
    I have an 07 5.7 with the tow package, I guess the first year oil cooler lines are something small like that was diff with the tow package, (correct me if I'm wrong) but my pops bought the truck new in 07 and has done every 3000ish and I bough it from him in 14 and done every 3000ish. All been conventional and never swap weights for in winter, I live in IL. My dad's in the union for heavy machinery (local 150) and is one of those baby EVERY peice of equipment we own, so that's why we've done every 3000 but I'll tell you what I've rolled over 210k this past summer and there truck runs the same as it did at 5k, 50k,150k and I can only guess that doing it every 3000 helped quite a bit with that
  23. Dec 4, 2018 at 6:27 AM
    Atomic City Tundra
    Devin
    New Mexico
    I had one done at ~57K miles. I didn't get the TBN as I am under warranty until 100,000 miles, so I am going to stick with the 5K interval until that runs out. Report indicated that my engine was wearing slightly higher than average. But not too bad.
  24. Dec 4, 2018 at 6:33 AM
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
    bought new in October, dealership has set up a 5000, 5 month maintenance plan. I guess It won't cost me for the next 2 yrs so it doesn't matter.
  25. Dec 4, 2018 at 6:38 AM
    Stig
    Stig New Member
    3000!? I treat my motor right, every 1000 miles.
    Supersport and Gibo244 like this.
  26. Dec 4, 2018 at 6:58 AM
    Jengel451
    The Bitterroot, MT
    With Organic Cold Pressed Coconut oil? Nothing but the best.
  27. Dec 4, 2018 at 7:02 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Lately I’ve been changing mine every 7-8k miles. I use Mobil1 synthetic.
    I just have a feeling you’ll never find somewhere that says, “man if only you changed your oil every 5k instead of 8k then you wouldn’t be having all these problems.” Just listen to your owners manual and stick within their guidelines.
    Jengel451 likes this.
  28. Dec 4, 2018 at 7:02 AM
    Jengel451
    The Bitterroot, MT
    The Iron number is the only one that sort of pops with me, but that's not a bad number really. The other high ones may be the oil. What Air Filter are you using?
  29. Dec 4, 2018 at 7:07 AM
    Atomic City Tundra
    Devin
    New Mexico
    OEM. Really, I don't think that was a bad report at all. I only got the report at the time out of curiosity. I will start getting them again once I break past the warranty point.
  30. Dec 4, 2018 at 7:11 AM
    Jengel451
    The Bitterroot, MT
    I agree, it's not bad at all. I ask about the Air Filter because the Silicon number is really really low. This shows that the OEM filter is pretty dammed good.
