Over the top bed rail bracket
Discussion in '2.5 Gen Tundras (2014-2021)' started by Backstrap, Dec 28, 2021.
  1. Dec 28, 2021 at 6:01 AM
    Backstrap
    Backstrap [OP] New Member
    2021 Tundra SR5
    Hi everyone, I want to mount pod lights in the bed of my truck. I found these for a Tacoma, not sure if they’ll work for our Tundra. Has anyone used these?
  2. Dec 28, 2021 at 8:14 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    Yes they make a bracket, the upper one in my images. They mount one eighty from he way I have them mounted and stick into the bed. I like the ones you have posted a lot better, I don't see why they wouldn't work on a tundra. I had to make a couple of brackets to get my lights out of the bed space so to speak.
    No idea why its posting one image twice, unsure how to fix either.
  3. Dec 28, 2021 at 1:45 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Pretty sure it should fit all bed rails. As long as your t-slot nuts can slide through, and your bolts fit through the holes on the chase light mounting brackets.
    Even if it doesn't fit through the mounting bracket, you can always use a hole drill bit and widen the hole to fit the proper size bolt for the t-slot nuts. I'm pretty sure it's 3/8x16.
    NewImprovedRon likes this.
  4. Dec 28, 2021 at 2:22 PM
    Backstrap
    2021 Tundra SR5
    Thanks, either of these I think will work. I have in the bed tool box and when you open the lid you need the over the rail mount for the lights to be out of the way of the lid.
