OPT7 Running lights won’t turn on
Discussion in 'Lighting' started by mav7021234, Oct 10, 2022.
  1. Oct 10, 2022 at 12:26 PM
    mav7021234
    mav7021234 [OP] New Member
    My OPT7 running board lights won’t turn on with the amber DRL or turn signals. There’s 4 wires.
    -Yellow/Red are the Turn signal/DRL
    -White/Black are the courtesy light/ground
    I tapped into my front turn signal wire harness for both sides.
    The courtesy white lights work. I tapped into the footwell courtesy lights for the white light and ground
    I tried switching the Yellow and red wires and tapping differently into the turn signal harness and it still doesn’t work.
    The ambers worked when I tested them before installing on my truck. Any suggestions? I’m stumped.
  2. Oct 10, 2022 at 4:05 PM
    mav7021234
    *PSA
    For anyone that’s having the same issue, I fixed it somewhat.
    I had to wire the courtesy and ground wires on the running board to the cargo light wire and ground on the body. Now the DRL/Turn signal function works.
    Only annoying thing is, I have to have my DRL/headlights on for the turn signals to work. If my DRL lights are off, my turn signals only blink once. Idk how to fix that
