Oil leak after the cold?
Discussion in '3rd Gen Tundras (2022+)' started by SP3ll✔️, Jan 15, 2024.
  1. Jan 15, 2024 at 8:18 PM
    SP3ll✔️
    SP3ll✔️ [OP] New Member
    Western ND
    23 Black Tundra TRD OR 4x4 Limited
    I park on the street. This morning I flipped a u-turn and noticed oil where the truck sat. Got to work and took off the skid plate to find oil coming from the little catch under the oil filter. Filter is tight. Break cleaned area and called dealer. Dealer states that maybe after the cold, the o-ring on the filter may have been pinched and the extream cold caused a leak. Oil level checks out ok. Do I belive the Dealer? Truck has 12,600 on it and never leaked before this last 8 months.
  2. Jan 15, 2024 at 8:47 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    How long since your last oil change?
    GODZILLA likes this.
  3. Jan 15, 2024 at 8:54 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    Sounds like he has no idea and now he is making up stuff.
    Eagleye likes this.
  4. Jan 15, 2024 at 8:54 PM
    Did you do your last oil change, or did the dealer? If it was the dealership, I'd take it back and have them check it, because it is possible the tech was lazy and didn't oil the new seal first. There's not an o-ring on the new Tundra filters. It's a gasket for all the regular type of filters. The dealership might have been mistaken thinking it's a cartridge filter like the previous generation Tundras.
  5. Jan 16, 2024 at 7:34 AM
    SP3ll✔️
    Western ND
    Back at the dealership. 4,500 on the oil change. I don't care for the way the setup is by the filter. I would like to see the threads and seat area. Will let them do the changes until the freebies are up. Will pay for 5k oil changes though.
  6. Jan 16, 2024 at 12:18 PM
    SP3ll✔️
    Western ND
    UPDATE!
    Culprit turns out to be "engine oil cooler leaking" ~ parts on order. Service guy...just keep an eye on your oil level.
    Mattedfred, raylo and IsaiahCanada like this.
  7. Jan 18, 2024 at 11:59 AM
    SP3ll✔️
    Western ND
    Fall over!!! Parts are in. Appointment on Tuesday
    Mattedfred and sandiegosteve like this.
