Oil Filter question
Discussion in '3rd Gen Tundras (2022+)' started by ArmygreenTRD, Jun 19, 2023.
  1. Jun 19, 2023 at 5:28 PM
    ArmygreenTRD
    ArmygreenTRD [OP] New Member
    2022 Army Green TRD, SR5 DC
    Can anyone that has changed their filter take a look at this. Filter on the left is what was taken off. One on the right is what the dealer gave me. Parts Dept used my VIN to look up. Seems odd. TIA.IMG_4508.jpgIMG_4509.jpg
    Kap1 likes this.
  2. Jun 19, 2023 at 5:39 PM
    TundraTT
    TundraTT Full Send
    23 Taco Trail 97 FZJ80 68 Goat
    Your new one is correct.
    I let the dealer do my first oil so I can’t confirm if your old filter was used on early production runs. Either way you’re set now
  3. Jun 19, 2023 at 5:40 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    one on the right is the one they come with from the plant - the one on the left is the revised one - looks like they changed your oil / filter somewhere along the line and used the revised / superseded part. Original made in Japan - revise one somewhere else
  4. Jun 20, 2023 at 4:25 AM
    raylo
    raylo not so new member
    Frederick, MD
    Dealer here also gives YZZF1s. I have used them and they fit and work same as the other one. Went through this question awhile back in another thread and cut some open and they were very similar. The ZZ1s are just a few mm taller. I have a few of each type and will use them interchangeably. They both take the same cap wrench.
  5. Jun 20, 2023 at 9:46 AM
    rlc177
    rlc177 Data Logger
    Northeast PA
    The F1 is the very common filter. Toyota came out with the 90915-10010 filter just for the V35A application, which is very un-toyota like. I wonder if the V35A part has different bypass PSI or flow specs. I'd be personally very nervous about using F1 because if F1 worked toyota would not have came up with a completely different part for the V35A only.
    walleyes and ryanwgregg like this.
  6. Jun 20, 2023 at 12:25 PM
    Clockwatcher68
    Clockwatcher68 New Member
    23 MGM Tundra TRD Offroad
    I had read through the earlier thread discussing YZZF1 vs 10010, so on my 1,000 mile oil change I was paying attention. Local dealer sold me a 10010. Also, 10010 was what I removed from the truck, and was what they installed at the factory. April 2023 build date.
    Ray D, Mattedfred, walleyes and 2 others like this.
  7. Jun 20, 2023 at 2:59 PM
    walleyes
    walleyes ‘23 Tundra
    Very interesting, thank you for sharing.
    Sparks Parts lists the vehicle applications for the 90915-YZZF1 filter and the Tundra isn’t included:
    https://www.sparksparts.com/oem-parts/toyota-genuine-toyota-oil-filter-90915yzzf1
    Sparks Parts lists the 90915-10010 as the filter for the Tundra:
    https://www.sparksparts.com/oem-parts/toyota-genuine-toyota-oil-filter-9091510010?c=az0x
    I’m surprised the Sequoia is not listed though.
    Mattedfred likes this.
  8. Jun 22, 2023 at 8:19 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    ryanwgregg likes this.
  9. Jun 22, 2023 at 8:52 AM
    Tom976
    Tom976 New Member
    Tom
    I faced this issue when I did my first oil change (well getting the parts for it)
    In the end I stuck to whatever the factory sent with the truck.
    90915-10010
    So now I have a case of 10 of them and will be using them for some time.
    303Gen3, pwpblue and ryanwgregg like this.
  10. Jun 22, 2023 at 9:19 AM
    pwpblue
    Greensburg,PA
    Now I'm going to have to take a look see under my truck.
  11. Jun 22, 2023 at 11:27 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Very interesting, so now I can check if the dealer actually changed my filter at 1k mile oil change...
  12. Aug 3, 2023 at 11:52 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    It's interesting that the dealer wouldn't have the correct filter on hand. When I work for a parts department, a new engine release you would get a list of recommended parts to stock and some were just sent to you to have on the shelf.
  13. Aug 3, 2023 at 12:02 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Just curious, so the Gen 3 Tundras went back to spin-on filters and went away from the cartridge filter of the Gen 2 and 2.5? I thought that spin-ons were death to the environment.
    WILLINH likes this.
  14. Nov 1, 2023 at 11:43 PM
    02TundraIdaho
    02TundraIdaho New Member
    LG
    02 Tundra / 11 ES350
    no Mods... has new headlights and some dings on the side... just purchased a dent puller and Bilstein 5100's for it..... absolutely love it in the 2 weeks I've owned it...
    In my opinion the shorter the filter with less volume would be easier to push fluid through as long as filter is changed regularly!! Less vertical height! Regular changes absolutely necessary to avoid restriction! I put the wrong filter on about 350 miles ago (YDZZ1) when I should of gone (YDZZ3) for a UZ2 motor, I didn't get a red flag because it was the same size as the filter I replaced. My oil pressure on dash has shown exceeding pressure on an engine with 230K.... I drive Semi's for a living and always look at oil pressure.
    Probably the only difference in the two profiles is a slight volume of oil at change intervals and distance to supply top of motor by a few millimeters! But Toyo filters are designed to keep supply line filled for start ups... thus longevity!!
    Anyone out there reading this? and I'm wrong on any detail? please chime in!! love learning! and will entertain new thoughts/ideas!
