Outdoor weatherproof truck cover
Discussion in 'General Tundra Discussion' started by GrimReaper, Apr 25, 2019.
  1. Apr 25, 2019 at 8:46 AM
    GrimReaper
    GrimReaper [OP] New Member
    Dave
    2016 Red Toyota Tundra Crewmax SR5 TRD 4X4
    Just purchased it a few weeks ago (April 2019). Only mods so far are tinted front side windows, LED fog light bulbs (will be adding LED headlights soon!) and LED interior lights.
    I am a new member and this is my first posting. I am searching for the right truck cover for my situation. My truck sits outside with no type of protection from the sun, rain, bird droppings, etc. After researching covers, it looks like it is best to have a breathable cover to let moisture out from underneath, but these types of covers are not guaranteed to keep rain water from getting to the truck. I like to keep my truck clean so I do not want rain bleeding through or moisture forming underneath and messing up my detailing job. It needs to have the soft inner lining to protect the paint, durable enough to withstand the hot summer sun and cold winter months with some snow, yet manageable enough for me to put on and take off by myself without being too heavy or bulky (I'm 5'10", 49 years old, and this is a 4WD Crewmax). I drive the truck 2-4 times a week, so taking the cover on and off will be regular. Any guidance in this area would be much appreciated!
    2016 Tundra Crewmax SR5 TRD
  2. Apr 25, 2019 at 9:38 AM
    Dontra
    Dontra Newer
    Don
    AR
    2021 Ram Big Horn
    2021 Ram Patriot Blue, Lonestar or Bighorn, Crew cab 4x2, 5.7 bed, 5.7 Hemi etorque, Level 2, anti-spin 321 rear end, Air ride, 33 gal tank, 18 in wheels, Multifunction tailgate, Ram box, Wheel liners, MT Brown Deluxe bucket seats, 8.4 no navigation, Trailer brake controller. Front and rear rubber mats. Mopar power steps,8 yr 85K extended Mopar warranty.
    Build a carport or garage. That would be the best in the long run
    NewImprovedRon likes this.
  3. Apr 25, 2019 at 9:42 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Welcome from San Diego. As mentioned above, a carport would be best if you have the space for it. With regards to a cover, I’m not much help. I know they make high end covers for cars but I’ve never seen them for a truck.
    I would check out CoverCraft and see what they offer. They have quality products and may be able to make you a custom cover if needed.
  4. Apr 25, 2019 at 9:55 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  5. Apr 25, 2019 at 11:23 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Welcome from WI. Covercraft makes some very good, well fitting covers. The ultra'tect or Noah covers would likely be the best fit for your needs. One thing to be aware of ...and I've seen it firsthand... is paint wear from wind. Even the best fitting covers will flap in the wind and regardless of what they're lined with, it will cause paint damage on corners and body lines. You'll also have to remove and reinstall your antenna every time you put the cover on or take it off.
