Oriface value location
Discussion in '3rd Gen Tundras (2022+)' started by TundraDriver$$, Jun 16, 2024.
  1. Jun 16, 2024 at 2:03 PM
    TundraDriver$$
    TundraDriver$$ [OP] New Member
    Colin
    22 Tundra
    I have every high high side pressure, 350 psi, and want to replace the orifice tube and expansion valve. I am having a hard time finding an orifice tube on line. Does it have one? I see something on the condenser but am not sure if it is indeed the orifice tube. It is not what I expect.
    Thanks,
  2. Jun 16, 2024 at 2:56 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Might have better luck in the 3rd Gen. Tundra forum. And, pictures always help.
  3. Jun 17, 2024 at 5:30 AM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    It probably doesn’t have an oriface. Probably only uses expansion valve. I’m not sure what you see on the condenser but on the gen2.5 there is a filter dryer on the condenser, that may be what your seeing.
    raylo likes this.
  4. Jun 17, 2024 at 5:42 AM
    I’m guessing your 22 is out of warranty already?
  5. Jun 17, 2024 at 5:45 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    A clogged orfice would cause lower pressure because it’s all being condensed and stacked in the condenser not actually picking up heat(pressure) from the evaporator
  6. Jun 17, 2024 at 5:55 AM
    raylo
    raylo not so new member
    Frederick, MD
    What refrigerant do we have and what are the normal operating pressures? I did a lot of A/C work on my old GM R134A vehicles but my 2009 Tacoma went 15 years and never needed anything, so I need to bone up. IIRC I put gages on it once to have a look when it was 3 years old and that was it. Never touched it again, and it worked 100% when I sold the truck.
    As noted above, almost certain we have expansion valves, not old school orifices.
  7. Jun 17, 2024 at 8:57 AM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    Blocked airflow through condenser up front is the first thing to check, debris, grille inserts, shutter malfunction, fan clutch operation, etc...
  8. Jun 17, 2024 at 9:04 AM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    A/C head pressure will soar if insufficient airflow over condenser!!!!!
  9. Jun 17, 2024 at 9:28 AM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    Toyota vehicles have never used orifice tubes like many domestic brands use, they use expansion valves, later models use H block style expansion valves.
    pwpblue likes this.
