One reverse light not working
Discussion in '2nd Gen Tundras (2007-2013)' started by ajperea, Dec 20, 2020.
  1. Dec 20, 2020 at 12:32 PM
    ajperea
    ajperea [OP] New Member
    2007 White Tundra 5.7 CrewMax
    Hi. New user here. 2.43/10 on the DIY scale. I’m a teacher so I’m pinching pennies where I can.
    My 2007 Tundra 5.7L is due for an inspection this month so it’s time for me to finally take care of this after a few months.
    My passenger’s side reverse bulb isn’t fully functioning. The bulb works properly for a turn signal and the hazards, but not when the truck is in reverse. The driver’s side reverse bulb is fully functioning. I have replaced both bulbs, so that doesn’t appear to be the issue—any bulb that works on the driver’s side has the same issues when connected to the passenger’s side.
    Any suggestions would be appreciated!
  2. Dec 20, 2020 at 12:42 PM
    TheBeast The Beach
    have you try swapping the passenger side reverse light bulb to the driver and see if it works ? reverse is a bulb on its own so it might be bad.
    otherwise check wiring if any cuts or chewed.
    video here that shows which one to look at:
    https://www.youtube.com/watch?v=sY5OnpXvmzc
  3. Dec 20, 2020 at 12:47 PM
    timsp8
    NY
    If it’s not led you’re putting in there, it shouldn’t matter which way it goes in. Since your known good bulb doesn’t work, try a voltmeter on the connection and see if it’s getting power. If you don’t have one, you might be able to go to an auto parts store and ask them to test it.
  4. Dec 20, 2020 at 1:50 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    Also check the socket for corrosion
  5. Dec 20, 2020 at 6:15 PM
    ajperea
    Got it! Thanks for the advice. There was a loose connection somewhere. I disconnected both wiring harnesses and switched them. Now they’re both working. Thanks for the input!
    TheBeast likes this.
