Oil filter housing check valve? Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Radarninja, Feb 23, 2022.
  1. Feb 23, 2022 at 7:35 PM
    Radarninja
    Radarninja [OP] New Member
    Ryan
    Ca
    What’s with this check valve?
    In the center, came with a cover and gasket- in the other baggie. BE664B60-E6E2-4995-93D2-1472C89D377D.jpg Don’t see why you have a check valve when it’s covered??..
    I just got the truck. Still have lots of learnin.
  2. Feb 23, 2022 at 7:41 PM
    Anohibian
    Anohibian New Member
    Anchorage, AK
    2018 Inferno Crewmax
    That allows you to drain the oil from the filter when you do an oil change. That way you aren’t dropping your filter and housing full of oil.
    Radarninja[OP] likes this.
  3. Feb 23, 2022 at 7:41 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    not a check valve.
    oil canister drain plug. This way you can drain the housing before cracking it open without it being a giant mess…
    motiv-x is a popular option that threads into the housing and has a drain tube with flow control.
  4. Feb 23, 2022 at 7:43 PM
    Anohibian
    Anchorage, AK
  5. Feb 23, 2022 at 7:44 PM
    Radarninja
    Ryan
    Ca
    So without any special tools you just stick a screwdriver in there or what?
  6. Feb 23, 2022 at 7:47 PM
    Anohibian
    Anchorage, AK
    Most filters come with a little plastic piece for you to put in there and drain it out.
  7. Feb 23, 2022 at 7:49 PM
    Anohibian
    Anchorage, AK
  8. Feb 23, 2022 at 7:49 PM
    No.....a new filter comes with a plastic piece that you push in to drain it which is messy. If you want a clean oil change, get the drain hose setup as mentioned. Many of us also have Fumoto oil pan drain valves.
  9. Feb 23, 2022 at 8:08 PM
    Radarninja
    Ryan
    Ca
    Cool cool thanks doods for the info.
    Much appreciated, don’t know what you don’t know I guess.
    tundratoofun likes this.
  10. Feb 23, 2022 at 8:58 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Life, like this site is a learning experience, stay on here long enough, you might learn some shit, from all the fine people!!!!
